Question about Refrigerators
How do I set the temperature of my samsung fridge freezer? it sticks at 19 degrees
  • 4,793 Answers
You do mean -19C (which is the default setting for this unit)
Posted on Aug 21, 2010
My temp on the fridge keeps on rising to 19 degrees but freezer temp ok
Are you talking about 19 degrees Fahrenheit? The normal temperature for the refrigerator section should be 38?, and the freezer should be at 0?, both in Fahrenheit.
Mar 06, 2015 | Refrigerators
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
My Samsung Cooltech plus fridge's temperature keeps on skipping back to 9 degrees celcius. Freezer is working fine, what can the problem be?
Every time I select my fridge and freezer temperature from -16 and 3 degrees C respectively it keeps on going back to 20 and 18 degree C. Please assist.
Mar 11, 2011 | Samsung CoolTech Plus / Basic Bottom Mount...
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
Temperature showing on door indicates freezer is +19 degrees (currently set for 0) . Cannot adjust temperature to recommended + 6 degrees and when it is set there it goes to +25 degrees). Refrigerator...
Un plug the fridge and remove the top plastic hinge cover...There is a connector there that is for the control panel. Disconnect and reseat that connector...If there is a glob of hot glue there it may keep the connector from totally seating together. Remove the glob of glue.....
Re-apply power and see if that helps...
This fridge is a comptuter controlled machine. It is extremely complex in it's operation....Bummer.....I have one and have worked on it for 3 different problems...
Most service guys are just going to throw parts at it.....they have no understanding of the operation of it...
Here is a link for the service manual that may help if someone in the family can follow instructions...Nice tests....
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Good luck....
Apr 11, 2010 | Samsung RB215LASH
Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
