Question about Lexmark X5470 All-In-One InkJet Printer
I cant set up my lexmark x5490 to send faxes. it give me phone line error with every attempt. how can i solve this prob?
I had a similar issue. my problem was a faulty dsl filter might be worth checking out, it wont run without one
Posted on Oct 15, 2008
Thnks for the reply. i am with talk talk and when i called them they said they dont have customer support or advice for fax.
Posted on May 17, 2008
    Genius:
  • 2,035 Answers
First check the fax line by telephone company and then try to send a fax..
Posted on May 13, 2008
My lexmark x5490 is a heap of ****! i will never buy lexmark again! Until then, can someone help me with this problem. I have tried to do a master reset by goingot original settings but when i change...
Forget your lexmark. Reason: Lexmark have very frequently many problems because industry programming all hardwares in printer for one use.After that you need Lexmark official service or buy new.
May 25, 2011 | Office Equipment & Supplies
My fax machine is not sending faxes but will recieve faxes it copies the pages to send then dials but once it connects it drops the call and gives a error message on the screen then tries to redial a...
Reset all settings of fax to factory defaults.
For that press menu button of printer and enter in fax settings reset all settings to defaults.
Then restart printer.
Also change phone line cable Then check.
My chat session is disconnected because of power failure .
Let me know if you need further assistance.Thanks.
Nov 20, 2009 | Lexmark X8350 All-In-One InkJet Printer
Lemark 5400 can't faxor rec fax give phon lone error message
If u have DSL modem ..u need to have a splitter for the fone line.....and then....the connections need to be right...
Phone line to splitter -splitter to Fax mech(Line Jack)...
Problem Receiving--
Make sure ur answering Mech rings are set more than the fax mech...i.e (if ur answering mech is set to 3 then fax mech should be set to 4)....
If u r using DRPD(distingtive ring pattern i.e If u have one line and two numbers.....) then set double ring for fax and single for Phone or answering mech....or vice versa...
Jun 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
I have a Lexmark All-in-one X5490. Color Cartridge replacement request
Printable Version print_friendly.gif null.gif null.gif null.gif null.gif How to Clear the Memory on the Lexmark X4250 / X4270 ID:ENUS13874 null.gif null.gif null.gif
  1. Disconnect the power cable from the back of the printer.
  2. Hold down the Stop/Clear button.
  3. While keeping the button pressed down, reconnect the power cable. A message on the LCD will display MEMORY CLEARING.
    Note: The Fax, Copy and Scan buttons will remain ON until the message disappears. Only the Fax button should be ON when the function is complete.
  4. Select the personal settings you require as follows:
    LANGUAGE? Press the right arrow key to select the language you want to use, and then press Select.
    COUNTRY CODE: Press the right arrow key to select the country you will be using the printer in, and press Select.
    ENTER DATE: Using the date format dd/mm/yy (in the USA, mm/dd/yy), press Select.
    ENTER TIME: Using the format hh:mm, press Select.
    Select Format: Press the appropriate number to choose between 1=12hr, 2=24hr.
PERSONALIZE FAX: Press Select.
Enter Name: Type in the name and press Select.
Enter Fax Number: Type in the number of the phone line to which the printer will be connected, and then press Select.
Apr 18, 2008 | Lexmark X4270 All-In-One InkJet Printer
Comm error
are ur telephone lead in line socket of printer of back side.
Mar 01, 2008 | HP LaserJet 3055 All-In-One Printer
Lexmark 7350 all in one
Before you begin
To pinpoint the cause of the issue, please record answers to the following questions:
Can a fax be sent or received?
Can a fax be sent, but not received?
Has the fax function ever worked in the past?
Any error messages may also help to narrow down the cause of the issues.
Print out the following:
- a settings list to view the current fax settings
- a receive log if there are issues receiving faxes
- a send log if there are issues sending faxes
- an activity log if faxes cannot be sent or received.
Initial checks
If the fax option has worked in the past and does not do so now, check that the same connection is being used and that it still works.
Check to see if any configuration settings have been changed that could have affected the fax settings.
Faxes cannot be sent/received:
If you are using a digital line, you need an analog card, an ISDN adapter, or an ADSL filter in order to send faxes.
If a PBX is being used, an ISDN Adapter/ADSL filter will not be used as these are supplied within the system. (A PBX is normally used within a company to share a small number of public lines among a large number of private ones to save on cost.) For instructions on configuring the X6100 Series machine with a PBX, see How and When to Use the PBX Option.
Check the phone line (without the printer):
Test the line by connecting a phone directly into the phone port.
Check for a dialing tone.
If you cannot hear a dialing tone, try another phone cable. Once you can hear a dialing tone, you know that the phone port is live and working.
Make sure the RJ11 cable is not damaged.
Check that the printer is accessing the dialing tone correctly:
Press the Options button on the operator panel five times until ON HOOK DIAL is displayed.
Press Select. You should hear a dialing tone.
If you can't hear a dial tone, make sure that the speaker volume is set to High. (Go to Fax, press Options eight times until SPEAKER VOLUME is displayed, then use the plus or minus buttons to change the setting to HIGH. Press Select.)
If there is still no dial tone, unplug the power cable and the phone lead, then plug them back in and try again.
Faxes can be sent but not received:
Connect the Lexmark All-in-One directly to the phone port. IMPORTANT: Do NOT connect any phones to the EXT port.
Make sure the Fax receive mode is set to answer the fax after 3 rings. (Press the Fax button on the operator panel and then press Options three times until ANSWER FAX WHEN is displayed. Change the settings using the - or + buttons as appropriate.)
Faxes can be received but not sent:
Make sure that Country Code is set correctly:
Press the Fax button on the operator panel and then press Options 15 times until Advanced is displayed.
Press Select.
Press Options 13 times and then press the + or - button until the right country is displayed.
Press Select.
IMPORTANT! These tests must be carried out with NO EXTENSIONS, i.e. phones or answering machines, connected to the EXT port on the All-In-One.
Feb 15, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Sending Fax
set baud rate to 9600 or slow
set resolution to standard
set error correction mode (ECM) off
if fax has overseas mode turn it on
vonage can make changes to the line that could help, if your using a voice line with call waiting use *70 prior to the number to disable call waiting for that call
Dec 31, 2007 | Lexmark X125 All-In-One InkJet Printer
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Lexmark X5470 All-In-One InkJet Printer Logo
114 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
