Question about Chicago Pneumatic Air Tools & Compressors
We are using 2 nos. of air compressors Model No. HX2T - 100 LP in our power plant please give us requirement of minimum quantity and quality of cooling water for each compressor. Regards, Lava Kumar Mech. Engineer. SRAAC Ltd., Kurnool. 9966210410
4 Suggested Answers
  • 4088 Answers
SOURCE: I have a model FP209501 Air Compressor 2 Gallon,
The spray gun consumes more air volume than the compressor can deliver. You can pause painting periodically to allow the compressor to 'catch-up' or buy a larger delivered-volume compressor. The compressor that you have was intended to supply air for pneumatic nailers and staplers in an intermittent fashion. Hope this helps!
Posted on Jan 18, 2010
compman66
  • 169 Answers
SOURCE: What horse power is required for producing 16.9
You are looking for about 5 H.P. to do that, but what is more important is the r.p.m. of the motor, the size of the pulley,,, and the size of the compressor pulley! most manufactures will spec the pump for certain horse power,,, they go hand in hand,,, for example you cannot take a pump designed for 5 H.P. and hook a 10 H.P. motor and a bigger pulley on it and spin the pump faster to make more air,,, it wont take that high of speed,,, I hope this helps.
Posted on Feb 25, 2010
  • 1383 Answers
SOURCE: hi, I have a 15 gal dewalt air compressor model
This model compessor has developed many problems all related to the unusually high cutoff pressure of 200psi. Most all single stage compressors cutoff at about 125- 140psi to keep amp draw to a minimum. Reduce the cutoff pressure as low as possible for job to extend the life of you unit. Locate pressure switch and remove cover to expose adjustment nut. There are generally two adjustments. One for pressure cutout and the other for differential. Sometimes instructions are under cover to switch. Good luck.
Posted on Aug 17, 2010
My newish SIP TN3/100D v twin compressor will not pump above 100psi !!??
100 psi is capable of running the gun
what the problem is the volume of air supplied to the gun
check the specification requiring the air usage for the gun against the volume supplied by the compressor
if you gun requires 20 c/ft of air /min and the compressor is only capable of 15c/ft of air /min, then the volume is too low so the pressure will not build up
modern impact 1/2 guns will operate quite well on 80 psi unless the gun is leaking internally
another point is this-- impact guns come in two configurations-- single hammer and double hammer
double hammer give 2 hits for each revolution of the air motor and there fore use less air to do the job
add the fact with 2 hammers , the torque applied is generally higher than single hammer units
the reality is this , the compressor capacity in c/ft/min should be 2 times that required or used by the tool
Sep 20, 2016 | Air Tools & Compressors
Craftsman air framing nailer model 351-183200/ after one nail has been shote plunger wont lift for the nail to be fired
This is usually low air pressure. The framing nailers need to have a minimum of about 90 pounds to work properly. I always run mine at 100. When using a too small compressor (such as the "pancake" compressors) and continuous firing they will do this after about six or seven shots. Once the compressor catches up they work fine again. Also make sure you put six or eight drops of gun oil in the air inlet each morning.
Jul 11, 2011 | Tools & Hardware - Others
I want to use a 120psi brad nail gun on a clarke ranger 115psi compressor ..will it be ok
It'll be perfectly fine. Wear safety glasses with them nail guns, they can really send a nail flying.
lp
Dec 29, 2010 | Clarke Power Products Clarke Pioneer 2 Hp...
Craftsman air compressor 2 hp 20 gallon, seems to running o.k. builds up to 100lbs shuts off when it hits 80lbs come back on, but when i run a tool , right around 90lbs the tool dies out and runs week.when...
IT depends on the tool. Some tools require higher cfm. (cubic feet per minute) of air. IF your air line is not large enough, then sometimes 90psi is not enough to operate a tool as there is a pressure drop at the tool. Look at the required cfm for each tool. Find a chart for air line size, cfm and pressure. Most impact wrenches should be used on a minimum 3/8" air hose. You could look at your manual and see what the max pressure is on your compressor. You may be able to decrease the differential pressure e.g off and 100 and on at 90, but then the compressor will cycle more frequently, and may exceed the duty rating of the compressor.
Oct 01, 2010 | Craftsman Air Tools & Compressors
I want to make a minor project in core java.....suggest me some new and different projet.....
Program 1
//Find Maximum of 2 nos.
Program 2
//Find Minimum of 2 nos. using conditional operator
/*Write a program to generate 5 Random nos. between 1 to 100, and it
should not follow with decimal point.
* Write a program to generate Harmonic Series.
Display Triangle as follow : BREAK DEMO.
and you can find projects from below link
http://www.freejavaguide.com/javasource3.htm
thanks
May 18, 2010 | Microsoft Windows XP Professional
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
2 gallons is small to begin with u need to buy an in line pressure adjuster/regulator their a few bucks and can be attached to the paint gun or line and will keep the pressure at ur adjustment the regulator on the tank sets the tank pressure at 50 so when u us it will let it drop down to about 45 than start up to build the pressure up to 50 than shuts off than repeats it self the inline keeps pressure steady even if tanks are at 200 psi
Jan 18, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
WE REQUIRED 02 NOS LAMP AND 01 NO. MAGNE TEK MODEL 3A49-03-100
sorry. the company that made that ballast no longer makes power supplies.
Jan 06, 2010 | InFocus LP 530 Multimedia Projector
Gas furnace
OIL WONT WORK IN THE PLACE OF LP OR VICE VERSA!
And correct You can addapt SOME burners to LP. Check with MFG to be sure. SOme Burners are dedicated to 1 fuel only IE LP only or NG only.
The LP has no regulator needed at the appliance it is regulated at the tank regulator, or on some 2 stage systems at the inlet to the building.
11" - 13" water column is the range for LP
If you cant find any MFG to answer your question take the name off the GAS valve you use and any model number on the gas valve and attempt to inquire form those numbers as to availability of lp change over. IF YOU DONT FIND ANY MFG OR INSTRUCTION MY ADVISE IS EITHER REPLACE THE VALVE WITH ONE THAT YOU KNOW IS APPROVED. A safety warning here is worth all the money because you cant save enough on the price of a new heater to replace any body and very few houses. Keep in mind that the spuds or orfices have to be changed also and some burners require reset of the Combustion Air inlet.
Dec 12, 2007 | GE AJCH10ACB Built-In Room Air Cool Unit
Air Tools & Compressors Logo
82 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
