Question about Foxconn (945G7MA-8KS2) Motherboard
My computer restarting continuously,even i cant boot it from my cd rom, thats why i cant setup windows too, what is the problem?
    Sergeant:
  • 179 Answers
Sounds like a hardware issue, but how far into the boot process does it get? It may be as simple as something jiggering loose. Start with reseating memory modules and checking the hard drive connection; or send it in for service.
when was the last time you blew out the vents as they can easily become clogged with dust.
Could well be an overheating issue.
The heat sink may detached for some reason.
Also check your bios settings. There is an option in there for rebooting upon failure. Make sure thats set to " no ". Otherwise if your having a HD issue your stuck in a loop or if your having problems
Posted on Aug 21, 2010
I want to get in the bios to change the setting to boot from disk platform windows 7
  • Shut down your computer. Check your computer manual for the key stroke to get into your BIOS. Typically it is your "F1" or "F2" key.
  • Restart your computer.
  • Press the BIOS key that was indicated in your computer manual. Continue to press the key until the computer enters your BIOS.
  • Once entered in bios look for boot option and set primary boot device.
    Then restart your system
    Feb 20, 2011 | Acer Computers & Internet
    Netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair this file by starting windows setup using...
    Put the original setup CD-ROM into your CD-drive.
    Restart the computer.
    Tell it to "boot" from the disk in the CD-drive.
    Choose "repair an existing Windows installation",
    and let it fix the problem.
    Remove the CD-ROM disk.
    Restart your (repaired) computer.
    Oct 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
    Wont boot, not even from CD, won't open setup or boot options
    At first you insert your system disc on your cd/dvd rom driver and restart your computer. Now press F2 or DEL until you get your BIOS option. Now go to advance option then boot option in that. Now change your first boot option to CD/DVD ROM DRIVE and save that change by pressing F10. Now restart your computer and continue your installation. Thank you.
    Jun 10, 2010 | HP Media Center m7250n (ED842AA) PC...
    How i can boot from cd
    There is very simple procedure.
    • 1st restart your Laptop and enter in bios setup with the help of F2 key or F1 or Del key.
    • After entering in BIOS setup change the Boot order or Boot sequence.
    • Select the booting device 1st boot from CD Rom.
    • Save the setting.
    • Insert windows XP Cd in CD Rom.
    • Now Computer start from CD Rom.
    • You follow the instruction and install the windows.
    Mar 19, 2010 | ASUS P4B266-C (P4B266-C WA) Motherboard
    My dell desktop doesn't start or boot from cd rom
    Basically you need to go to Bios to change your "Boot device pripority". Please follow these steps to do this.
    Please follow these steps to install XP on your PC.
    1. Please start your PC with power button. At the very first screen, at the left down corner, you will see the button to be pressed to go to Setup i.e. Bios of the PC. For most of the PCs , it is delete button. For some of them, it is F2 also. So, after starting the PC press Del to go into setup.
    2. After you enter setup of the PC, please go to Advance bios setup.
    3. There you select Boot device priority.
    4. here the first boot device priority should be CD ROM, then the HDD. Please see the instructions given at right down corner and select this priority.
    5. After you rightly selected boot device priority as given above, Press F10 to save the changes and then press F12 to exit.
    6. Now the PC will restart again, but be sure that you put win XP cd in the drive before it restarts.
    7. Now you will see a note that : press any key to boot from CD ROM, so please press any key.
    8. The PC will boot from the CD ROM now , now you can follow the instructions given on the screen.
    May 07, 2009 | Dell Dimension 4600 PC Desktop
    HP Desktop PC, won't boot even under safe mode
    if the system was able to enter the desktop and restarts...once possible cause is a virus...scan the pc via safemode or reinstall windows.
    but if it didn't enter the OS desktop...cause might be the boot loader or MBR is damage..
    worth a try:
    Run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
    1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
    2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
    3. If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
    4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
    5. At the command prompt, type this commands one at a time.
    FIXMBR C:
    FIXBOOT C:
    COPY [CDDRIVE]:\I386\NTLDR C:\
    COPY [CDDRIVE]:\I386\NTDETECT.COM C:\
    BOOTCFG /rebuild
    6. To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
    Feb 17, 2009 | Compaq (261671-001) Motherboard
    HOW TO INSTALL WINDOWS 98
    How to Install Windows 98 loadTOCNode(2, 'moreinformation');
    1. Insert the Windows 98 Startup disk in the floppy disk drive, and then restart your computer.
    2. When the Windows 98 Startup menu is displayed, choose the Start computer with CD-ROM support option, and then press ENTER.
