Question about Microsoft Standard Wireless Optical Mouse
Left button problem
I now have to click really ******* the left button before it will function. The right button works fine. What is the problem and how can I fix ? thx
This problem of yours has a simple solution:just change the left push to on switch.desolder the original one, get a switch from the local electronic market of the same type(if possible OR another one which will b placed correctly on d pcb and which ensures that d click works)
The problem is that the spring in d switch has lost it's physical properties,which is a aging problem.
Solder the new switch,and there u go,click click click,all working fine.
Posted on May 31, 2008
The left click is not functioning, right click works just fine but left click has no response whatsoever.
Usually either the lever (button) has slipped out of it's pivot point, the spring has come out, or the switch below the button is broken. To check, look around the edges for a small screwdriver slot or small screw. Open the mouse. Look at the button to see how it pivots. If on opening there are small pieces of plastic, discard the mouse. if it has just slipped out of its spot, realign and close the mouse, it should be good to go.
Mar 22, 2015 | Logitech LX3 Optical Wired USB Mouse Grey
My left and right keys on my mouse has swapped functions, can i put right
go to start->settings->control panel and Double click on mouse icon and Uncheck switch primary and secondary buttons under Buttons tab. and Click apply and OK. now it will work fine
Jan 26, 2010 | Dell Latitude C600 Laptop Keyboard 47NVF
The left mouse button does not work on my IBM
Windows has the ability to swap mouse buttons, mainly for those who mouse left-handed. It looks to the right button for left button action. It seems that the actual left button is not functioning. A work-around is to use the right button as the left as you are now doing, AND, use the solid windows button (the one to the immediate left of the right control key) as the right button. Not as easy, but it works.
Jul 18, 2009 | Lenovo ThinkPad R51
Right click doesn't work
HI,
REALLY DEPENDS ON THE AGE OF THE MOUSE AND HOW OFTEN YOU USE THE RIGHT CLICK FEATURE. LIKE MYSELF I USE IT CONSTANTLY. UNFORTUNATLEY IF THE RIGHT CLICK NO LONGER FUNCTIONS AND YOU USE THE MOUSE ALOT LIKE ME THE MOUSE IS SIMILAR TO A KEYBOARD IN THAT IT HAS ONLY SO MANY TACTILE TOUCHES BEFORE IT HAS WORN ITSELF OUT. YOU CAN HOWEVER GO TO CONTROL PANEL IN YOUR OP SYSTEM UNDER MOUSE ETC AND DIAGNOSE A SOFTWARE INCOMPATIBILITY BY RECALIBRATING THE MOUSE. IF THIS DOES NOT WORK IT IS MOST LIKELY TIME FOR A NEW MOUSE.
GOOD LUCK, HOPE THIS HELPED!
Mar 30, 2009 | Computers & Internet
Right & left click buttons not working
hmm quite interesting
has your laptop suffered some damage
i recomend you try to disassemble your laptop and check the connector for the touchpad.
dont know how try this site:http://repair4laptop.org/disassembly_acer.html
Nov 30, 2008 | Toshiba Satellite A105 Notebook
Left click button on toshiba satellite broken
You can order a new top plate from EBay or Toshiba and replace it yourself or have it done professionally. The button itself it most likely fine, however the plastic that holds the plastic button over the actuator is broken and is actually fairly common occurrence.
Nov 07, 2008 | Acer Aspire 5610-4648 Notebook
Dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Sep 20, 2008 | Dell Latitude C610 Notebook
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
Microsoft Standard Wireless Optical Mouse Logo
262 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
