Question about Garmin GPSMAP 298 GPS Receiver
My unit cannot find any satellites. I have had the problem before with periods of the unit not being used, but fixed it by deleting the stored settings and forcing the unit to download the latest almanac of sat positions It has been on for hours, and just doesnt seem able to find them now
2 Suggested Answers
SOURCE: Will not aquire satellites
I had this Problem and Disabled Bluetooth. So Far so good. Now finds the satellites.
Posted on May 27, 2008
I have a Garmin Nuvi 300 model and from last few days its not picking the satellite signals when I open the antenna, it keeps saying searching for satellitie signal. What could be problem & can it be...
Hello there,
As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes. If your unit has not been used for an extended period of time (more than a month), it may take 3-5 minutes to acquire satellites. If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal. If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased. If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions. If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites. If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*. If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Compatible Devices tab on the external antenna's page to see if your unit is listed.
Hope this was helpful to you. Goodluck Elect_Comp
Sep 01, 2011 | Garmin GPS
Toshiba satellite laptop won't wake up from hibernation even after holding power botton down?!
If pressing down and holding the restart/start button doesn't wake it up you might try Control + ALT + DELETE keys (together) - that will reboot it though. And if that won't work then you might have to pull the battery to reset it.
It seems that some laptops have a problem with vista and sleep mode, in particular, and sometimes hibernate too. You can try going under POWER OPTIONS under Control Panel and setting everything back to default, saving it, then resetting it again. Also it's best to avoid using sleep mode if possible to avoid problems.
If the problem developed after a recent install or updating you may need to go to an older store point to fix the problem. Personally, I just avoid using these settings as much as possible and use regular shut down and a screen saver for times when I need to step away from laptop for short periods of time.
Apr 27, 2011 | Toshiba Satellite Pro L300 Notebook
Hello, my nuvi 350 isn't locking onto a satellite signal. I have recently upgraded the maps, etc. and have tried resetting the defaults with no luck. it was not dropped, i was using it and it simply...
the only thing i can find is this I suggest you save all your way-points, then do the deed.
1. Turn the device OFF.
2. Place your fingertip or the eraser end of a pencil in the top right
corner of the touchscreen.
3. Apply pressure in the top right corner of the screen.
4. While pressing down on the screen, power ON the unit and continue
pressing on the screen. A message displays to confirm if you really want to
delete all user data?
5. Touch Yes.
6. The unit will now restart.
7. Follow the onscreen prompts to set up the nuvi.
Once the reset is complete, please place your unit in an area with clear view
of the sky until it acquires satellites. satellite codes are uselessly updated in firmware and work with the software but if the info is incomplete you will lose the satellites config settings. the codes are always updating. and most look for 15 satellites and then chooses the strongest 3-4-5 for pin point. but try this and see if it works but you need to save your data if you have it stored IE address. as it might delete them.
Jan 19, 2018 | Garmin nuvi 350 GPS Receiver
Slow on picking up satelite on nuvi 260w
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
*Note: Some units may not be compatible with an external antenna. Please check the Products tab on the external antenna's page to see if your unit is listed.
Good Luck. Did this help?
Dec 03, 2009 | Garmin nuvi 205W GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
Nuvi350 doesn't locate any satillites. What can I do?
Jul 11, 2009 | Garmin nuvi 260W GPS Receiver
Brought my NUVI from NY to San Francisco and it doesn't locate any satillites. What can I do?
Good Luck
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
Garmin Etrex Venture doesn't aquire satellites
I have an eTrex and you can reset the defaults which may help. I don't see any 'reset' operation in the manual other than Restore Defaults.
After switching on and letting the unit go through its initalisation press the button on the front (next to the etrex name) until you get to the main menu. Select Setup and press. Select System and press. Move the button to the left and press. Press the button again to restore defaults.
HTH
Peter
Mar 05, 2009 | Garmin eTrex Venture GPS Receiver
Garmin 260w won't acquire satellites
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
Hello i have the garmin 250 i had brought it on the water a few weeks ago and as soon as i got of the water it has a question mark and says aquiring satatiles but never picks up a signal and doesnt work...
Question: Why won't my unit acquire satellites?
--> Answer: There are a several different factors that can cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it is normal for it to take a while to establish its initial position.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take longer than normal to acquire.
  • If your unit has traveled a long distance while turned off or not tracking your travel, it may take a longer period of time to acquire.
  • If your unit has not been used for an extended period of time, it may take a longer period of time to acquire.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, you may need an external antenna.
If your unit is not acquiring satellites, it is recommended that you place the unit in a stationary position where it has a clear view of the sky. In some cases it may be necessary to take the unit outside of your vehicle as certain vehicles inhibit the unit from acquiring satellites. As the unit receives signal from the satellites, it will begin to lock on to them individually until it has acquired enough information to establish your position.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software. You can do this using our WebUpdater program which can be found at the following link:
http://www.garmin.com/products/webupdater/howtoinstall.jsp
Sep 25, 2008 | GPS
Garmin GPSMAP  298 GPS Receiver Logo
88 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
