Question about Hoover AAA160 Front Load Washer
Error code 4 machine will not start - Hoover AAA160 Front Load Washer
  • 92 Answers
Check the plug in every measures necessary and then call an engineer rate : [
Posted on Aug 21, 2010
  • Adarsh Ramchurun Aug 21, 2010
    Any other problem let me know
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
While starting the xerox machine SHARP AR 5316 , indicator is showing 4 and blinking everytime, unable to take the printout
I'm going to guess that if you watch the display closely, it is alternating between an "H", and a "4". If that is the case, you have an "H4" error code. This is a fuser error and can either be a freak out from the machine, or an indication of something serious. I would recommend resetting the code and seeing if it comes back. To reset the code, turn the machine on and press "#" -> "Interrupt" -> "Clear" -> "Interrupt". Doing this should put you into service mode, where the display will show a blinking double dash (--). Enter 14 and press the green start button, just like you are trying to make 14 copies of something. At this point, the machine should restart itself and hopefully the error code will go away. If the error code does not go away, or recurs on a fairly frequent basis, I would recommend contacting a professional service technician.
Feb 22, 2011 | Sharp AR-5316 Advanced Digital Imager...
Push start and machine wont fill and draining/unlocking light sarts blinking about 2 seconds later
My machine had the exactly same problem:
1. Push Start button to wash, but Draining/Unlocking light will flash right away. The drum started to run and stopped
2. No error code shown up
3. Run Quick test: no error code
4. Run Universal Test: error code F25 (later, found nothing wrong with the CCU)
What I did:
1. Clean the bump: found coins and strings.
2. Clean the drain pipe from the pump to tub: found more coins.
3. Clean chamber of pressure switch at the tub: found nothing.
4. Clean the gap between tub and drum: found a credit card!
After the cleanings, the Draining/Unlocking light would still come back and I almost gave up. Amazingly, I ignored it and a few minutes later.... the machine started to run as normal!
It seems that CCU needs sometime to reset itself after the failure.
Jan 24, 2011 | Whirlpool WFC7500VW Washer
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
System error 4-00
your problem is displaing 4-00 error code but it is not clear code befor 4-00 any alphabatic latter is displaing so, please tell full error code
like H-4-00
if H-4-00 code then go to dignostic code and press 14 and then press start button then wait it will rest your error code
it will restart it self after 1 second
now can strart your work machine is working ok,
May 12, 2010 | Sharp AR-5316 Advanced Digital Imager...
Error code E-4
You only have part of the error code. You need to hold down the "." key in order to get the rest of the code. Since there is only 3 error codes that begin with 4, I'll post them here so when you find out what the problem is, you can attempt to solve it.
E405 - Transfer belt/drum charge roller position abnormal
E440 - Main motor lock
E442 - Drum charge thermistor abnormal
It's most likely not the third, as this one doesn't normally cause the machine to stop operating. The first two can be reset by turning off the main power switch for a few seconds, then turning it back on. This will clear the error, provided it's not a hard error (one that reoccurs during the machines warm-up cycle).
Just so you know, due to the age, parts for this machine are getting hard to get...
Dec 16, 2009 | Savin Office Equipment & Supplies
F 2 error code
Hi KG Oliver,
This is a common complaint on the Whirlpool built Kenmore's. Please follow this link to my solution for it.
Thanks,
SG
Apr 05, 2009 | Kenmore Washing Machines
Unable to print mcf-215
plz press menu then start-bk-copy then fourtimes arrow up quickly after another. machine turns to maintanence mode. press start bk copy: what two digit error code does the machine display?
If it starts with a 4 you do need a new printhead!
Mar 28, 2008 | Brother Multi-Function Center® MFC-215C...
Brother IntelliFax 1840C
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If that doesnt give you the code then try going into service mode by pressin menu key then *, 2 , 8, 6, 4  super quick!! Display goes blank or Maintenence mode is displayed, if not... not quick enough, do again to you get it, then press 77 start, error should display. press 99 to exit Maintence mode, dont play with other numbers!!
a couple of the most common errors are
Error 41 needs new print head costly
error 46 waste ink full, need new waste tank
Whats yours?
Oct 30, 2007 | Brother IntelliFAX 1840C Plain Paper...
Hoover AAA160 Front Load Washer Logo
166 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
