Question about Kodak EasyShare M883 Digital Camera
My Kodak Easyshare M883 camera wont stay on. I turn it on and it makes a buzzing sound then turns off. It cant be because of the battery because I have full battery. So what is the problem and how can I solve it? Please and thank you!
  • Kodak Master
  • 17,130 Answers
The camera is shutting off because on start up there is an error on the main controller . Remove the battery and if possibel check if the current capacity of the battery is good enough. Most often the voltage will be shown but the current (Ah) will be less. So use a load to check if possible or try on a similar camera just to make sure. Remove the memory card , check for virus , format and reset.
Try the battery back, if fault recurrs then you will have to open to check if the electronic board is not getting the correct data on switch on but has some errors -- possible load factors in circuit- to switch off.
Might have to disconnect flash unit to check, if not the lens or shutter drive could be faulty.
hope this helps.
Posted on Aug 21, 2010
Cara memperbaiki kamera kodak easyshare m883 yang mati sendiri
check battery of the camera if is okay unless you have a damaged battery, or the push button swich if stuck or damaged.
Jul 01, 2016 | Kodak Easyshare M883 8.0 Mp Digital Camera...
When i try turn on my camera it makes a buzzing noise, as if its trying to turn on but the lens does not come out any solutions?
Check to see if the retractable dust covers on the lense, if one of or both are knock out of there track that they slide in.
Mar 01, 2012 | Kodak EasyShare M883 Digital Camera
Kodak Easyshare M883 overheats when battery & camera is off
There is a dead short somewhere within the battery holder, replaceing the battery will not fix it It will require intervention by a technician to uncover and fis the short circuit or bare wire. Check out the minimum repair cost and compare it to replacing with a newer model. It may well be throw away.
Please rate my help++++Thankis for using FIXYA
Apr 20, 2010 | Kodak EasyShare M883 Digital Camera
HELP!! I am having a real Kodak moment. I have a Kodak M883, The wall charger says the battery is full but when you put the battery in the camera the camera turns on, the lense extends, battery reads...
Hello :
It seems that the battery is dead or the battery base is rusty or there's isolation stuff on it . Try to clean the base first . If that didn't help , then I recommend you to replace the battery .
good luck .
please don't forget to rate !
Apr 04, 2010 | Kodak EasyShare M883 Digital Camera
My m883 turns on for 1 second then shuts off??
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 18, 2009 | Kodak EasyShare M883 Digital Camera
My kodak m883 green light flashes when turning on
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Battery support : KAA2HR,CRV3, 2xAA Ni-MH and 2xAA Lithium-Ion
Here are the steps:
Contact KODAK:
Nov 17, 2009 | Kodak EasyShare M883 Digital Camera
M883 Powers on then off ?
Check if there is ample space on the memory and good charge on the battery and try, if it still persists then there is a fault on the lens moving out and in, probably because u wud have dropped it.
Thankyou
Jul 31, 2009 | Kodak EasyShare M883 Digital Camera
My camera will turn on and shortly turn itself off
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 29, 2009 | Kodak EasyShare M883 Digital Camera
Kodak EasyShare M883 Digital Camera Logo
248 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
