Question about HP Deskjet F4180 All-in-One InkJet Printer
When i turn printer on it says remove black ink cartridge and put back in. then it says refer to manual
    Problem Solver:
  • 6 Answers
You normaly get this message when the cartridge in not seated properly.reseating normally means just removing the cartrige & reinstalling it correctly.When it says refer to manual it just means if you dont know how to do it refering to the manual shows you how
Posted on Aug 21, 2010
How do i put in ink on 926 dell photo scanner and copier
From the online manual...
1. Turn on your printer.
2.Lift the printer unit, and then position the scanner support between the tabs to hold it open.
3.The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4.Press down on the ink cartridge lever to raise each ink cartridge lid.
5.Remove the old ink cartridges.
6.Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
9. Snap each lid closed.
10. Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
Manual can be downloaded here.
Oct 30, 2012 | Dell 926 All-In-One InkJet Printer
Cartridge error,refer to devise documentation to troubleshoot
Hello
Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, move on
Remove the cartridge and use a clean, lint-free, dry cloth to gently wipe the contacts.
Wipe from the top of the contact to the bottom. Do this for each contact.
Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
Turn on the HP printer, open the cover and remove both the black and color cartridge. Close the cover.
Remove the power cord from the outlet and disconnect the cables running to the computer and/or router. Wait one minute, and then plug in the power cord and then the cables.
Open the cover and install the black and color ink cartridges. Turn the printer on.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, you will need to buy new ink cartridges. Office Max or Wal-Mart have ink cartridges for almost every model of HP Deskjet, Photosmart and Officejet printers.
Jun 10, 2011 | HP Officejet 5610 All-In-One InkJet...
I have a Dell Photo926 printer. I just changed the color ink cartridge and it is giving me an alignment error stating remove tape from cartridge. There is not any tape on the cartridge. I have ran the...
Are you using Dell Series 9 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 9 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 9 color cartridge.
You are using Dell Series 9 ink cartridges, correct?
Dell Series 9 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 9 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
Black cartridge = black side(left side) Color cartridge = color side(right side)
Photo cartridge = black side(left side) Color cartridge = color side(right side)
It is possible to get a Dell Series 9 cartridge with a bad sensor. Contact the place of purchase for a replacement.
Rick
Apr 26, 2011 | Dell 926 All-In-One InkJet Printer
How do you replace the ink cartride in a hp 2175 all in one printer
1. Prepare the replacement cartridge by pressing down and back on the top of the protective plastic, then sliding the cartridge out.
2. Set both the cartridge and empty cartridge protector aside.
3. Turn on your printer and lift the access door until it locks into place. The print carriage will move to the center.
4. Once the print carriage has stopped moving, raise the latch to release the empty cartridge. 5. Remove the empty cartridge by pulling towards you. If you are replacing the tri-color cartridge and need to remove the black ink cartridge temporarily, use the empty cartridge protector to hold it. 6. Hold the replacement cartridge by the sides and remove the black plastic tape. 7. Insert the replacement cartridge into the appropriate slot (left for tri-color, right for black) until it snaps into place. 8. Pull the cartridge latch towards you and press down until it snaps into place. 9. Close the access door. -------
You may also download and refer to it's product manual :-
http://h10032.www1.hp.com/ctg/Manual/bpu73527.pdf
and
http://h10032.www1.hp.com/ctg/Manual/bpu73554.pdf
Sep 25, 2010 | HP PSC 2175 All-In-One InkJet Printer
I have a lenmarx x5150 printer and have no manual with instructions.How do I use it and replace ink?
  • Press the "Power" button to turn on your Lexmark
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color ink cartridge.
  • Step 4 Remove the new black ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black cartridge into the slot on the left side and push it down. Slide the color cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the cartridge until it clicks closed. Push the purple plastic cover down over the cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Nov 19, 2009 | Office Equipment & Supplies
Cartridge error: refer to device documentation to troubleshoot
remove the cartridges and clean the metal contacts with tissue paper and put it back. if the problem continues check the cartridges.
Nov 03, 2009 | HP Officejet 5610 All-In-One InkJet...
Cartridge Error, Error 50C
Hi there Error 50c
Dell gets this lots so have a try.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 02, 2009 | Dell A940 All-In-One InkJet Printer
Where is the black ink cartridge located. How to remove fr refill
Here is a link to the setup manual.
Go to page 3 and 4 for instructions for installing cartridges. (For removal, just reverse the process.) Make sure the printer is ON when replacing the cartridges.
PSC1510 Setup Guide
I am also giving you a link for the User guide below for reference.
PSC1510 User Guide
Replacement of cartridges is on Page 45 of the guide.
Save these for future use.
Jan 09, 2009 | HP PSC 1510 All-In-One InkJet Printer
Color Ink Cartridge Problem
Unplug the printer, and leave it unplugged for 5-10 minutes. Then if the printer is still complaining about the color cartridge when you turn it back on, then replace the print cartridge.
David
Dec 04, 2008 | HP Photosmart 2575 All-In-One InkJet...
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Deskjet F4180 All-in-One InkJet Printer Logo
Seeker5211
Seeker5211
