Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Replacing the on/off switch on Dyson DC07. After the switch retaining screw is removed, how is the switch removed? Does it just pull out or are there retaining tabs ?
  • Dyson Master
  • 378 Answers
Have a look at www.dysonmedic.com which has some great info on your machine
Posted on Aug 21, 2010
How to replace the cord in dyson's dc07
Things You Will Need
  • Dyson DC07 power cord
  • T15 Torx-bit screwdriver
  • Small can
  • Camera or cell phone with camera
  • Flat-head screwdriver, 3/4-inch or smaller
  • Needle-nose pliers
Tips
  • Do detach the black wire that goes to the motor as it does not require removal.
Warnings
  • Do not work on the power cord when it is plugged in.
  • Do not force the plastic-covered connectors from the switch or you could break the male ends. Pull them off firmly but gently to avoid breaking the terminals.
  • Do not apply too much force to the plastic arms that hold the housing in place. The plastic arms are fragile and may break easily.
References
1 - Unwrap the power cord from the Dyson DC07. Detach the handle of the vacuum cleaner by pressing the release button. Pull the handle from the hose. Slide the hose down the wand and push the button at the bottom to release the hose from the machine.
2 - Press the button at the top of the dust bin handle to remove the canister bin assembly from the Dyson DC07.
3 - Lay the machine on with its back with the power switch facing upward. Locate the Torx screw directly beneath the switch actuator. Remove the Torx screw, turning it counterclockwise. Place the screw into a small can so you do not lose it.
4 - Remove the switch box housing held in place by the Torx screw just removed. Carefully pry upward on the two plastic arms that clip the housing in place. Take a picture with your cellphone or camera of the open housing to make it easier to reinstall the wires where they belong in the channels and spaces provided.
5 - Center the needle-nose pliers on the female connectors from the power cord attached to the switch. Apply equal force to pull them from the male ends of the switch. Also detach the two wires that connect together within the housing, identified by the clear plastic connector between them. Depending on your machine\'s manufacture date, the wires might have different colors. For example, they may be white and brown, all white or one could be blue. Disconnect a total of four wires -- two from the switch and the two connected together. Leave the other wires alone.
6 - Trace the electrical cord on the machine until you reach its protective cover where it enters the Dyson DC07. Lift up the cord protector to remove it from the vacuum. The cord protector has slotted sides that fit within the plastic. Slide the cord protector from the power cord.
7 - Remove the plastic covers that protect the female ends on the power-cord wires that connect to the switch. The new power cord does not come with these. Insert the tip of the flat-head screwdriver through the top of the plastic connector with two internal ridges. Lift upward and away to pull the wire free from the connector. Repeat for the other wire. Push the female end into the plastic connector until it snaps into place. Repeat for the other power-cord wire.
8 - Thread the new power cord through the cord protector. If you have trouble pushing the wires through, reach in with the needle-nose pliers to pull both wires through the rubber protector.
9 - Reconnect the two separated wires back together by inserting the male end into the female end of the other wire. Reconnect the two wires from the power cord to the switch. Reinstall the switch housing on the machine. Align the wires in the channels provided to keep them from being pinched or pulled out when you reassemble the housing. Look at the photo you took earlier as a guide, if necessary. Insert the wire that goes to the motor in this channel and the white wires connected together to the left of the switch in the area provided.
10 - Put on the switch housing cover and secure it with the screw you removed earlier. Reassemble the vacuum in the reverse order you dismantled it.
Aug 27, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
Repair manual dyson dc07
To replace the. Switch pull the handle out to remove the screws holding the switch cover on. Release the tabs to remove the cover to expose the switches.
Jun 29, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 main filter can it be removed to clean?
Yes, remove the dust bin and set it aside. Using a small screw driver gently pry on the lid that the dust bin sits on. you'll see little holes to insert a screw driver and pry back on the lid. Start on one side and pry at the three points to insert a screw driver and then remove the lid and replace the HEPA filter with a new one from EBay, local vacuum store, Dyson direct, etc. That filter is not washable.
May 20, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do you remove the electrical cord for a dyson
remove the cover right above the canister. there is a couple of screws in the front holding it in. i think they are T15 torx. that will give you access to your switches and your cord
Jan 02, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum has burning smell like a belt but cant figure out how to tear apart
First job is unscrew the 3 retainers (arrowed) they turn a quarter turn.
If your belt hasn't snapped it will need pulling off the motor shaft
The brushbar can now be pulled out (this brushroll had a groove scored into the side of it caused by a hair grip its visible just to the left of my thumb)
With the new belt positioned on the new brushroll insert it into the hole and locate brushroll
(To make the belt easier to locate on the motor shaft give it a bit of a stretch)
Ensure these lugs are located correctly
Pull the belt over the motor shaft
Refit the soleplate cover and tighten three screws
Before switching the machine back on rotate the brushroll to make sure the belt hasn't been trapped between the soleplate.
I hope this helps and good luck!
Nov 11, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do I replace the cord on my Dyson DC07 Animal vacuum?
To replace the cord, remove the screw on the front plate just above the on off switch. This is held on with tabs, so carefully use a butter knife or screwdriver to pry the plate off. Once the plate is off, remove the slide in tabe from the white plastic protectors and remove them. Slide the tabs of the new cord into the protectors and then push the protectors back on the vacuum tabs. Replace the plate and screw. NOTE: I did test the vacuum to make sure it would turn on before replacing the plate and screws.
GOOD LUCK! Sheila
Oct 19, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater bar will not engage. belt ok, cannot find a clutch, what else?
One possible problem could be a worn clutch. I just had the same problem. Before buying a new clutch assembly, I took the out the clutch just to make sure I could do it (the link previously mentioned is great: http://www.dysonmedic.com/DC07%20Folder/DC07%20Clutch%20replacement.html). In the process, I also opened the clutch at the wide end (two screws and a little retaining clip on the side - can watch a video as to how to disassemble the clutch here: http://www.ezvacuum.com/dyson-dc04-dc07-and-dc14-belt-pack-for-clutch-system-90251401-2-pack-p-2196.html?currency=USD). In the "lid" you will see a little black plate (looks like the same material that a car breakpad is made out of). If the clutch is the problem this plate will look a little worn down. It can be removed and flipped over. You'll get a few more years out of it. Of course, when the second side wears out, you'll have to get a new clutch (but by then maybe the the entire vac will need replacing anyway). Saved myself $40. Enjoy.
May 08, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
103 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
