How to install UIF File format of 3dstudio max in windows7?
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
I have some mp4 format videos on a usb and when i plug it into my sons audiosonic tv/dvd model km2120 it comes up as unsupported file i have also tried mkv files as well and its the same please help?
what file format does the tv read. not the file format like mp4 or avi or mkv but the disk format of the usb stick. Is it FAT 32 FAT 16 or NTFS
http://windows.microsoft.com/en-au/windows7/comparing-ntfs-and-fat32-file-systems
is it in apple mac file system this is different to windows file system
Jun 17, 2015 | Computers & Internet
I installed 3ds max 10. when I click modifier list,system hanging, also modifier list not working. then I uninstall max10,re installed max 9. same problem. how to solve this issue.
I installed 3ds max 10. when I click modifier list,system hanging, also modifier list not working. then I uninstall max10,re installed max 9. same problem. how to solve this pls tel me
Nov 21, 2010 | Autodesk 3dStudio Max 9 for PC
Hello Sir, I purchased Acer Aspire 5745G two weeks ago. Yesterday My brother installed Fedora 12 and Windows7 was already instlled in it... Acer Customer Care Service suggested me to use Windows7 only. So...
The problem is with your Windows Boot file "bot.ini file" This file can become damage, corrupted or deleted for a number of reaons, (here seems the installation of Fedora 12) and id usually brought to your attention to by an error message befoe booting windows, the same message you are facing. there are two ways of removing it. 1-You can format your OS and re install it. or 2- repair your windows using the windows OS Cd.
Nov 15, 2010 | Acer Aspire One PC Notebook
3Dmax serial no
But its better than spending 3K!
http://thepiratebay.org/torrent/4455035/3DS_Max_2009_Keygen__With_Instructions
May 19, 2010 | Autodesk 3dStudio Max 9 for PC
3ds max autodesk is not opening in windows7 ultimate
Right click the 3dmax then open it with administrator.
May 22, 2009 | Autodesk 3ds Max for PC
Cant' figure how to hook to internet connection
It seems you have several questions. Some programs must be installed from a cd some don't.
1. You can try copying the contents of cd and pasting it to the flash drive then to the laptop into a single folder and run the install/setup program from there. This may or may not work.
2. You can install Magic Disc to your computer and the laptop.
With this program you can copy a cd or dvd into one file.
Then this program can take the file and load it as a cd rom drive.
You can download the program from this link.
http://www.magiciso.com/tutorials/miso-magicdisc-overview.htm
Once you have the program installed you should see you have a new dvd-drive in my computer and a new icon on the taskbar. The icon will have a hand holding a cd disk.
Right Click on it and select make cd/dvd image.
Select the drive where you have the cad cd.
Select where you want it saved on your computer. Make sure you click on the folder type a filename and click save or it will put the file in some strange place, and make sure you take down where it saved it to.
Keep the .uif format don't change it.
No need to make a password.
Click OK
Let it do it's thing.
When it's done you will have the .uif file on your hard drive you can run as if it is a cd drive without a cd drive.
To do this right click on the magic disk icon in the taskbar and select "Virtual CD/DVD-ROM", select No Media, select mount.
In the "Mount CD/DVD" window select the .uif image file you created.
The cd file should load just as if you had inserted a cd into a real cd drive.
To do this on the laptop first copy the installation file for magic disc to the laptop then intall it. Then copy the .uif file to the laptop and mount it the same way I said on xp.
I've use this program a ton and it works great. My kids can't ruin cd's this way. :)
Note: If your flash drive isn't big enough you can use a program like winrar or file dicer to break the .uif file into smaller pieces and move it over piece by piece.
Sep 10, 2008 | Dell Latitude D600 Notebook
Open Questions:
Computers & Internet Logo
224 people viewed this question
David Payne
David Payne
