Question about Casio Sea-Pathfinder SPF40-T Wrist Watch
Hi, I'm trying to replace the battery on my Sea-Pathfinder. Got stuck after unscrewing the four screws holding the back plate. Cannot remove the back plate which seems to be hold in place by two plastic holders connecting the watch with the titanium wrist band. Is there a way of removing these holders? Thank you
  • 374 Answers
SOURCE: REPLACEMENT STRAPS
Call Casio Parts dept and they should be able to send you a band. 800-223-2001 is their number. :)
Posted on Jul 23, 2007
  • 73 Answers
SOURCE: Repliciment wrist gand for Casio Pathfinder
you can go to this link and in the upper right corner type in the model number not the module number (there are instructions for finding the model number if you don't know it) I found a band for a watch that is over 8 years old on here.
http://www.fsiwebs.com/shopcart3/SC_ProdList.asp?
Posted on Jan 07, 2008
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
The schlatter.org solution is for the other type of casio band I've run into.
The wristband with the arrows has a fine pictorial solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band
Basically you use a very very fine poker to poke the pins out in the direction of the arrows.
NOTE: you can't poke them out if you will drive them into your work surface, so think about that before you start.
Posted on Feb 02, 2008
SOURCE: wrist band adjustment
In addition to the Pin there is also a small inner "locking" collar about 2mm long that fits into the center section of each link.
I did not notice this collar at first and it fell to the ground when I removed the first link. Without this piece the Pin's will just slide through the links with no locking mechanism.
It fits neatly into the inner portion of the link directly opposite the arrow that shows the direction of removal on the band.
Posted on Dec 06, 2008
escapement
  • 2334 Answers
SOURCE: How do I get the pins out of the titanium band for Casio PAW1500T
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Jul 09, 2009
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    How to change battery
  • Spread the towel out on a flat surface.
  • Remove the watchband if necessary in order to access the back of the watch.
  • Unscrew the back protector from the watch using the correct size miniature screw driver. Place the screws in a small pile on the towel. Be careful not to drop them as they are difficult to find.
  • Remove the back plate by unscrewing the small screws. There is a tiny spring on the underneath of the back plate. It may be visible, or not. Make sure not to turn the watch upside down or the spring will dislodge.
  • Remove the rubber protector to find the battery.
  • Use sharp point tweezers to remove the clasp covering the battery. There is a small hole at one end of the clasp. Insert one end of the tweezers into the hole to spring the clasp loose.
  • Remove the old battery with tweezers.
  • Insert New Battery and Reassemble Watch
  • Pick up the new battery using regular tweezers and put it into place. Do not touch the battery with your fingers.
  • Replace the clasp over the top of the new battery.
  • Perform a reset by touching the AC contact with one part of the tweezers and the back of the battery with the other part. Hold for a few seconds. Lift the watch carefully and look up at the front to make sure the watch is working. Do not turn the watch over.
  • Replace the rubber cover.
  • Replace the back plate by screwing the small screws back into place.
  • Replace the back protector by screwing the small screws back into place.
  • Reattach the watch band to the watch face.
  • Feel a bit unnerved by this? Find a local jeweler. Best regards.
    Jewel
    Sep 01, 2010 | Casio MTP3036A-2AV Wrist Watch
    Battery replacement procedure for Casio 901 DW-5600?
    hi, if the back plate on the watch the part that is against your wrist has four screws holding the silver back plate onto the actual watch then you need to undo these four screw, once undone you lift the back plate off and then this gives you access to the battery, the screws are small philips (cross head screw) so you will need a small screw driver, their is also a little bracket that holds the battery in place you can either push this over to allow the battery out or undo the small screw that holds this bracket in place this will then allow the battery to fall out,
    If their are no screws in the back plate then all you need to do is get a very fine flat head screwdriver and look around the edge of the back plate and you should see a little bit on one of the edges that allows you to put a screwdriver into to allow you to lever the back plate off if it has no screws then its just a push fit so just pry the back off and this will give you access to the battery then like above the battery will be held in place by small bracket undo this then remove the battery.
    when fitting the new battery make sure you dont touch the top and bottom of the battery as this will flatten it really quick so just push it in place then refit the bracket then either push the back plate back on or screw it back on depending on the type of back plate once this is done you watch will be working again
    Aug 14, 2010 | Casio DW-5600E-1VCT Wrist Watch
    After battery replacement of casio sea-pathfinder
    If it has "AC" written on the module you may need to short between the AC point and + battery. Also check voltage of battery. It may just be too flat.
