Question about Hoover HCA390K Bottom Freezer Refrigerator
How do I change a Hoover HCA390K freezer door seal? Apparently Hoover say it is tricky and there are no instructions.
SOURCE: fridge seal repairs
We sell these seals online at http://www.doorseal.com.au
We also have online instructions on how to fit them.
Posted on Nov 12, 2008
bobicehouse
  • 1524 Answers
SOURCE: Need to replace freezer door seal on Hoover HFA29K
This is probably a "push in" gasket.
Posted on Apr 23, 2009
philbran
  • 242 Answers
SOURCE: changed freezer seal,bottom half of door won't close tight
tough job there , you must get a hair dryer and carefully heat gasket until it seals properly. some gaskets take hours to get to seal right.
Phil
Posted on Jun 10, 2009
beltronic205
  • 1466 Answers
SOURCE: i need to change the door seal on a bosch washing
Can be tricky if not done before..look @ utube for video how to//
Posted on Nov 11, 2009
  • 104 Answers
SOURCE: Instructions for changing a door seal on an
There are videos of how to change a door seal on you tube. Not necessarily for your particular model but changing them is virtually the same for all machines.
Posted on Jan 28, 2010
I have a Hoover Fridge freezer and my fridge is really warm inside and the freezer is not freezing the food in the top drawer but it is keeping the food a bit cold. What could be wrong with it?
It could be
- a faulty thermostat
- a loss of refrigerant through leakage
- a very poor sealing door gasket
If the fridge is old I'd say you will need to replace it.
Nov 13, 2016 | Hoover Refrigerators
Why is my Hoover A Class upright freezer alarm light constantly on
1) It could be a short. 2) The thermo sensor that turns the light on could be defective and needs to be replaced.
Mar 24, 2015 | Hoover 9.9 cu. ft. / 280 liter Upright...
Fridge freezer not getting cold and freezing
This issue is frequently seen when the valve that diverts refrigerant between the top compartment and lower compartment is stuck closed.
It is advisable to turn the whole unit off to prevent any further damage within and contacting a domestic appliances service engineer in your area as soon as you can to have the valve replaced and the unit regassed (If neccessary 50/50 if it does or not)
Please also be aware that this can be an expensive repair and in many cases it is more cost effective to replace the unit than get it repaired.
If you elect to replace be sure to buy one with a lengthy warranty as had this unit have been under warranty Hovver will have paid for the repair.
Feb 28, 2011 | Hoover HCA390K Bottom Freezer Refrigerator
How to replace door gaskets
The BEST way, is to remove the doors and lay them flat, totally supported. This will insure that the doors don't twist while you are changing the seals. Just remove the screws around the edge and remove and replace the seals. Some are a bit tricky so, match them up as you remove the old one. Some look backwards as you put them on but after stretching them around the frame they are correct.
Jul 19, 2010 | Electrolux ERN2820 Bottom Freezer...
I need to change the door seal on a bosch washing machine is it tricky
This video will show you how to change a door seal on this Bosch Classixx WFL 2066 Front Load Washer washing machine
Nov 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Fridge seal repairs
Check for the seal replacement on www.marcone.com.
Mar 13, 2008 | Refrigerators
Earth leakage trip
What about the light switch,lamp'S housing and in worst case a burn wire ? Good luck!
Jun 28, 2006 | Hoover HCA390K Bottom Freezer Refrigerator
Hoover HCA390K Bottom Freezer Refrigerator Logo
108 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
