Question about Marantz Audio Players & Recorders
Hello, I have recently purchased a NR1501 Marantz receiver/amp and have wired it up to LG DVD via 5-wire "component" , LG blue ray via HDMI, LG VHS via 3-wire "component" and have connected to my LG 60inch TV via HDMI. During set up I use the instructions on page 17 of the manual to get OSD (on screen display). 1. I turn on the unit with the button bottom left corner of the amp (page12). 2. Press MENU. 3. I get "SYSTEM" on the amp screen and I can't get past that! No OSD MENU comes up. Can you give any advise? Thanks, Lew
  • lewis_tucker Aug 21, 2010
    Thankyou for the help. As it happened I had done your suggested actions but your comments led me to review my precise procedure where I picked up a small error which had confused me. Thanks again, Lew
  • Marantz Master
  • 11,800 Answers
You don't get the OSD on the screen because either the HDMI cable for the TV isn't plugged in the OUT plug (the one on the right) or the tv isn't set on the correct AV source (it should be n HDMI1 - if you have plugged the cable correctly on the tv).
Posted on Aug 21, 2010
Marantz amp freezes... What could be the problem?
From the description you have a microprocessor control problem, the only thing I can suggest is unplug everything from the amp, including speaker wires, and anything that is hooked to it, remove plug from wall receptical and let the amp sit for 30 minutes in a effort to get the processor ic to reset. If there is no change you will need a professional to resolve this issue and I recommend a estimate.
Apr 01, 2012 | Marantz NR1501
We recently purchased an AVR 146 receiver and have attempted to connect our DVR satellite receiver, a DVD player/recorder and our Hitachi (non HD) TV, plus a surround sound system to it. The surround sound...
This is how the connection is suppose to be, DVR "OUT", to TV "IN" using the RCA plugs, then press AV on the TV. If this is how you connected it, then maybe there is something wrong with the video wire (Yellow).
As for the DVD, you need to connect an Audio wire separately because the component Red + Green + Blue wire only stands for video. Audio is Red and White, this must be connected for you to get sound from the DVD.
To connect the Audio for your DVD player, connect Red and White wire to Audio "OUT" of your DVD player, to "AUX" in of your AVR 146 receiver, then select AUX on your receiver and sound will come out from your DVD through the receiver.
I hope this is not complicated for you. This connection is simple, all you need is to understand the basics which is OUT and IN. If you want to watch DVD on your TV, this means the DVD will be good OUT to IN of the DVD. The same goes for audio.
If you don't understand, please let me know so that I can direct you further.
Good luck.
Oct 06, 2010 | Harman Kardon Audio Players & Recorders
Have connected dvd/vcr but the tv screen is blue. Can you help please.
You MUST select EXTERNAL Input, NOT a Channel. You MUST connect up via, the INPUTS at rear, either COMPONENT, or COMPOSITE, Or, HDMI. Except for HDMI, ALL Cables, go Color Jack, to Color jack. 3 for composite & Audio, and 5 for Component & Audio.
Apr 23, 2010 | Sanyo DVW-7200 DVD/VCR
I recently purchased a new Samsung Blue Ray player. My previous Sony DVD player used the blue,green, red cords plugged into DVD imput, and I used Coaxial for sound. The Blue Ray only uses HDMI, which the...
Optical carries only 5.1 sound, no video. HDMI carries both video and sound. If your receiver doesn't have HDMI, check your TV for optical output. You can go BluRay to TV via HDMI, then TV to receiver via optical.
If you don't have optical out on your tv, you're going to need either a receiver with HDMI or a BluRay player with component output (blue, green, red).
Dec 06, 2009 | Sony STR-DG500 Receiver
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
My Yamaha receiver stops working when using DVD plsyer
Is your BluRay connected via HDMI? and if so, are any other sources connected the same? if not, just for arguments sake, try hooling up the BluRay via component and digital coaxial or optical. Yamaha as well as all other AV receiver MFG have had big issues with HDMI processing. HDMI has been battling with the recording industry over HDCP and copyright issues on recording via HDMI. So, that's why HDMI has been so flaky. It's been thru versions 1.1,1.1a,1.2,1.2a,1.3a, and now 1.3b, which seems to work so far.... Anyway, sorry to stray off topic, however, HDMI has been a blessing and a curse for both professionals and consumers alike and has caused multiple strange issues with all products that use the technology. Hope this helps. Post a comment if you need further help. I've got lots of contacts for crazy issues!
Aug 18, 2009 | Yamaha RX-V861 Receiver
Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Mar 19, 2009 | Yamaha RX-V463 Receiver
HDMI Connection
is the hdmi connected to the tv
Apr 09, 2008 | Sony STR-DG510 Receiver
541 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
