Question about Dishwashers
I just need a user's guide for a Whirlpool Quiet Wash dishwasher. I think it is a 2000 model. Thank you.
    Genius:
  • 1,073 Answers
Www.whirlpool .com and the site will direct you to the down load section to download the manual
Posted on May 03, 2008
Tip
I have a Whirlpool Quiet Parter I - I think the model # is 3385818. I tried this...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Dec 25, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a Whirlpool Quiet Wash dishwasher. I don't
yes.. keep going deeper you will most likely find what is blocking the chopper from turning.
Sep 10, 2009 | Dishwashers
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold quiet partner IV
You probably need to clean the filter; here is a site to show you how to do it: http://01tutorials.com/video/1686251/how-to-clean-the-filter-on-a-whirlpool-gold-quiet-partner-iv-dishwasher/4107
Sep 20, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dishwasher quiet #1
Have you figured your dishwasher problem out yet? In my Whirlpool, that tube doesn't fit on the wash column, it just snaps on to the lower rack, right above the washer column black rubber gasket... hope this helps!!!
Sep 02, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Wash Plus Dishwasher is not despensing the detergent properly. After a wash cycle there is still some left.
My Whirlpool Quiet Wash plus dishwasher seems to have died. No power. None of the buttons work, it quiet mid-cycle. No breaker issue, my garbage disposal runs off same breaker and is working fine. Any ideas? I was thinking the comp. board that the buttons work off of is fried. If this is the case any idea how much to replace it? Would it be cheaper to buy a new dishwasher?
Apr 21, 2008 | Dishwashers
Dishwashers Logo
100 people viewed this question
Top Dishwashers Experts
