Question about Dishwashers
Heller HDW12 at first it wouldnt do a complete cycle, now it wont do any cycle. I can turn it on, it has power it just wont wash, it makes a noise but its not washing. The tap is turned on. Could you please help me as I live in Kalgoorlie and it takes weeks to get a plumber, and he's not cheap...probably cost me my first born!!!! regards B Hughes
  • Anonymous Aug 08, 2008
    Fills with water, heats the water though does not perform the wash cycle and then empties??
  • Anonymous Nov 02, 2008
    my dishwasher will not complete a cycle, it was really expensive and is only 3 yrs old:( Anyone know how to fix
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Posted on Jan 25, 2009
  • 555 Answers
SOURCE: Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
Posted on Aug 30, 2009
SOURCE: Whirlpool Quiet Partner Doesn't finish cycle
FIX YA IS A JOKE I WOULD LIKE TO BURY THE ************** WHO CREATED IT!
Posted on Feb 05, 2010
SOURCE: I need an instruction manual
www.gafcontrol.com.au/brochures/pdfs/GAF-Whitegoods2.pdf
Hi, please find above your user manual.
Posted on Aug 24, 2010
Aa class beko 1400 rpm in black...my washer has been fine until today...it did a wash and spun fine...then wouldnt unlock it just kept making a noise (like it was just about to start a cycle) for bout 4...
Try pressing start pause and cancel at the same time. This is the way to overcome a Beko door lock power problem. A bad sound suggests the belt has broken, and that can only be replaced by a technician
Mar 17, 2014 | Washing Machines
Dryer wouldnt turn on its saying door is open
most of the time. its the door switch that causes this. if door is closed and it does not start, its the door switch. try this! unplug power, remove the door switch, hook the wires from switch together. this will make a complete curcuit.put black tape on wires so it wont short out. plug back in. it should work, if it runs ok door switch is bad. good-day !
Mar 29, 2012 | Frigidaire Dryers
Clicking noises
IF APPLIANCE IS RUNNING OK I WOULDNT WORRY TOO MUCH THE CLICKING YOURE HEARING IS PROBABLY THE HEATER RELAYS SWITCHING ON AND OFF AND THE MOTOR REVERSING RELAY ALSO NORMALLY THEY WOULD NOT BE HEARD OVER NORMAL RUNNING NOISES OF MACHINE.
Sep 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Just out of storage, my washer is having difficulties.
Hi, There are capacitors that give an initial boost to start the motor moving and these tend to go bad from sitting for long periods, that's why you could give it an assist and it would work, you are providing the extra boost. Helping it though causes other problems, like belt and voltage control problems, so that is not a good idea. You should have it looked at if you are not electrically or mechanically inclined. Best of luck to you!
Feb 13, 2009 | GE WBSR3140DW Top Load Washer
No operating INSRUCTIONS
I don't have the manual but I can make a few suggestions. First, if you have left scraps on the plates, they won't come clean. Second, if the water is not hot enough, you will have problems with your detergent. Three, use the amount of detergent the bowl holds. Fourth, never jam in more to the unit than it should easily hold...in the utensil racks, for example. Fifth, always make it easy for what you've put in to drain thoroughly so the drying cycle works.
Mar 07, 2008 | Dishwashers
Washing machine does not spin Whirlpool LLR7144
the motor coupling is probably broken. Especially if it wont wash either. Its probably just filling with water and then making noise but not actually washing. If its doing this than replace the coupling.
Jan 10, 2008 | Washing Machines
Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Jun 15, 2007 | GE WBVH6240F Front Load Washer
Dishwashers Logo
116 people viewed this question
Top Dishwashers Experts
