Question about Ovens
Oven problems When I turn my oven on to heat up it never does. You can leave the oven on for hours and it never gets warm. Do you know what part I need. Any help would be greatly appreciated. Haven't been able to use my oven in 6 months.
  • Anonymous May 03, 2008
    Followed proper procedure to Bake at correct temperature. It shows going to 100deg on preheat but the oven does not heat up. Tried same procedure on another oven and it worked so something wrong with this oven.
    Problem Solver:
  • 12 Answers
Need to know whether you are dealing with a gas or electric oven. if it is electric then there could be a problem with the heating circuit, the element. if it is gas then again it could be a problem with the heating circuit, or ignition system. first check incoming power ie breaker or plug. if gas make sure you have unit plugged in and there are no gas valves turned off. If all of those check out fine then the problem is with your oven. in which case if you are not comfortable working on the innards of your oven call a certified technician.
Posted on May 03, 2008
My Electrolux double oven goes from "bake" to "warm oven " after about 1 hour. I try to use the other oven and it will go start to "warm oven"
is the bake element getting hot?when you put the oven on bake both the broil and bake elements come on,if just the broil element is getting hot it might take it an hour to heat up.you might just have a bad bake element,if the bake element isn't hidden does is turn red? if not it's not getting hot.
Nov 14, 2017 | Electrolux Ovens
Neff electric oven stays hot after turning off
This is normal...there is a cooling fan built in to your oven designed to cool the facial controls when hot and can take some time to cool to an acceptable temper?ture that's why you can feel the air blowing,, usually above the oven door...if you switch off at the mains you are risking the plastic components on the facial melting. Just leave it to Run it is a very low wattage motor and costs very little to run
Oct 10, 2017 | Ovens
The ovens turn on but do not get hot--it gets warm but the burners never turn red --- it takes 3 hours to cook a chicken
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 17, 2010 | Jenn-Air Ovens
I have an older Sears Kenmore oven. It has the
the internal fuse is blown out and the circuit breakers gone short its a reparing job not a resetting job.you will have to opoen the oven and get the circuit breaker checked and repaired or replaced.
Mar 02, 2009 | Kenmore Ovens
GE P7 Wall oven had bad thermostat????
IF YOUR HEATING ELEMENT IS GETTING ORANGE HOT, AND CYCLING, I WOULD SUSPECT THE THERMOSTAT TO BE THE SOURCE OF THE PROBLEM. YOU MAY FIND IT HARD TO FIND ONE THOUGH DUE TO ITS AGE.
Jan 28, 2009 | GE JKP50SH Electric Double Oven
Oven not heating
you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Dec 07, 2008 | Hotpoint SY36 Style Line Stainless Steel...
GE Profile JT952 Double Wall Oven doesn't heat up adequately
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
heatman101
May 29, 2008 | GE Profile JT952 Electric Double Oven
Fan runs for hours after use
The fan is in place to cool the electronics it will run after the unit is off it is possible you have a bad sensor on the fan circuit leaving it to run too long
Apr 05, 2008 | GE JTP15 Electric Single Oven
Slow warm up
hi petrich let me know if you had your voltage to the oven checked. is must be the problem to have two ovens slow to heat up... let me know..krazytech
Aug 25, 2007 | Elan E-948-DB / E-948-DW / E-948-DS...
I have a whirlpool RBS245PDQ12
you probably have the clock set wrong and oven is on automatic.switch off for 5 mins, get your book out and reset the clock
Jul 06, 2007 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
87 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
