Question about Dyson DC04 HEPA Bagless Upright Cyclonic Vacuum
How do I remove plastic cover plate over the switch assembly within a dc04?
  • Dyson Master
  • 379 Answers
Have a look at www.dysonmedic.com which has some great info on your machine.
Posted on Aug 21, 2010
How can i remove a switch cover to a dyson dc04
Hi, it's Cindy from Crucial Vacuum.
It is possible to replace the DC04 switch. Unplug your vacuum and remove the cyclonic assembly on your vacuum. Using a screwdriver, unscrew the switch cover. You may need to shimmy the switch cover off then the old switch is easily removed from its connectors and the new switch can be connected. Screw the cover back on and place the cyclonic assembly on and your done!
You can purchase direct your replacement switch from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/dyson-dc07-dc14-on-off-switch.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 26, 2014 | Dyson DC18 all floors Bagless Upright...
Dc04 on off button
This video will give you full instructions how to remove switch to change cable
and here are pictureshttp://www.dysonmedic.com/DC04%20Folder/DC04%20Cable.html
Dec 12, 2012 | Dyson DC04 HEPA Bagless Upright Cyclonic...
The lever came off (drive/neutral)
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items
Feb 06, 2011 | Kirby Ultimate G Bagged Upright Vacuum
HOW DO YOU REMOVE THE DYSON04 SWITCH
Dyson sell a bent screwdriver.....
.... to make it easier to remove the switch cover:
I have used an ordinary screwdriver pushed into the tiny gap between the flat side of the switch cover (see picture above) to force the 'tooth' away from its housing, and then pull cover off.
Underneath is a torx-headed screw, which when removed allows withdrawal of the switch assembly.
Jul 28, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
I have a Dyson DC04 which is making a strong burning smell within a few seconds of switching on. Is this likely to be the motor and if so can it be replaced?
More likely it is the beater brush which is jammed and not turning. Turn the machine over and remove the bottom plate. Unhook the drive belt, then try to turn the beater brush--it is likely bound up with string, thread, and hair. Try turning the machine on once--if the motor spins and makes vacuum, it is probably ok. Remove the brush assembly and clean it of debris. Clean the end bearings with a Q tip and WD40 oil, then wipe clean with another Q tip. Oil the bearings with 3-1 or other light oil. Check the belt for a badly burned area--replace if necessary. Slide the new belt over the brush and motor shaft, then drop the brush with bearings into the case, and check rotation. If ok, replace the plate and test on your floor. Hope this helps!
May 16, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
My belt has snaped on my dyson dc04 that has a clutch how do i change it
Remove the roller brush cover plate that is on the bottom and you will be able to access the belts. Here are the belts you need:
Dyson DC04 Belts
Nov 18, 2009 | Vacuums
DYSON DC04 how to remove switch housing to check
its most likely not the switch, check the power cord.. check where the cord meets to the vacuum. the cord could be going bad and most likely not a loose wire.
Sep 10, 2009 | Vacuums
How do I replace the microswitch in my dyson DC04 Zorbster
Move the flexible hose at the rear out off the way and you will see a small hole that goes through to the on/off switch assembly. Use a small screwdriver through the hole to push the plastic clip away and you can then lift off the on/off button. You will then see a phillips screw that holds the switch assembly/housing to the main unit. Just unscrew and the whole switch unit can be removed.
Apr 24, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson vacuum cleaner DC04
I would suggest you invert the vacuum and remove the plate covering the spinning brush assembly. You should check the belt located on one side of the spinner brush to see if it is worn or broken. Also remove anything wrapped around the brush that could be affecting it. Ensure the brush is free to rotate and seated correctly. If the belt is worn or broken, or the spinner brush is unable to spin, replacements are available from a licenced repair facility. I hope it helps! Good Luck!
Jan 29, 2008 | Vacuums
Dyson DC04 HEPA Bagless Upright Cyclonic Vacuum Logo
89 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
