I Have a Heatline Compact combination boiler That is noisy IE:- The diverter motor chatters.So I changed the diverter plunger With a new replacement kit.But it was still the same.So I bought a new diverter valve motor to no avail can anyone point me in the right direction
  • 3 more comments
  • jim_shep Aug 22, 2010
    Yes it is the same in hot water only & central heating
    In the water only mode the motor still chatters even though it is not calling for hot water
    Could it be a pressure sensor problem
    If I put my ear to the diverter motor it seems to be coming from there.If I turn the hot water on I get a continuos pressure noa a spluttering type ?
  • jim_shep Aug 23, 2010
    IHave Been asked to refer this problem to another expect as it was not his forte
  • jim_shep Aug 24, 2010
    Hi Kirk
    I replaced the the old parts the same as removed but asI dont have a schematic on the lay out
    I just assumed I was replacing like for like I dont suppose you have a diagram of the correct insallation of the repair kit so I can double check
  • jim_shep Aug 30, 2010
    yes
  • 2,019 Answers
Does it make noise in both modes, heater and hot water?
Is it the same at all heat settings?
Your problem may be due to hydro water flow switch.
Try putting 2 pieces of plastic pipes in the cold and hot feed pipes to reduce the transmission of the noise.
Also make sure your not putting more than 9 liters a min through the boiler
You may need to reduce water pressure.
If it is the heater function that is noisy, there may be something clogging the system, and it should be cleaned and back flushed.
Your water supply system may also need an air compression tank to reduce water hammer effects. Water has momentum and it is hard to stop flow quickly without a compressible chamber to absorb the kinetic energy.
Tell me more and I may be able to give a better answer.
Posted on Aug 22, 2010
  • 2 more comments
  • Kirk Augustin
    Kirk Augustin Aug 22, 2010
    If the motor chatters even when there is no water demand, then it seems to me the motor is running all the time, even after the valve is closed, as if it thinks it is still open.
    But I am not familiar enough with the exact system to be able to say if it is out of adjustment or if there is a sensor to give it feedback when it is supposed to be closed.
    When I try to look up the valve, I don't get much information.
    They suggest draining the heating loop, since that is closed normally and can build up sludge and contaminants that can block the normal diverter operation.
    http://www.akgas.co.uk/Heatline-Diverter...
    Sorry, this is not my specialty, and maybe someone else has more experience.
  • Kirk Augustin
    Kirk Augustin Aug 23, 2010
    You may want to copy all of the conversation so far into public space, since no one else can see the comments I have made so far.
    It may save a little time and stimulate ideas.
    For example, most of what I read says draining and flushing the heat loop is important, because sludge or debris can clog the valve and prevent it from closing all the way.
    This would give the exact symptoms you are getting.
    But since you already replaced the valve once, you should have seen the condition of the heat loop.
    Was it clean looking, or contaminated?
    Telling people that will make it easier for them to figure out the problem.
    By the way, are you sure you did not put the valve in backwards regarding any of the connections?
    That would also give the noise symptoms.
  • jim_shep Aug 29, 2010
    Hi Kirk
    Just to let you know that I have solved the problem.
    it seems that the spindle with the plunger repair kit was wrong I took the kit bck to suppliers who confirmed this fitted the new one
  • Kirk Augustin
    Kirk Augustin Aug 29, 2010
    Good to know you got it fixed.
2005 Toyota Corolla 1400 vvti. Replaced timing chain. Now, when it starts why is it very noisy?
If you have a lot of chatter coming from the timing cover area, it could mean that the chain guides were left loose or that the VVT actuator plunger was not released when re-installed or it may have jammed and is not able to keep tension on the chain.
Oct 02, 2015 | 2005 Toyota Corolla
Hetline sargon boiler manuals
my heatline sargon 35kw boiler is showing f1 fault i have drained boiler and cleaned out relivant peaces but still no change any advice in sorting this out
Dec 20, 2010 | Heating & Cooling
Hi. my heatline vizo 24 boiler not working
overheat stat or fan best of luck
Oct 13, 2009 | Water Heaters
Vaillant boiler - heating OK, but no hot water.
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Apr 13, 2009 | Air Purifiers
Hot water
there are two main faults with combi boilers not giving hot water. one is a faulty flow sensor, the other is the most common which is a blocked heat exchanger caused by debris and scale in the system. this needs to be flushed out or may require a new heat exchanger depending on the age and condition of the boiler some plumbers may suggest a new boiler.
Mar 02, 2009 | Water Heaters
Valient combi boiler is not heating the water properly
vailant boilers are one of the best on the market and should last you more than 6 years depending on installation and servicing.
the engineer you had should not have replaced the diverter valve if the boiler was firing up when the taps are opened. if you was getting luke warm water with the boiler alight it is a classic symptom of a blocked plate heat exchanger on the central heating side.
a new heat exchanger can cost around £100 depending on the age and model of the boiler.alteranatively it could be descaled but may clogg again. it would be a good ideal to fit a magna clean filter on the system to help prevent further debris if you have a dirty system .if you don't trust your engineer i suggest you ask another. find out if he is registered first and don't pay until you are satisfied with the work. if you are asking the same engineer back try and get a discount off the work as he has failed to rectifiy the original fault and fitted the wrong part due to wrong diagnostics. if he is registered you can complain to the governing body ie corgi or gas safe register.
good luck.
Jan 16, 2009 | Water Heaters
Heating & Cooling Logo
341 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
