Question about Acer Aspire One PC Notebook
My acer aspire one is working but not showing display it was totally black....
  • Acer Master
  • 17,130 Answers
Connect the laptop to an external monitor to confirm that the system is worrking in perfect condition. If so then there is a possiblity that the LCD display is at fault.
1. Check using the external monitor for any errrors in the display drive. if so reinstall.
2. If not, there could be a possible break in the lines that go through the hinges. check the continuity of the connection from the mother board.
3. possible failure of the mother board/display drive. This might be expensive and so take help.
Helpful.
Posted on Aug 21, 2010
Cannot open my laptop,acer aspire 4720 zo1 series
Totally No Display? Is the laptop running? Do you hear fans running, disk drive spinning and lights? If it seems like the laptop completed the boot process except the screen is black, try this:
Shine a flashlight on the dark screen to see ifyou barely see the icons on the desktop. If so, then the LCD Inverter isbad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on
Apr 19, 2012 | Computers & Internet
Acer Aspire 4930 not starting.... only black screen
Hook a spare monitor to the video output, usually on the back, if picture okay! the LCD screen on the laptop has a bad inverter board or the backlight behind the screen has failed. But if both show the same symptom the Video Graphics Card is bad usually built into the motherboard.
Mar 21, 2012 | Acer Aspire 4930-6862 Laptop
Hi, I have acer aspire 5520,2 Gb RAM... When I turn on my acer,everithing works just fine,exept monitor,it remains black,When I try ecternal monitor,it works fine,windows wors fine to,everithing but the...
Aspire 5520 has LCD Display. The screen displays becomes dark/ dim if there is no backlight.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. These parts are inside the LCD screen. Either of the parts may be faulty or in some rare cases both. Also, the video data cable may be loose or faulty, which can be identified only after opening the top cover.
So, my advice is that you get it properly checked by any professional for replacement of Inverter or CCFL.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 22, 2011 | Acer Aspire 5520-5579 Notebook
Once i log onto my acer aspire one D255 the screen goes black and it wont even show me the task manager. i have already re booted and shut down
test it in safe mode. if it works, do a restore to a previous working date or last known-good configuration. if you cannot get to the Windows log in at all, reinstall your OS. if nothing shows up on the screen from the time you power it on, test an external display and if it does not work, sounds like your video card is faulty and needs a replacement
Dec 31, 2010 | Acer Aspire One D255-2670
Brand New Acer 5738PG6306 (touch screen) Notebook - BLANK SCREEN
If you can return it to the retailer, that would be my first option. Sounds like a bad backlight.
Feb 22, 2010 | Acer Aspire AS5738PG6306 (LXPK802046)...
Acer computer screen went white and black
If the mouse is newly installed may be theres a problem in the port drive of your acer computer or one of its components been corrupted. So as your monitor doesn't work since display components and its, drive have been missing. YOu have an acer CD, try to repair or perhaps it needs to reformat your Acer computer.
Jun 19, 2009 | Acer Aspire 9410 Notebook
Acer aspire 5220 booting problem
Try connecting to an external monitor. If it displays on the external monitor then the LCD is probably dead. If it doesn't display on the external monitor, its a problem with the video card.
Feb 25, 2009 | Dell Inspiron 6000 Notebook
Acer aspire 3680 svideo in black and white?
Have you checked The Settings in The Bios.
Your laptop May be set As NTSC Or PAL, displaying on A Different format tv set ?
Try An external Monitor, Or the TV Out if applicable.
If these work in Colour rather than monochrome ( Black And White ) then the fault lies with your svga output on the laptop.
Mike @ compurepair.
May 07, 2008 | Acer Aspire 3680 Laptop
Acer Aspire One  PC Notebook Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
