Hi. I have problem with my Electrolux EWF16589W. It stops during any program with error code E20. Checking with the manual what can be wrong, and clean the pump, and all the other things who can cause the errors. Nothing helps. Started the longest program without any clothes inn. Then it run all the program with no problem. After on wash with two small clothes, then new error E20. What can be wrong? It looks like the machine dont like strain. Is it necessary to reset the "brain" of the machine? Can anyone help?
  • Anne Bodil Hetland Aug 21, 2010
    We have check everything as you discribe, and no problems to find. Still no function. We called the technical support at the shop were we bought the washingmachine, and explained everything as it is, and he told thats a guarantee-case. So monday we will call directly to the technical support at Electrolux here in Norway. When we get the machine fixed we can also give you a feedback, if you want?
    friendly
    Anne Bodil
  • Anne Bodil Hetland Sep 26, 2010
    Hello again.
    Sorry I'm late with the update. Have some busy weeks for us here....
    The the service man came sept 2, and he changed the washing machine pump. And then everything was OK. He said the pump was broken. This is a warranty case.
    Now after 3 weeks with washing, we havent seen or heard any problems.
    Very saticfied.
    Anne
  • 10,319 Answers
The circuit board is at fault since you can run this normally with no clothing inside of it. The sensor relay built into the board is at fault
Posted on Aug 21, 2010
  • Washing Mach... Master
  • 19,396 Answers
Hi.
To reset the machine simply disconnect power for two minutes. If E20 is already coming back, that willl not help.
As you know E20 means lint filter full or outlet pipe blocked.
Ensure that you have already accessed the pump by removing kick panel, opening pump access, unscrewing the filter cap and removing filter.
If that does not work, next step is removing the filter.
If still no luck, the pump may need disassemblying to check the pump itself and the exit hose connected to the pump. At that point I would recommend calling a technician.
Check also the drain hose at the back of the machine.
Here parts potentially involved, filter may need replacement:
Washing Machine Pump Filter
Askoll Magnet Motor Pump
  • Ginko
    Ginko Aug 21, 2010
    Re:So monday we will call directly to the technical support at Electrolux
    Yes please, keep us updated.
    Many thanks.
  • Ginko
    Ginko Sep 26, 2010
    Hi.
    If there is no blockage, not even at the hose directly connected to the pump, then there is a fault.
    The brain (central control unit-CCU) rarely fails, and when it fails you usually get more than one problem. If drain and pump are OK, then the part to check is the pressure switch, that is the part sensing water level.
    If you called Electrolux they will probably send a technician to test parts on site.
    Having feedback on the repair will be interesting.
    Regards.
    Ginko.
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
Jul 19, 2012 | Electrolux EIFLW55HIW Front Load Washer...
I have a E=20 error code. Where do I start??
Try checking the filter is not blocked and that the pump can turn freely because E20 relates to a blockage.
Hope this helps.
Aug 26, 2010 | Electrolux EW1000i Front Load Washer
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
How can I reset my electrolux washing machine afer an E20 error?
turn the dial to off. Press and hold the start pause and the nearest option button. While you're holding them down, turn the dial one notch clockwise.
The machine will beep or flash, let go of the buttons. Release the buttons, then turn the dial slowly, stopping at each click until you get to "off". Now, turn to any setting, then turn to off.
Now, try the machine. If it works, I'm very happy. If not, perhaps someone else can help.
Good Luck
Apr 20, 2010 | Electrolux Washing Machines
Error code E20 electrolux washing machine EW1280F
• E10 = there is no water filling • E20 = the water is not drained • E40 = door open
Download Manual - http://laundry.manualsonline.com/manuals/mfg/electrolux/ew_1280f.html
Feb 04, 2010 | Electrolux Washing Machines
Electrolux EWF 1470 Error code E20
could be the element at fault or pressure chamber
Jan 12, 2010 | Washing Machines
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Electrolux W375E
if you go to electrolux laundry systems you will be able to download the operating manual for the W375N. all error codes are on this PDF doc..
Nov 26, 2007 | Washing Machines
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
1,766 people viewed this question
Top Washing Machines Experts
