Gut aircon unit in bedroom turns itself on in any mode gas ok wiring correct batteries in handset ok had to disconnect from power supply to turn it off can you help was ok before Keith
  • cazmoores Aug 21, 2010
    if the unit is off it turns itself on sometimes cold or heat or fan only have tried other remotes on unit same problem even removed all handsets from house still it comes on in any mode KEITH
    UNIT COMES ON ONITS OWN COOLING OR HEATING OR FAN ONLY WHICH EVER MODE IT FEELS LIKE DOING REMOVED ALL HANDSETS FROM HOUSE AND STILL IT STARTS UP KEITH
  • 857 Answers
Normally this happens when the system senses low pressure in the system and shuts down the compressor to avoid internal damage. The A/C system is sealed and should not be leaking. If it is, there is a problem. It could also just be a simply control module failure.
Must check if the climate control is on or not.
Posted on Aug 22, 2010
  • 17,130 Answers
Your Air conditioner is working well except you are not able to put the set off. Hence the fault can be most possible with the remote control .
If the AC thermostat is OK and if you turn off the thermostat down, the AC must cut off the compressor.
Now if you can set the OFF timer -if present- in the remote- to switch off after a predetermined time , then the switch off sectionis OK.
Hence we need to check on the remote control, ON/OFF switching. If you have a IR tester check if the OFF trigger is emitting. If not clean the remote , change the pads or use carbon pen to trace the tracks. It must work noe.
But if the IR works and there is no shut down then the fault is the error in the controller IC in the AC unit.
You will need to check this section or for the time being you can shut off by bringing the temp down to switch off the compressor and then switch off power.
Hope this helps.
Posted on Aug 21, 2010
Hi there. there is no spark to ignite the gas in oven.
You will need to replace the spark module if you don't hear any clicking, or there is no spark present when trying to ignite the gas.
To test the Spark Module:
When properly operating, the spark module repeatedly produces a spark at the ignitor accompanied by a sharp snapping sound.
  1. Turn off gas and power supply to unit.
  2. Check wiring diagram to verify all terminals and wire connections are correct and tight with no cuts in the wiring.
  3. Prepare to measure voltage on spark module from terminal L to N.
  4. Turn power supply back on.
  5. Turn top burner to LITE position.
  6. If no voltage is present on the meter, this will indicate the electrical circuit is interrupted before the spark module
  7. If voltage is present, then check ignitor.
  8. If ignitors are ok; then replace spark module.
To access the Spark Module:
  1. Turn off electrical power and gas to the range.
  2. Disconnect gas and power from unit.
  3. Remove screws securing top surface burners.
  4. Remove surface burner and disconnect spark ignitor wire from surface burner.
  5. Raise and remove maintop from unit.
  6. Remove screws securing spark module bracket.
  7. Disconnect wire terminals from spark module.
  8. Replace and reassemble in reverse order.
May 18, 2011 | Amana Ovens
Raypak 2100 265A displays GVO. I know it means Gas Valve Open, but I do not know what is wrong. It is a IID Electronic Pilot. I see a slight flame when the igniter lights and then the system goes into GVO...
Here is the directions from raypak on this code.
1. Turn off power and disconnect ignition wire and gas valve wires from cpu board.
2. Turn on the power and watch for spark at module.
3. If no spark is observed, turn off power and replace the board.
4. If spark is observed, turn off power and reconnect gas valve and ignition wire.
5. Turn on power and unit should fire.
if unit does not fire and code reappears, turn off power and disconnect gas valve wires from the board and remove MV,PV and ground wires from the gas valve. Clean and reconnect wires.
7.Plug the gas valve back into the board and torn power on. Unit should fire.
8. If the unit fails to fire, Replace the gas valve.
Its not a good code to get. Hope this helps
Mar 21, 2011 | Rheem Pool & Spa
Main remote control is not working can you bypass the remote temporarily
No. However you may be able reset the thermostat to its factory setting.
Turn the thermostat off.
Shut of the gas and water supply to the unit.
Unplug or disconnect the unit from its electrical power source. Disconnect the thermostat from the heater.
Wait approximately 5 to minutes, and then reattach the thermostat wires to the heater.
Turn the water supply on and open the tub faucet to its hottest setting for about a minute.
Turn the faucet off and make sure no water water is flowing anywhere in the house.
Turn the gas supply back on.
Reconnect the thermostat wires to the heater.
Connect or turn the power supply back on.
Wait at least 2 minutes before turning the thermostat power button back on.
