How to add a bluetooth in my computer - Computers & Internet
  • 838 Answers
Just connect the bluetooth device with your pc through USB...it will be automatically recognized....
Thanks
Posted on Aug 21, 2010
How do I make my hp officejet 100 discoverable
Extracted From the USER GUIDE (download here) http://h10032.www1.hp.com/ctg/Manual/c02648771.pdf
Set up the printer for Bluetooth communication
The printer allows you to print documents from
Bluetooth devices without a cable connection.
Simply print from a Bluetooth device such as a PDA or camera phone. You can also use Bluetooth technology to print from a computer to the printer.
Set up a Bluetooth wireless connection
This section describes how to set up and configure the device for a Bluetooth wireless connection.
You can configure Bluetooth wireless settings during software installation, or you can configure settings later using Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs
(Windows Mobile). For more information, see Printer management tools.
To connect the printer using Bluetooth communication (Windows)
NOTE:
If you are using an external Bluetooth adapter for your computer, specific instructions for adding the printer might be different. For more information, see the documentation or utility provided with the Bluetooth adapter.
1.
If you are using an external Bluetooth adapter for your computer, make sure your computer is started and then attach the Bluetooth adapter to a USB port on the computer.
If your computer has Bluetooth built in, just make sure the computer is started and that Bluetooth is turned on.
2.
On the Windows taskbar,
click Start
, click Control Panel
, click Hardware and Sound
, and then click Add a printer
- Or -
Click Start
, click Printer
or
Printers and Faxes, and then double-click the Add Printer icon
or click Add a printer
3.
Follow the onscreen instructions to finish the installation.
To connect the printer using Bluetooth communication (Mac OS X)
1.
2.
Click
System Preferences in the Dock, and then click Print & Fax
3.
Click + (Add).
4.
Select the entry for the printer in the list with Bluetooth beside its name, and then click Add
5.
Set Bluetooth security for the printer
You can enable the following printer security settings:
• Require passkey authentication prior to someone printing to the printer from a Bluetooth device.
• Make the printer visible or invisible to Bluetooth printers that are within range.
• To enable these settings, you can use Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs (Windows Mobile). For more information, see Printer management tools.
Set up the printer for Bluetooth communication 93
Use a passkey to authenticate Bluetooth devices
You can set the security level of the printer to either
High or Low
• Low : The printer does not require a passkey. Any Bluetooth device within range can print to it.
NOTE:
The default security setting is Low
. Low level security does not require authentication.
• High: The printer requires a passkey from the Bluetooth device before allowing the printer to send a print job to it.
NOTE:
The printer ships with a predefined passkey that is set to six zeroes "000000".
Set the printer to be visible or not visible to Bluetooth devices
You can set the printer to be either visible to Bluetooth devices (public) or not visible to any (private).
•Visible : Any Bluetooth device within range can print to the printer.
• Not visible : Only Bluetooth devices that have stor
ed the device address of the printer can print to it.
NOTE:
The printer ships with a default accessibility level of Visible
To reset to factory default settings
NOTE:
Using the following instructions will reset only the device's Bluetooth settings.
1. Press and hold down (Power button).
2. While holding down (Power button), press (Cancel button) 4 times, then press (Resume button) 6 times.
3.Release (Power button).
Sep 11, 2014 | HP Officejet 100 Mobile Inkjet Printer,...
How to enable bluetooth
Your computer has to have a bluetooth radio. You can check
Control Panel > System and Security > Device Manager
Do you see a Bluetooth Radio listed?
If not, you don't have BlueTooth on your computer so you will have to add a BlueTooth device by plugging one into a USB port.
If you have a BlueTooth radio, go to Control Panel > Hardware and Sound > Device and Printers > Add a Bluetooth Device
This option is used to connect a blue tooth device (e.g. bluetooth headphons) to your laptop through your bluetooth radio.
See this Windows web page for more information.
Set up Bluetooth enabled device
I will respond to any additional questions you have.
Aug 05, 2014 | Dell Inspiron Computers & Internet
Bluetooth connection issues
There are several things to try:
Remove and then reinstall the device:
Click the Start Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
Select the device that's not working, and then click Remove.
Click Add, press the reset button on the device
(or make it discoverable following the manufacturer's instructions), select the My device is set up and ready to be found check box, and then click Next.
If the device is not found, repeat the previous step.
When the device is found, select it, and then click Next.
Follow the rest of the instructions in the wizard.
Make sure the device is turned on and that the batteries don't need to be replaced.
Make sure the Bluetooth adapter for your computer is attached and turned on, and that the device is turned on and discoverable.
If you're not sure how to turn on discoverability, read the instructions that came with the device or check the manufacturer's website.
Make sure that you installed the device using the correct program. If not, reinstall the device.
For a printer, follow these steps:
Open the Add Printer wizard by clicking the Start Control Panel, clicking Hardware and Sound, clicking Printers, and then clicking Add a printer.
For a mobile phone, if you have Bluetooth wireless technology installed on your computer, use the Add Bluetooth Device Wizard. To do so, follow these steps:
Click Add.
