Question about Toro Lawn Mower With Toro Power Tools
Replace pull cord on toro 6.5 hp lawnmower - Toro Lawn Mower With Toro Power Tools
3 Suggested Answers
jmgldsmth
  • 1869 Answers
SOURCE: Pull Start Locks
Disassemble and, re-engage the pull cord locking pawl spring
Posted on May 20, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Toro lawnmower appears flooded and won't start.
Actually all you have to do is take out the spark plug and pull the engine through several times. What has happened is the intake valve was open when you tipped the motor so when the fuel ran out of the carb into the engine it saturated the spark plug. You may have to by another spark plug to get it started or dry yours out very well. The main thing is to make sure that most of the liquid gas has exited the cylinder.
One more thing.... the float needle may have tilted a bit in the seat as a result of haging it tipped on its side. This is going to sound a bit strange BUT... grasp the handle and alternately bang the front and rear wheels on the ground a couple of times by lifting the back of the mower with the handle about 2 inches and drop it. Do the same by pressing down on the handle for the front tires. (2 inches and drop)
IT WORKS!
This should get you going. IF not just respond here and we can continue troubleshooting.
Kelly
Posted on Apr 15, 2010
Testimonial: "Thanks for the advice! I followed the suggestion and it worked like a charm. My hats off to you! "
I have a toro self propelled 6 hp lawnmower battery and pull start it wont start with battery but will with pull cord
Try to start it using jumper cables to boost it from another battery. If it starts, your battery needs replacing.
May 21, 2015 | Toro Lawn Mower With Toro Power Tools
Gas leaking from muffler
Blown engine. Replace engine.
Jun 17, 2012 | Toro Power Lawn Mower
10 year old Toro 2017 lawnmower, suddenly stopped while cutting grass. Oil quite low. Cannot pull cord more l than few inches.
When you pull the cord does it hit a hard stop and not go any further or does it get really difficult?
Aug 02, 2011 | Toro Lawn Mower With Toro Power Tools
Try to pull cord but seems seized on my self propelled lawnmower
Look underneath at your blade - it could be bent and hanging up. If not, remove spark plug and try to pull starter cord. If it won't move then you may have seized the motor and a new mower may be in order.
Hope this helps!!
Nov 16, 2010 | Toro Lawn Mower With Toro Power Tools
My toro lawnmower (brand new) it doesn't start.\r\...
The drive shaft might just need to be oiled. Turn the mower over and locate the drive shaft, where it goes from the mower's blade up into the body of the mower. Lubricate the area of the shaft that disappears into the body with WD-40 or another lubricant, then turn the blade by hand (be careful!) and squirt some more oil.
Eventually the blade should become easier to turn, and then your pull cord should extend without getting stuck. Good luck!
May 20, 2010 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 lawnmower wont start when you pull the cord it comes out about an inch then it locks where you cant pull it no more
Remove the plug then try and see if you can pull the cord any futher.If not you may have to dismantle the pull start and check the clips are not jamming.
Jul 06, 2009 | Toro Lawn Mower With Toro Power Tools
Pull Start Locks
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
357 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
