Question about Dryers
Simpson Sirocco 500 dryer does nothing when it is turned on. Changed power point, checked fuse, still won't go. Maintained well throughout it's life to date - always cleaned filter, etc.
  • Dryers Master
  • 3,051 Answers
Hello there:
The first thing is to check to see if you have the lights work or if not and won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. It blows fuses or trips the circuit breaker Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then: If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician. If the circuit breaker trips or the fuse blows when the dryer is
Posted on Aug 21, 2010
The centre rear pulley is locked causing the belt to break. Simpson sirocco 500 dryer
And you tell us this WHY . ? replace the pulley with a new one
Mar 09, 2018 | Dryers
Simpson clothes dryer sirocco 455 5kg the power shorts out when we turn it on ?
check the heating element.remove back panel to access it
May 31, 2015 | Dryers
How to get back off simpson sirocco 500
Either you missed a screw or it is stuck and you have to pry it off.
May 18, 2015 | Dryers
Is it a big job to replace the heater element on the Simpson Sirocco 350 dryer?
It won't be the element unless a wire from it is grounding against the casing. You most likely have some sort of issue with the home breaker.
Mar 15, 2014 | Kenmore 500 6952 Dryer
Simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
May 04, 2012 | Simpson Esprit 750 Top Load 7.5kg
I have pulled the dryer apart at the back and discovered the fan is not working. Is it fixable or should we just buy a new one . It is a Simpson Sirocco 450 Dryer.
well this one is down to you ,,how old is the dryer? how much to fix it? how long will the patch job last? how much life is left in this unit?
how would you like a new unit???? how good will it fell to show off a new unit?,,,go for it,,,spoil yourself!
Jul 21, 2010 | Dryers
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
Diagram of how to replace drive belt on simpson sirocco 500 tumble dryer
May 12, 2009 | Dryers
Dryers Logo
154 people viewed this question
Top Dryers Experts
