Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
LInt filter Where is the lint filter/pin filter for a front load samsung washer? We have been told this is the problem and the reason it won't drain, but where is it so we can clean it?
    Novelist:
  • 177 Answers
Find you owners manual, it should say how to clean the button trap on your pump
Unplug the machine FIRST!
Get some towels, you will have water coming out.
if the tub is full of water you will need to bale it out!
Remove the lower front panel, usually two screws,
look for the pump it will have hoses on it. now lay some towels around, expect water.
Unscrew the end of the pump, if it has a button trap or lint filter.
it will be on or near the pump refer to your owners manual
If you dont have an owners manual you may find it at Samsung.com?
Posted on May 03, 2008
Where is the drain filter in a Samsung top-load washer WA400P ??
There is no drain filter on the top load washer. Many of the front load washers have the lint filters.
Oct 21, 2016 | Samsung Washing Machines
Where is the lint filter on Speed Queen...
You didn't say if it was top or front loading and did not include a model number. The model number is usually on a tag that is covered by the lid or door.
As far as I know most washers do not filter out lint during the wash but rely on the lint being suspended in the wash water and expelled with the dirty and rinse waters. Many do have filters in the drain that do need to be cleaned at times but the symptom is usuall a slow drain or not draining.
How to Avoid Lint on Clothes from Your Washing Machine Top Load Washer...
This is an active lint filter machine.
Filter Flo Lint Capture
At this link you can download Speed Queen Product Manuals.
Maintenance Tips
Front Load Washer Troubleshooting Lint
Oct 16, 2014 | Dryers
Miele W1926 Door Won't Open
You probably still have something stuck in the filter in have had the same problem and found it to be the remnants of hair scrunchie.good luck
Feb 22, 2013 | Miele W1926A Front Load Washer
I have a Sears Kenmore washer, model # 110.28922791. I bought it approximately 10 years, give or take a year or two. I know it does not have a lint filter but is there any way to clean whatever processes...
HI- Washer really don't have a lint filter so to speak. Some of the front load washers have a filter in the drain pump but that basically just keep the quarters and bobby pins from ruining the pump. Is it possible to have someone extend your standpipe with a larger diameter pipe that you could place a screen into, or place the screen on the drain hose and then put them both into the larger pipe. A plumber should be able to figure something out. It would be about $1000 dollars cheaper than buying a front-loader and probably more effective. Good luck.
Sep 24, 2010 | Washing Machines
I can't find the lint filter in my 4kg machine. Where is it?
washer/dryers do not have a lint filter.. Any lint is flushed down the drain.
Mar 01, 2010 | LG WD14311RD Front Load Washer / Dryer
Maytag Legacy Series Washer. Lint settles on
Lint is in majority flushed out in drain cycle. make aire the tissue and match books aren't in any pockets. the lint is then deied and separated in the drier , Well so I was told . good luck
Jun 07, 2009 | Maytag Legacy Series Top Load Washer
Washing machine not draining or spinning. samsung j1043.
Samsung washer drain pumps usually have a trap that may be holding a large amount of debris (buttons, pins, coins, etc) and lint packs around all of it and the water can't drain, which means the unit won't spin. A more complete model number would be required to find out if the trap is accessible by removing the front panel or not.
Apr 25, 2009 | Samsung WF203ANW Front Load Washer
LG FRont Load Washer Dryer WD-1256RD filling up with lint
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Feb 08, 2009 | LG WD-12124RD Front Load Washer
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Kenmore 41742042100 front load washer
IT IN THE SAME PLACE AS THE FRIGIDAIRE YOU HAVE TO TAKE THE FRONT LOWER PANEL OFF
Jan 02, 2008 | LG WM2688H Front Load Washer
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
443 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
