Classixx1200 express the softner is not being taken from the tray and delivered to the drum
Hi.
That happens when the detergent drawer is clogged with rest of detergent.
Try pouring hot water mixed with citric acid (white vinegar also works but is smelly), use a boiler/kettle if possible and take care not to hurt yourself with the hot water. Ensure that there is no load and eventually disconnect power.
Pull out the dispenser drwawer and see if there is a blockage at the bottom of dispenser.
In that case clean the blockage.
On some machine there is a solenoid operated plastic tab at the bottom of the dispenser, in that case check the solenoid.
If machine is not filling at all, check inlet hose, inlet valve and pressure switch.
If that does not fix the problem, then the machine must be disassembled to reach the detergent drawer outlet and unblock it.
