Question about HP Pavilion F1703 17" LCD Monitor
Need help installing
I am unable to successfully install my LG L226WTQ monitor to my driver.
  • Frank  Fernandez
    Frank Fernandez May 11, 2010
    On what Operating System are you having this problem?
  • 558 Answers
Most people I have seen have to change the resolution in the display settings area of windows. after they do that the display will show properly without distortion
Posted on May 11, 2008
Monitor sleep problem
This type of problem is usually caused by a failure of the filter capacitors on the power supply board. The LG L204ws uses the AIP-0156 power supply which is the same board used in many of the LG monitors that were sold around the same time. Here is a link to a repair guide for the LG L226wtq model that used that board. The repair guide as pictures and videos showing how to open the unit and check the filter caps. There are parts lists showing what needs to be replaced too.
http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/
I hope this helps,
BuddyMc
Dec 01, 2012 | Computers & Internet
Desktop seem to be out of alinement and some of the applications are off the screen
sometimes it depends on your operating system (OS). for instance i have a LG L226WTQ and when I'm working with windows 7 this problem appears for me too but with windows XP not.
installing or using bad applications (harmful or incompatible) also can be the cause.
mostly video card (VGA) is the cause.
you should check your motherboard model and your VGA.
maybe they are incompatible each other.
Jan 03, 2011 | Acer AL1916W 19" LCD Monitor
I have an LG Flatron L226WTQ-SF and my monitor has some "shadowing". If you need more infos I can send you some pictures.
If you are using analog VGA cable, replace it with one that has ferrite rings near both ends. The best is to use DVI digital cable but this depends on the capabilities of the videocard and the monitor ofcource, but I think this monitor has DVI input.
Aug 05, 2010 | LG L226WTQ-BF Monitor
Lg Flatron L226wTQ, power button failing
This problem is usually caused by a failure in the power supply board which in turn is caused by a failure of the filter capacitors. We have a repair guide article posted on our web site at: http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/ Check out the article and then open your monitor up and look for the failed capacitors, replace them if found and you should be back going again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 16, 2010 | LG 22" FLATRON LCD Monitor
I need window 7 driver for a lg flatron monitor L226WTQ-SF Cheers
There is no need to install any driver for the monitor as the inbuilt drivers always work with all operating systems and windows 7 have thousands of drivers inbuilt.
Mar 05, 2010 | Computers & Internet
I have a l226wtq-sf monitor, is there a 64bit windows vista /7 driver?
L226WTQ monitor won't turn on after 3 min.
Hi, I have this model and defective as a power problem, so I ordered capacitor package to solder, but the board was a little different model with the posted picture. As my poor knowledge, defective caps look fat so easily identifying its problem, but they were looked good. Anyway I soldered 3 of them matched with the procedure, but it kept on for 3 min then had gone and never turned on. After a while, it could turn on for an other 3 min.
Please help me~~~!
Feb 18, 2010 | LG L226WTQ-BF Monitor
Monitor comes on at 30% regular brightness then fades to black over the next 1-2 seconds. Stays black. Does the same thing if I hook it up to another computer too.
The LG L226WTQ series has a bad habit of blowing out the power supply. We have a step by steprepair guide posted on our web site at: www.ccl-la.comIf you can solder then you should be able to do the repair. If youdon't want to do it we do offer a repair service for $30 plus returnshipping. let us know if you have any questions about the repair, youcan contact us at the address below.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 08, 2009 | LG L226WTQ-BF Monitor
Won't Turn On ,,,No Blue Or Orange Lights,,,Light Just Flickers
The LG L226WTQ-BF monitor series has a issue with the power board going out. We have a step by step repair guide posted on our web site at: www.ccl-la.com If you can solder then you should be able to do the repair. If you don't want to do it we do offer a repair service for $30 plus return shipping. let us know if you have any questions about the repair, you can contact us at the address below.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com HTML clipboard
Dec 03, 2009 | LG L226WTQ-BF Monitor
How do I install LG L1932TQ monitor drivers in XP Home service pack 3?
Hello there:
Providing that this is a new monitor, there should have been a installation cd that came with the monitor if not i would contact the manufacture or the place that u got it from and request a new cd.
if unable to do that you might be able to go to www.lg.com and get the driver from there. ok
best regards mike
Aug 17, 2009 | LG Computers & Internet
I am unable to make resolution 1024 x 768 in lg model 500G
If the monitor is somewhat old and the monitor hardware doesn't support 1024x768 resolution, installing a new driver won't help. You will have to switch to a better monitor.
Dec 21, 2008 | LG Studioworks 563N 15" CRT Monitor
HP Pavilion F1703 17" LCD Monitor Logo
99 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
