Question about Nokia 6288 Cellular Phone
Hi. when i plug charger phone typing NOT CHARGING. the problem after change retu. retu changhed 3
  • 277 Answers
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And ifcharger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Posted on Aug 21, 2010
Wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 09, 2012 | ZTE Avail Bluetooth Music 3G GPS Android...
Wont charge
First Option:
Second Option:
Sep 09, 2012 | AT&T Avail
I have N95 and i have being charging for more than 14 hours but it still not changed.i try new batterys but it still the not charging can any body help me.thanks
hi there!
14hours! its not the battery then. try other chargers, if none of them worked, plug one working charger, try moving the plug jack (make sure its pushed all the way to the phone's charging port) wiggle it, see if the battery level changes. the contacts of the phone can be damaged too. its a hardware issue meaning a local technician is the best thing for this .
Apr 08, 2011 | Nokia N95 Cellular Phone
The cable is plugged in but my phone wont charge
It can be deduced that the charging port of your phone which carries power from the charger to the panel in no more functioning,therefore the phone is unable to charge,
But,before we conclude that the problem is from the charging port,i will suggest you test the charger with another phone of its kind,if the charger charges the phone,it can be concluded that the problem is from the charging port,and the solution is to replace the charging port,
However, if it doesn't charge the other phone ,it means the problem is from the charger,which indicates that you have to get another charger instead of changing the charging port of your phone.
Thanks and take care.
Aug 21, 2010 | Cell Phones
My samsung cell phone gives no indication when charging so I donot know whether is charged or not.The problem is the charger or the mobile phone?It indicates only the bar which requires charging but when I...
There are 3 solutions to your problem.
1) You need to replace your phone's battery, or
2) You need to replace your charger. (If you have a car charger, try it to determine if your home charger is the problem) or
3) you need to have the charging plug on your phone repaired; it will need to be sent in for service.
Feb 01, 2010 | Samsung SCH-u340 Cellular Phone
My nokia 6280 is not keeping gharge and is refusing to charge
1-Try another trusted genuine battery.
2- Try another trusted genuine charger.
3- If RETU IC is not under-filled try yo reflow it, if not works then replace it.
4- No way but to try replacing TAHVO IC even if it's under-filled (if you really want to solve the problem) ;) .
maybe ur bsi line short to ground!!
try to remove the resistor in bsi line....
Mar 21, 2009 | Nokia 6280 Cellular Phone
Sidekick ID
The sidekick ID has the same type of charging port as the sidekick 3, which are notorious for going bad. The easiset thing to do is get a charging cradle that has a spare battery slot.
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Mar 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
N 70 charging problem
put out battery first than fix it again and restart your phone and than recharge ur cell.
Feb 22, 2008 | Nokia N70 Cellular Phone
Nokia 3250 charging problem
it sounds like a problem with the charging port (where you actually plug the charger into your phone). unfortunately, you may have to replace the phone, as switching batteries or chargers wont solve the problem.
Sep 24, 2007 | Nokia 1100
Nokia 6288 Cellular Phone Logo
50 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
