Question about Haier HWR05XC7 Wall/Window Air Conditioner
Freezes up when temperature drops outside. Drips water inside room.
    President:
  • 3,773 Answers
Sounds like a good cleaning of the coils and bottom pan would work
Don't forgrt to tilt the unit back off level a bit after cleaning.
Use a good coil cleaner spray
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 21, 2010
What does mean wayer coming from tailpipe 2000 Silverado
During combustion many gasses are produced as well as particulates. Water vapor (think super fine steam) is also produced and depending on the temperature outside and/or the temperature of the exhaust system (e.g. when first started it would be cool) the water vapor condenses and drips from the tail pipe. Just like water drips from an ice cold beverage container on a hot, humid day. ;-)
Nov 27, 2015 | Cars & Trucks
What is wrong with and Air Conditioner that continues to freeze up?
the ac cant keep up,you need a bigger ac or a smaller room,if the ac needs to keep cooling,it doesnt have a chance to cycle
Jun 23, 2015 | Norpole 5000BTU Mechanical Window Air...
Inside air sensor defect
The air sensor is part of the thermostat assembly. It controls the room temperature to whatever temperature it is set at. If the temperature varies too much, you may need a new thermostat. Other problems could cause various temperatures in the room. Low on refrigerant, due to a leak in the sealed system. Water in the system freezes and thaws to cause larger temperature variances.
May 18, 2014 | Samsung AS18A6RB Air Conditioner
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
My LG Split AC leaks, the water drips from the front right side (inside the room, where it is installed) instead of from the drainage pipe (outside the room). What to do?
Hello, make sure the unit is tilted back somewhat so the Condensate can drain toward the back and not collect up in the front. Also, make sure the drain tube is not obstructed or blocked with sludge.
May 25, 2011 | LG Heating & Cooling
Ice forms on the coils. Would wet clothing hung in the area contribute to this problem? The temperature of the area is in the high 50's - 60's.
Yes. Wet clothing would act to put Humidity in the air. think of the air as a sponge the more you heat the air the more the air will take moisture out of its surrondings. The more you cool the air the less moisture it can hold.
a Dehumidifier is a reverse refrigrator.. Air is forced over cool coils and the moisture forms and freezes on the coils (ice). The unit turns off and the coil and ice takes heat up from the surrounding area (makes room colder;Clothing takes longer to dry; The temperature in that room should be were people reside 70-80 degrees). the ice melts and water drips into a holding container which you dump periodically. Solution: 1. remove wet clothing or 2. raise temperature in room. 3. put a space heater in that room instead of Dehumidifier
Nov 29, 2010 | Dehumidifiers
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
AC works fine but water drips on passenger side
this is normal, water is the condensation leaking out,but if leaking inside the van then the drain is pluged up, the drain is on the pass/side outside the van on the firewall,blow air into drain or stick a coat hanger in to hole until water leaks out,
May 14, 2010 | 2001 Chrysler Town & Country
Indoor temp is 5 degrees colder than display reads on digital thermostat
Where are you measuring the indoor temperature?
To compare it to the thermostat temperature you have to measure both temperatures at thermostat.
The thermostat will only control the temperature at the thermostat, not any where else in the room.
The room temperature depending on insulation in walls and ceiling and distance from outside wall and outside temperature, can be as high as 10° difference from outside wall to inside wall of house.
The lower the outside temperature, the greater the room difference in heating. The higher the outside temperature the greater the room difference in cooling.
Feb 13, 2010 | Honeywell Programmable Thermostat Heater
My fridge freezes everything
If the temperature outside the refrigerator drops below the temperature inside such as in a non heated garage the things in the refrigerator will freeze. Short of moving the refrigerator to a temp controlled place there is not much you can do about it.
Jan 07, 2009 | Freezers
Haier HWR05XC7 Wall/Window Air Conditioner Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
