Question about Zodiac Pacer Pool Cleaner
Zodiac pool cleaner stops and starts and sometimes just stops working completely. Checked diaphram. replaced it with a new one. pool is forever getting green ... at my wits end... bout to pull my hair out.
  • 640 Answers
With these pool cleaners, there are several things that can cause a lack of suction and movement. Make sure that the main drain and all suction lines are closed except the line you are using. Make sure there is no debris in the flapper or filter that could be clogging suction. Check the hose are ensure that there are no leaks. Check the pump basket for looseness, cracks, and worn or missing o-rings.
Posted on Oct 28, 2010
At the end of summer our Zodiac ran for about 5 minutes and then stopped.We got the pool-guys out and they said the underground pipes had a leak,they dug it all up and replaced.The Zodiac did the same.Then...
Sad ??.
Home water pressure runs 60-80#, which a sound plumbing system should handle. Can you get into your plumbing where there is a straight shot to the pool, rig an adapter and try to back flush into the pool?
I presume your filter is clear (low pressure drop on gauge).
Apr 13, 2017 | Zodiac Pacer Pool Cleaner
My g3 is not working, took it to pool store and they replaced diaphram, but still not hopping or moving, suction is good but now movement.
There are a couple things to check with these pool cleaners when they stop moving. Use Pool Pulse to insure proper flow through the cleaner. Clean baskets and filter to ensure that you are not clogged. Check hose sections for leaks by lifting each section above water.
Apr 09, 2011 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac G2 Cleaner not moving around pool. Suction is adequate, filter has been backwashed. Cleaner pulled to pieces and reassembled. Has small crack in diaphram. Unit is 6 months old and has problems the...
any damage to that diaphram will cause the cleaner to not work. If it is only 6 months old then it is under warranty. any pool store should be able to get you a new diaphram at no cost. bring your paperwork with you to show proof of purchase.
Dec 29, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Can Baracuda Diaphragm be replaced?
If you can't find any junk in the diaphram or throught. The best thing to do is take it to a store they can show you how to do this and they will not usually charge for more than just the part.
May 28, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Has good suction but wont move
Is there a tile stuck in the condom shaped diaphram when you look into the cleaner from underneath. Could be any kind of rubbish make sure you look deep inside as debris gets stuck right at the top.
This diaphram is removable check also that it does not have a hole in it.
Cheers Bazzard
May 08, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My baracuda G3 stop working is not pulsating and therefore not moving. I checked the suction and the hoses even the diaphram everything looks ok.
If you have suction at the bottom of the cleaner, there has to be a problem with the diaphragm. I would remove it and recheck.
Feb 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
G3 is not moving, but has suction? Please advise.
I had the same problem. come to find out there was somehting stuck in the diaphram. (a piece of mulch). Once I removed it, everything worked fine. Take your Barracuda apart and check the diaphram for blockage.
Mar 21, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac Pacer Pool Cleaner Logo
1,135 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
