Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Kenmore progressive Direct Drive Vacuum w/Hepa
While vacuuming, the carpet brush stopped. Now I have no suction whatsoever. I have cleaned the filter already.
  • 1 more comment
  • Anonymous Mar 16, 2014
    Hepa filter pops off when I turn the vacuum on
    gold eureka airspeed technology with hepa filter
  • Anonymous Mar 30, 2014
    model
    President:
  • 1,673 Answers
Check the hose and dirt inlet for a blockage. Also the brush roll, check it to see if you can turn it or not by hand. If not, then something may have jammed it.
Posted on Jun 01, 2008
Kenmore progressive 360 vacuum cleaner has low suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Kenmore 35912 / 35913 Progressive Upright...
Sweeping part of the vacuum stopped spinning.
Is the belt stretched or broken? There needs to be a (not-stretched and not broken) belt connecting the rotating brush (agitator) to the motor pulley on the vacuum.
May 05, 2009 | Kenmore 31913 Progressive Direct Drive...
My vacuum will not pick up even fuzz on the carpet
If the suction is strong through the hose and its still not picking up, then something is definately clogged despite the strong suction and rolle brush. Check all inspection tubes including the main dirt channel behind the roller brush. You may find something that keeps getting in the way when dirt or hair is trying to bypass through.
Jan 23, 2009 | Kenmore 31913 Progressive Direct Drive...
Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
I have the upright kenmore progressive with direct drive and the filter canister stops bringing in air and picking up when hose is put into vaccum, when you remove hose and use as an attachment it starts...
Check the hose after the brushes. With this problem there is normally a clog in between where you disconnect the hose (to use attachment) and the brushes that clean the carpet.
Dec 21, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore direct drive model 116 31912100 lost vacuum
Check the inlet where the dirt is first sucked in for a clog, also your hose may be clogged.
Sep 01, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
559 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