After the thermostat power button has be pressed, wait an additional 2 minutes before running water.
Test the heater at this time. Turn the water on at the farthest faucet to its hottest setting. measure the temperature with a cooking thermometer.
If you need to make adjustments to the water temperature, either up down, shut all the faucets off first.
The thermostat should read 100 degrees Fahrenheit when it first starts.
If you are receiving an error massage, consult with the manufacturer.
If the thermostat is reading the correct water temperature but the unit is not operating, there are other issue need to deal with. Let us know if this works or you need further assistance.
Sep 26, 2010 | Rheem Tankless Water Heater Main Remote...
My st4000 mkII shuts off from auto mode whhen i engage the clutch lever and the wheel turns for a second. the screen goes blank and just displays "st4000" . voltage is fine and all wires are connected....
CHECK THE POWER SUPPLY WIRING ,If it worked before ,could be corrosion or lose wire connection,or terminal bad crimped,or terminal loose inserted.
If it is new installation ,power wires could be undersized,or battery discharged .
Normally autopilot shuts off from auto and restarts when power supply voltage drops under the reset voltage ,when the wheel turns ,the motor current increase and the power voltage drops when the power supply wires are not OK.
Apr 06, 2010 | Raymarine St 4000 Wheel Drive E12093
Base unit on bt synergy 3505 keeps beeping and handset keeps displaying base 1 and losing signal.... intermitent fault....have changed batteries in handset and switched unit on and off but still not...
If the handset displays 'Searching', 'Base' or 'Range out' on the screen, this indicates that the handset has lost its link with the base. The following procedure should be followed to help resolve the problem:
  • Confirm that the power lead has not been inadvertently disconnected from the base.
  • Ensure that the handset batteries are correctly installed and are fully charged.
  • Ensure that the handset and base are within range of each other.
  • Switch the mains power off, wait five seconds and then turn it on again. This will reset your product.
  • Carry out a reset procedure on both the handset and the base to return the settings back to the factory default. Your user guide will guide you through the correct procedure.
  • If none of the above remedies solve your problem, please contact the helpdesk.
Jul 20, 2009 | British Telecom Synergy 2110 Cordless...
My samsung ac wont turn on at all. according to the wall plug its getting power but when i press the buttons nothing happens, this just started a few days ago
Ok, for the, start if this is a box type aircon, electronic control and solid state thermostat.For the sake of reference.
The problem could be your power outlet lack the other line. Its should be two wire that is completing the power source. Check this first, maybe a troublesome outlet or power plug or the power chord.
Next could be the aircon unit itself, defective power section, or controller section. Blown fuse,lizard insect mouse are common cause.Also bloated or defective capacitor.
But if you are not inclined or do not have any background to electrical and aircon troubleshooting the much safer and practical way is to call an aircon technician. To do the checking for you.
Regards
Jul 09, 2009 | Samsung AW1203B Air Conditioner
Kolin window type aircon shuts off by itself
This may be due to the size of the room. The master bedroom may be smaller than the living room? The unit is therefore reaching setpoint temperature and cycling (shutting off)? Or it could also be a faulty thermostat.
Jan 23, 2009 | Heating & Cooling
Hi the outdoor unit turns on ( fan runs) the indoor unit does open, no heat or cold air blowing. In just fan mode the unit works fine etc speed setting ok. Its a sharp split type air model # ae-a244j...
My gut says that this is evidence of a bad control board(circuit board). As usual, double check that your batteries are good in the thermostat. I have seen some weird things happen when the batteries are low. This one may be a job for your local contractor.
Jun 23, 2008 | Sharp Heating & Cooling
Phones won't work
A) Ok first try to disconnect everything and connect all the batteries and cable back. Charge your batteries to full. Then if it still Out of range, do this with all your handsets.
- Disconnect the battery
- Hold the * and # key on the Handset and put the battery back without releasing the buttons. (now your in test mode)
- press the 2 softkey below the screen ( it's a factory reset, erase everything)
- You will see RAM/EEprom erase on the screen
-After the bip press end
B) OK! Now disconnect the power adapter from your base unit .
-Hold the memory button on your base and plug the power adapter at the same time. Then the base will bip to let you know that you done it correctly.
-after the bip press No.1 ( that's mean the handset 1 is de-registrer.
- Now De-register all the other handset by doing the part B again. But only changer the No.1 for 2 then 3 then 4.
C) Disconnect and reconnect everything and use your manual to register your handsets with the base and your done! Everything should be ok !
Nov 21, 2007 | Uniden DCT648-3 Cordless Phone
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
