Question about Nikon FE 35mm SLR Camera
Ive just loaded a film, following the instructions, shut the back and wanted to advance the film, but the lever wouldnt extend the full way, it only goes to the on position
  • kakima Aug 21, 2010
    Are you firing the shutter? You can only advance the film one frame at a time between shutter releases. The procedure is to c-o-c-k, shutter, c-o-c-k, shutter, etc... (sorry for the punctuation, but FixYa censors that word).
  • 3 Answers
For the FE try turning the speed dial to M90. Sometimes FEs get hung up when you try shooting at speeds of 1/500 or 1/1000. If you fire off a few without film at at those speeds it should free them up. You might have to keep turning back to M90 until it frees..
Not sure if the F3 can be cured the same way but try activating the manual shutter release (the little lever to the lower right of the lens.
Posted on Sep 05, 2010
I have the same problem with a Nikon F2, got it off my grandfather and its been in his attic for at least the last 10 years. I don't know if parts have seized up or if im doing something wrong. have put in new batteries, but film advance lever won't go past "on" position. have tried pressing shutter but it doesn't help. Also film winding knob will not lift up enough to load in a film! any solutions!?
Posted on Aug 21, 2010
I purchased a Nikon N60 used. The film will not automatcally load therefore not shoot
Please follow these instructions: 1. Open the camera back 2. Pull the film leader across the red film index mark (red line) 3. Check to ensure film is properly positioned with no slack, then close camera back 4. Fully depress shutter release button to advance to frame 1. Check the rewind lever if it turns counter clockwise when you depress the shutter release button.
Keep on trying this procedure until you get it right. Most of the time, the error is in not pulling the film leader enough to reach the red film index mark.
If you're still having a problem with this, the next best option is to have the camera checked by a competent camera technician.
Mar 25, 2011 | Nikon N60 35mm SLR Camera
I put the film in the camera and the knob wont turn when i advance the film. I don't know what to do.
If the knob on the left hand side of the top plate (as viewed from behind) does not rotate when you operate the film advance lever, then the film has not been loaded properly and has failed to engage onto the take up spool. It's a very common fault and even experienced photographers sometimes make the same error. The frame counter will advance every time the lever is wound on, it only counts the number of full lever actuations, not the actual amount of film which has been wound on. The rewind crank is the only reliable way of knowing that the film is actually advancing.
Open the back of the camera and re-thread the film leader onto the take up spool. Close the back and wind one frame with the lever, and then open the back again to check that you got it right. This may potentially waste one shot but it will reassure you that you got it right. Once you're familiar with your camera you won't have to do this any more as you'll be able to feel and hear when the film is loaded properly or not.
If this does not solve your problem then please add a comment and I'll offer further assistance. If I have solved your problem then please take a moment to rate my answer.
Mar 06, 2011 | Vivitar V3800N Zoom 35mm SLR Camera
I am trying to load the film into a nikon fm10 slr like the instruction book told me to and when I try to advance the film so it can get to the first frame, it won't do anything.
This is typical of having left the multiple exposure lever set to the on position. It's fairly easy to set it accidentally and it's the small supplementary lever on the outside (right- as viewed from behind) edge of the hub of the film advance lever. See page 11 of the user manual (free download here)
If this is not your problem, then please add a follow-up comment and I'll provide other options for you. But if I have fixed your problem then plea
Sep 10, 2010 | Nikon FM10 35mm SLR Camera
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
My x 370 wont transfer pictures onto the film? The camera looks like it's in good condition. The roles come out blank!
Film cameras directly expose film to light to produce an image: they do not "transfer pictures onto the film", but your phrase is a big clue as it suggests you've only used digital cameras in the past and so may have made a very simple mistake with film loading.
If the film is blank as in transparent, then the film has not been exposed. If it's completely dark then it's been over exposed.
I suspect you mean that the film is unexposed as it's by far the most common fault: cameras like the X-370 have completely manual film loading; the film has to be manually engaged onto the take-up sprockets before closing the back of the camera. After that, correct loading is confirmed by watching to ensure that the rewind crank (top left knob as viewed from rear) rotates every time the film winding lever is used. Note that the frame counter will advance even if the film isn't correctly loaded. Once the film is used up, the winding lever won't operate and the film must be rewound back into the cassette before opening the back of the camera. To do this, you press the recessed button on the underside of the camera and use the rewind crank to rewind the film until you can feel no more resistance at all.
You'll find full instructions on the Norman Butkus website where he's provided a downloadable .pdf manual for your camera for free download.
Hopefully this has solved your problem; if so all I ask in return is for you to rate my answer. If it hasn't, then please add a comment and I'll try to offer other solutions to your problem.
Oct 30, 2009 | Minolta X-370S 35mm SLR Camera
Nikon fm10 cannot get shuuter release button to depress or film advance lever to work. is there a lock on shutter release ?
The film lever is also a switch. If you had advanced the film lever, **** it outward a little. You will feel the detent click somewhat when doing so. Leave the lever outward and see if the shutter will work. The detent is for appling an closed circuit for the light meter. When the lever is fully pushed back in it shuts the power to the meter on off to conserve battery power
Oct 13, 2009 | Nikon FM10 35mm SLR Camera
Film Advance Lever and Shutter Curtain
If the film advance lever is "flopping" back and forth, the problem is most likely a jammed advance mechanism inside. The shutter is cocked *mechanically* and released the same way--no battery power is needed. One old trick you could try to release things is to push the rewind button on the bottom of the camera.*sometimes* it will free up the mechanism enough to unjam.
Sep 17, 2009 | Vivitar V3800N 35mm SLR Camera
Film advance lever goes back and forth putting no tension or movement inside the camera to advance the film. Was working fine, then after taking my last shot, lever is just sort of loose., couldnt load new...
first make sure the rewind button is not stuck down. open the back door and rotate the advance sprocket back and forth to release the button. if that did not work take the bottom cover off and check the white plastic gear near the take up shaft. if that gear broke it will have to be repaired by a camera repair person.
there are no new parts for this model so get a cost estimate first.
Jul 07, 2009 | Minolta X-370S 35mm SLR Camera
Blank Film Developing
It likely did not catch when it was first loaded, and as such never advanced through the camera. Open the back of the camera, with no film in it, then set the shutter speed to 1, advance the film advance lever and take a shot. You should see the shutter curtains open and then close a second later. Then advance the film lever again and watch to see that the sprockets are turning. If they are, then the camera is exposing and the mechanics are working properly to advance the film. Chances are it was just loaded incorrectly.
Dec 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Film advance lever.
Do you press the shutter button to release the lever for the next photo? That's how you advance the film from the exposure to light, when first insterting the film.
Sep 16, 2008 | Nikon FE 35mm SLR Camera
Nikon FE 35mm SLR Camera Logo
136 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
