Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Shut down tv will come on for 10 second then shuts down
  • mdjesus May 20, 2008
    my tv turned on fine but if you step ******* the floor the image goes off but the sound keeps working.. if you step ******* the floor again or hit the tv the images comes back on.. does anybody have any idea what kind of problem is this?
    THANKS
What is dry solder?
Posted on May 08, 2008
  • 68 Answers
I have this problem before and to fix this problem is to check for dry joints at the fly back pins which are the primary section of the fly back. these two bins that supplies the power to the HOT. good luck
Posted on May 03, 2008
  • Waleed Rishmawi
    Waleed Rishmawi Jul 16, 2008
    when putting any parts on the printed circuit you have to solder them with a soldering iron. seem like that joint need to be soldered again.
  • 975 Answers
If it shuts down but the indicator ON remains , then check the convergence IC , I beleive it starts with part num. STK-392 of something similar, the other option is to check for a DRY SOLDER somewhere around the POWER SUPPLY.hope this helps
Tv shuts off after 10 seconds
one of the energy cables is damaged, so tv 'safety protcol' turns on, not to burn shuts off.
go to service
Apr 18, 2013 | Sylvania 6427TE 27" TV
How do I access RCA HDTV D52W23 Service Menu?
Shut unit off. Wait 10 to 15 seconds then press and hold volume down and channel down together for 10 to 15 seconds. This will get you into the service menu.
Apr 07, 2010 | RCA D52W23 52" HDTV CRT TV
Lc-13av4u Shuts down 10 seconds
some projection tv's will do this if you do not touch another button within 10 seconds. Power your tv on then change the volume or channel. This should let your tv know that it was not an accidental power on. Hope this helps.
Sep 11, 2008 | Sharp Televison & Video
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Samsung 56" shuts off after 5 or 10 seconds see a checker board image before shutoff
When the set shuts down you need to see what lights are blinking. For example: Timer/ Temp/ lamp on the front panel. You should also count the number of times they blink and the sequence. Most DLP`s give an error code alerting the technician to check the balast, lamp, or fan etc. for malfunctions. Unfortunately I can not tell you exactly what is wrong given the current information. Howrver, the last Samsung I repaired for shutting down had a bad light engine.
Nov 29, 2007 | Samsung DLP HL-P5663W 56" TV
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
I just took my Mitsubishi WS-65315 65" in to be repaired for the same problem and was told that it needed a new main circuit board part number 930b899005 as was told they wanted to charge me $1100.00. So I told them not to do the repair and picked up my tv and found that same part at Sears parts for only $225.00. Some of these TV repair places are theifs.
May 10, 2007 | Mitsubishi WS-48315 48" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
80 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