    Jul 25, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Replace batteries on sea pathfinder how do i remove the metal frame holding all four batteries in please
    If you see no screws holding the contact (metal frame), that means the contact is clip-on. Take an eyeglass and examine all contact legs carefully- you will find out where it is clipped on. Use fine pointed tweezers to pull contact legs and undo it.
    Rate, please.
    Jul 09, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    I wish to replace the battery myself, how do I do this?
    Polar tells its customers to send watches to them for battery replacement. But the Polar Fitwatch is too old (may have been introduced in 1997?), and they no longer support it. So the only solution is to replace the battery some other way.
    For most people I'd say go to a store that sells watches, they'll replace the battery for a fee.
    For those who are handy, you can replace it yourself. I did mine yesterday.
    The battery is a common type - CR 2032.
    You'll need a small screwdriver, philips type, I think. Maybe around 00, or thereabouts. And you need tweezers, preferably with a rubberized grip.
    There are four screws holding the back plate. Remove three, and loosen the fourth. Slide the back plate aside.
    I unscrewed the screws, then used the tweezers to take them out. They're a bit small for your fingers to get a good grip on them.
    The battery is held by a plastic holder that's held by 4 screws. These are (to my eyes) slightly smaller than the ones holding the back plate, so please keep those separate - and keep track of all the screws.
    Remove the plastic holder, and make sure you keep track of the spring that's between the holder and the back plate. It'll likely fall out when you turn the holder over.
    The holder keeps the battery with a small prong, but it's easy to slide out the battery. Replace the battery, getting the orientation right, making sure you don't touch either side with your bare fingers. This part is easier than it sounds.
    Replace the holder, and of course you noted beforehand what the orientation was, so you get it in the same position.
    Use the tweezers to drop each screw into its hole, then screw it in.
    By this time, the watch will probably start beeping when you tighten one of the screws, because you depress one of the buttons on the front.
    Put the spring back in its hole, then slide the backplate back into place, and drop the screws in place with tweezers and tighten one by one.
    You should be able to find a manual (which doesn't cover battery replacement procedure) by searching for polar fitwatch manual.
    Apr 28, 2009 | Watches
    Ironman Watch correct way to change battery
    It really is best to have a professional install it, but if you would like to attempt to try it yourself, you will need certain tools. Take a small phillips-head screwdriver and remove the four screws on the back of the watch. Take off the back. Be careful not to mess up the seal (rubber round gasket). You will see a battery strap with three prongs with screws holding down your lithium battery. Unscrew any two of the three screws, and using a tweezer, pull out the battery. Put in the same number battery (probably 2016) making sure to insert it positive side up. Rescrew the screws. Next to one of the screws that you unscrewed, there will be another piece protruding off the battery strap, which almost hits the circuit board. Take your tweezers and lightly press it down to make contact and hold for 3 seconds. Replace your backing and screws.
    Apr 22, 2008 | Watches
    CASIO SPF40 battery replacement
    "AC" means All Clear. This terminal should be marked somehow. Use a magnifying glass to get a good look at what you are working on. My Casio had an arrow pointing to four copper leads. I used a paper clip to connect the AC terminal (I just picked one of the four) to the + side (usually the "up" side) for a couple seconds and my Casio Sea Pathfinder model 2273 powered right up. See the following link for more guidance.
    http://www.geocities.com/watch_crazy/battery/battery.htm
    Feb 24, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    How to get casio sea-pathfinder working after replacing batteries
    This certainly put me on the right track,but i found on my pathfinder mod 2271 that the four brass dots located down in the hole were unacessable with standard flat head tweezers so I inserted a small sewing needle and touched one of the brass dots while bridgeing the distance from the needle to the positive (+) surface of one of the four batteries with tweezer legs.
    Nov 19, 2007 | Watches
    Casio Sea-Pathfinder SPF40-T Wrist Watch Logo
    27 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
