Toshiba Regza a3030d series only 2 anologue channels work channel 4 and bbc2 the tv swithes itself on and off no dtv channels present unable to access the digital menu to auto tune the set... no picture just a blue screen.Using and external ariel also tried an internal one as well. Regards Joe
SOURCE: Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
Posted on Dec 30, 2007
SOURCE: DTV locked on ITV1
do a reset in the service menu the turn the tv off and press..
info>menu>mute>power on
and go to the reset option. don't mess with any other setting in this engineer menu.
Posted on Apr 16, 2008
  • 103 Answers
SOURCE: Missing Channels
I have found that for some reason bbc brodcasts are not transmitted in hd,either on sat or cable
Posted on Apr 26, 2008
SOURCE: how to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Posted on Jan 30, 2009
  • 6 Answers
SOURCE: no digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Posted on Oct 05, 2009
I am unable to get any channels on 2 portable tv,s in the bedrooms since the digital switchover are my tv,s now defunct and do i need to buy new ones ??
The 2 portable tvs,dose it have a big bulky back?Yes,than these 2 tvs are analoge tvs.U still can use them though for DTV free air channels broadcasting by running it throught a box called a Ditgital Coverter Box.These Digital Coveter boxes u still can buy them on websites like Amazon.com,Ebay.com to used for analoge tvs wanted to pickup free air DTV channels broadcasting.
Sep 03, 2011 | Toshiba 19AV600U TV
Toshiba 19DV500 b will only pick up BBC1, BBC2, ITV, C4, C5 no freeview channels. there is no reset or reinstallation options
Hi, sounds like you are in Analouge mode and not in DTV mode so you can't access the DTV menu to tune in the tv.
Press the 'SOURCE' button and move to DTV using the arrow keys, then press ok and if channels aren't already tuned you will now be able to tune them by accessing the DTV menu by pressing the 'MENU' key on the remote control.
If you don't have the manual you can download it or view it by clicking ----> HERE
Hope this helps.
Feb 09, 2011 | Toshiba Televison & Video
Cant get freeview
go to menu put it on dtv scan channels/if not its aerial
Apr 18, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba 42 lcd cannot delete channels I use the manual channel set and select Not Viewable for channels I don't want to see. Then as I click through the channels, the deleted channels show up again.
Also have a 42" Toshiba and had the same problem, then had issues moving the channel order while some channels were set to skip.
What I ended up doing was retuning the tv. Then went through the channel list (Menu -> Setup -> DTV Setting -> Channels) and changed the number of the channels I didn't want to 1000+ (using the red button, ie 1001, 1002, 1003...). This in itself does not change the channel order, but when I then move these channels to the end of the channel list and because they are numbered numerically I can be sure I don't miss any.
Next I went to the channel options (Menu -> Setup -> DTV Setting -> Channel Options) and marked all the channels I'd moved to the end of the list as channels to skip and locked. This does not remove the channels from the EPG but it does move them to the end of the list and when scrolling with the channel +/- buttons these channels will not be selected.
Ideally I would also like to delete channels such as QVC etc altogether and would love to know if anyone has a more effective solution to this issue.
Aug 15, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
When i turn my toshiba regza on I cannot access DTV all I get is a black screen. when i press the menu setup button this comes on for about a second then goes off again to a black screen. I can still use...
Try either the "content / menu" button between the volume and programme buttons. Failing that, when the tv has been powered up from the wall socket wait untill you hear a small click from the t.v (usually about 5 or so seconds after it has been switched on) before switching it on from the remote control, have no idea why this works but the dtv has worked for me ever since I powered the tv up like that
Jul 17, 2009 | Toshiba REGZA 47HL167 TV
Trouble tuning in empty dtv channels
Just go to the main settings. You will see an "autoprogram" option. Select this and it will scan all available channels and delete non-airing channels
Jun 22, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Cannot find freeview/digital on our new TV
You can only get the freeview / digital channels through cable by subscribing to a package which includes them. They will then supply the necessary decoder to get the channels. Otherwise you will need a digital aerial and a freeview box if you tv is not dtv ready.
Jan 03, 2009 | Televison & Video
Cant get dtv on my toshiba regza
Does it work with a DVD or VCR?
How is it connected? With a Coax cable or a an RCA component cable? Check that the correct video source is selected (The one associated with the input you are connected with) or that you are tuned to the correct channel on the TV if you are using the coaxial cable to connect. Could be channel 3 or 4 but I have seen them set for channels like 73.
Missing Channels
Feb 17, 2008 | Sharp LC-26DA5 26 in. HDTV-Ready LCD...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