For a keyboard or mouse, if you have Bluetooth wireless technology installed on your computer, use the Add Bluetooth Device Wizard. To do so, follow these steps:
Connect a wired keyboard or mouse to your computer.
Click Add.
The device might be out of range of your computer, or too close.
Try moving it closer or a little farther from your computer.
hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetoothview/3000-2648_4-10800572.html
Runs in the background, and monitors the activity of Bluetooth devices around you
Oct 06, 2012 | HP Pavilion dv8000z Notebook
How to activite bluetooth in windows 7
  1. Add a Bluetooth adapter to your computer.
    This is usually done by plugging the adapter into a USB port. (If a Bluetooth adapter is already built in or attached to your computer, ignore this step.)
  2. Set up the device so that your computer can find it.
    To do this, you must:
    • Turn the device on.
    • Make it discoverable.
    To learn how to make a device discoverable, check the information that came with your device or go to the manufacturer's website.
  3. Install the device.
    To install most devices, such as a mobile phone, keyboard, mouse, or personal digital assistant (PDA), you can use Bluetooth Devices in Control Panel. If you have Bluetooth wireless technology installed on your computer, follow these steps:
    To install a Bluetooth enabled device
    1. Click the Start button , click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
    2. Click Add, and then follow the instructions.
May 30, 2011 | Computers & Internet
Is it possible to install a bluetooth device on a computer apart from usb
If you have a laptop computer, then the only way to add Bluetooth is with a USB adapter. There isn't any other place to add anything. On a desktop machine, you can install an internal Bluetooth card in an open PCI expansion slot on the motherboard or use a USB adapter.
May 17, 2011 | Compaq Computers & Internet
How do I get my pics from my phone memory to the card so i can download them or how can I donwload the photos from my phone memory?
You could send the pictures from the phone to your computer through Bluetooth. If your computer doesn't have Bluetooth you can add it a dollar.
USB Bluetooth module:http://cgi.ebay.com/Wireless-USB-2-0-Tiny-Bluetooth-V2-0-EDR-Dongle-Adapter-/250636804218?pt=LH_DefaultDomain_0&hash=item3a5b1e207a#ht_3769wt_952
Once your computer has Bluetooth, just add the phone to the computer's "Bluetooth devices" and then from the phone select all the pictures, hit menu, and select send to Bluetooth, then select your computer.
Oct 14, 2010 | Motorola Mobility i880 Cellular Phone
I can't connect my Samsung Jet with my PC via Bluetooth. What am I doing wrong?
to connect your samsung phone to a pc via bluetooth you need to follow the steps.
1. install your samsung pc suite NPS,
2. open your phone bluetooth.
>> go to menu, select bluetooth, select settings under bluetooth, make your phone bluetooth's visible,
3. go to your computer, open your bluetooth, right click the bluetooth icon on the system tray, they are grouped and can be located near the clock.
4. select settings for your computer's bluetooth, make it discoverable, check the discover services.
5. under the computer's bluetooth panel, you can see there add device, click add device.
6. once the computer search for your phone, pair them with passcode like 1234, or 0-9 digits, it's up to you to assign the passcode but make sure they will be having the same passcode. ( both computer and phone).
once paired you can see them there in your phone's bluetooth panel, your computer and your phone together.
>>to check if successful connection was achieved, select a file from your computer, right click and send to your phone.
>>do the same thing for your computer, select a file from the phone and send it to your computer, but you need to confirm that your computer will be receiving a file from a paired bluetooth, by clicking the balloon
message at downright corner of your computer where your bluetooth is located.
regards...
Mar 02, 2010 | Samsung Jet S8000 Cell Phone
Install bluetooth peripheral device
Hi, if you haven't tried the Bluetooth ("Wizard") to install the device? Go to the "Start Search" window, Type: Bluetooth, the Icon appear, select to open. In the "Views (column) there will be "Add Wireless Device" and "Bluetooth Settings," add the device to be identified; if not present, and (Setup / Install) the device. Restart the computer when finished! If this did not "fix" the problem?, go back to search: Type: Sony, "if a Sony Application Installer appear in the seach?" select to open, and in the (Bluetooth Device), and restart the computer to finish! " If the solution helped? Rating it is appreciated, thanks."
Feb 28, 2010 | Sony Computers & Internet
How can i connect my bluetooth to my pc?
on pc side
1. give your host bt name
2. find bt COM port
My Computer->My Bluetooth Places->right click my device->Local Services->Bluetooth Serial Port
on phone side
1. give your phone bt name
then install pc suite and modem tool (if necessary)
restart computer
pairing
1. add device
host: go to My Bluetooth Places->Add new connection
phone: go to bluetooth, choose Paired Devices->add
2. provide passkey (4-digit, 0-9 only) on both
Check mRouter
check bt COM port that you found
Start bt serial
if you see mRouter turns green and blue, you got it
start pc suite
Oct 19, 2009 | Nokia 5000 Cellular Phone
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