    3. If CD-ROM support is provided by the generic drivers on the Startup disk, you receive one of the following messages, where X is the drive letter that is assigned to your CD-ROM drive: Drive X: = Driver MSCD001
      Drive X: = Driver OEMCD001 NOTE: If your CD-ROM drive is not available after you boot from the Windows 98 Startup disk, install the CD-ROM drivers that are included with your CD-ROM drive. For information about how to obtain and install the most current driver for your CD-ROM drive, view the documentation that is included with your device, or contact your hardware manufacturer.
    4. Insert the Windows 98 CD-ROM in the CD-ROM drive, type the following command at a command prompt, and then press ENTER X:\setup where X is the drive letter that is assigned to your CD-ROM drive.
    5. When you receive the following message, press ENTER, and then follow the instructions on the screen to complete the Setup procedure: Please wait while the Setup initializes. Setup is now going to perform a routine check on your system. To continue press Enter.
    Jan 21, 2009 | Microsoft Windows 98 for PC
    Reformatting problem
    Do you mean that you are re-loading windows? if you are when it reboots after re-loading and it says boot/start with cd-rom support do not press enter again or anything else for that matter because if you do it will keep taking you through the whole process again. Once it has loaded and reboots do not press anything it will start windows( even though it gives you the option to start with cd-rom support - just ignore it), itself and take you to the welcome screen etc... once this happens you can take the disk out.
    Oct 25, 2008 | Computers & Internet
    Reformatting my computer
    • Using System Recovery CDs
    • Change the boot order in the BIOS:-
    • Turn off the computer:
    • Disconnect devices that are connected to USB, Fire wire, parallel and serial ports, except the keyboard, the mouse anb Internet Connection.
    • Turn on the computer.
    • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.)
    • Wait until the BIOS setup program opens.
    • Press the right arrow key to select Boot.
    • Press the down arrow key to select Boot Device Priority, and then press Enter on the keyboard.
    • Change the first boot device to CD-ROM using one of these methods:
    • Press the down arrow key to select the CD-ROM item. Press the + (plus) key to move the CD-ROM item up until it is the first item in the list.
    • Press the down arrow key to highlight the First Boot Device selection. Press the + (plus) key until CD-ROM is the selection.
    • Start the recovery:-
    • Press the Eject button on the top CD-ROM drive, and wait for the tray to open. Insert the System Recovery CD #1 and close the tray.
    • Press the F10 key to save the changes and exit BIOS.
    • With Yes selected, press Enter.
    • The recovery window automatically starts; wait for the onscreen instructions to display, and then follow the instructions:-
    • Press R, and then press the F key again.
    • Click yes to perform the full system recovery.
    • Insert the remaining CDs when directed.
    • When the recovery program finishes, click Restart to restart the computer.
    • Before the computer restarts, the CD tray ejects. Remove the CD
    • Return the BIOS to the previous setting
    • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.) Wait until the BIOS setup program opens.
    • Press F5 Key to Set Default Settings in BIOS.
    • Select yes and press Enter.
    • Complete the recovery
    • After the computer restarts, a series of startup screens appear. Complete Microsoft Windows setup as follows:
    • Complete the registration process, and then reconnect the devices that were disconnected earlier.
    • Reinstall software that did not originally come with the computer.
    • Write data files that were previously saved on the backup CD or diskette you made from the hard disk.
    Jul 04, 2008 | Computers & Internet
    Windows XP... Problem:
    reinstall clean copy of windows xp! refer HERE or THIS
    Dec 23, 2007 | Microsoft Windows XP Professional With...
    Foxconn (945G7MA-8KS2) Motherboard Logo
    96 people viewed this question
    Top Foxconn Computers & Internet Experts
    David
    David
    Gareth Cockram
    Gareth Cockram
    Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
