Question about Dryers
I need a new hose pipe thingy that the air comes out of
    President:
  • 1,033 Answers
You're looking for the vent that hooks up to the back and sends the heat out. You can buy these at Lowes or any local hardware store. Easy to install, usually with a big zip tie or a clamp
Posted on Aug 21, 2010
Where can i find a air condition tube pipe line for a Nissan bluebird u14?
Nissan Car & Truck A/C Hoses & Fittings ' eBay
www.ebay.com/sch/Nissan-Car-Truck-A-C-Hoses.../bn.../i.html
eBay90-96 Nissan 300zx OEM A/C ac hose line piping pipe #3. $20.99 .... 2002-2003Nissan Maxima 3.5L ' HVAC AC Air Conditioner Hose Line Tube OEM NEW.
Oct 14, 2015 | Nissan Cars & Trucks
I have a dc25 the pipe inside the handle has come through the top and i cannot get it down again can you please help
Try sprinkling some baby powder down inside the hose, between the wand and the hose. These hoses get sticky on the inside after a year or so . If that doesn't help you will probably need a new hose. Take it to your local vac repair shop.
Aug 20, 2014 | Vacuums
Mazda 626 gf 1.8l vacuum hose
Yes this is a vacuum just be careful to ensure it is sealed or you will have hardly Any braking :-)
Aug 13, 2012 | 1999 Mazda 626
2001 chevelot malibu 3001 engine is running hot. new head gakets, flushed everything for an hour, checked water pump, new thermostat nothing seems to help.......HELP
this engine needs the water/coolant blead on the top of the engine you should see a pipe with a screw insert ,if not find the top hose ie any water hose at the top of the engine and open it while the engine is running.You should see water /air coming out if the pipe keep going until all air/bubbles is gone.With all air gone the system should be ok,ren for 2 miles and blead again.please rate this answer.adrian,,,,,,,,,,,,,,
Aug 22, 2010 | 2001 Chevrolet Malibu
How do i chage the fuel injector for a geo metro 1997 LSI?
REMOVAL & INSTALLATION Fig. 1: Removing injectors from fuel rail 84245032.gif
Fig. 2: Make sure injectors rotate freely in cylinder head 84245033.gif
  1. Relieve fuel system pressure and disconnect the negative battery cable.
  2. Remove intake air hose between throttle body and intercooler.
  3. Remove accelerator cable.
  4. Unclamp PCV and fuel return hoses from deliver pipe.
  5. Unclamp injector wiring harness.
  6. Disconnect injector coupler.
  7. Remove cold start injector pipe from delivery pipe.
  8. Remove vacuum hose from pressure regulator.
  9. Remove fuel feed hose from delivery pipe.
  10. Remove pressure regulator from delivery pipe.
  11. Remove delivery pipe with injectors.
  12. Remove injectors from delivery pipe. To install:
  13. Replace injector O-rings and lubricate with fuel. NOTE: Make sure injectors rotate smoothly. If not, probable cause is incorrect installation of O-ring.
  14. Check if insulator is scored or damaged. If it is, replace with new one.
  15. Connect delivery pipe with injectors.
  16. Install pressure regulator to delivery pipe using a new O-ring.
  17. Install fuel feed hose to delivery pipe.
  18. Install vacuum and fuel return hoses to pressure regulator and clamp securely.
  19. Install cold start injector pipe to delivery pipe using new gaskets.
  20. Install injector coupler. Clamp injector wiring harness.
  21. Install PCV hose to cylinder head.
  22. Install throttle position sensor coupler.
  23. Install accelerator cable and adjust free-play.
  24. Install intake air hose to throttle body and intercooler.
  25. Connect the negative battery cable.
  26. Start engine and check for leaks.
Jul 03, 2010 | 1997 Geo Metro
Oil in my air filter box
This is just blow by from the crankcase breather system..the trapped oil in the box should be drawn back into the fuel air mixture to be reburned..its a smog pollution control design thingy..there is probably a hose attached to the bottom section of the air box...follow that hose to make sure that it didn't fall off from the top of the valve cover area..i think thats were it hooks up..at least thats where it is on my 87 cbr...i occasionally see a little oil in the box but nothing to worry about. if the hose is off its probably leaking down onto the exhuast pipes and thats the smoke you see. please let me know im curious.
thanks
Apr 05, 2010 | 1997 kawasaki ZX-6R Ninja
Bmw e46 318i , engine has high pitch noise after about 30 40 min driving like a screetching noise ,i had a split hose at the back behind the spaceship thingy , and i replaced the double pipes with bmw...
rubber pipe , its at the back under the pollen filter , comes as a double pipe one fat one thin , fat one is for air flow , thin one water , both for cooling the engine. The fat one was actually split , causing my engine to idle bad , so i replaced the part , engine idle is fine but now i gt that noise , and i get air suction when i take oil dipstick out while engine is running , so i am guessing something is not right but dk what
Mar 23, 2010 | 2000 BMW 3 Series
Ryobi petrol weed eater
SOUNDS LIKE YOU MAY NEED TO REPLACE THE FULE LINES THAY DO GET BAD OVER TIME
Dec 08, 2009 | Ryobi Garden
Steam coming out of vents and water runnind down inside of dash
Your heater core has corroded through. You need a new heater core. You may be able to get by temporarily, with bypassing the heater core hoses, located in the engine compartment. These hoses carry coolant heated from the engine, to the heater core. You remove the hoses from the core, and put a pipe in the middle, connecting the two hoses together using hose clamps.
Should there be a cool morning, or if you need the defroster, you won't have warm air. Just a temporary fix.
May 10, 2009 | Mitsubishi Cargo Cars & Trucks
Washer won't fill up
The problem is most likely your drain. If there is no air break at the drain,( a gap where the hose goes into the pipe so air can enter) Your water will siphon out of the machine. Also make sure your drain pipe is higher than the tub of your washer and you only want about 6 inches of the drain hose sticking into the pipe. If you have water coming back out of the pipe when the machine drains, you will need a plumber to clean the pipes or replumb the drain. New washers pump out faster than older ones did and they need a good drain to handle the flow.
Sep 26, 2007 | Maytag PAV2300 Top Load Washer
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
