Question about Dishwashers
Hello, I have a SMEG ST997 and the display shows no errrors, just P0, but I do not get it to work. The only digit working is the timer which is stock on 23. Can someone help? Thank Maurice
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Disconnect the Dishwasher from the power socket and mains and let it sit without power for more than ten minutes and replace all the connections and switch it on. If still the issue is not resolved, then you’ll need to run the diagnostic mode. However, before running diagnostic mode fully empty the dishwasher as it does not pump out before starting to fill and it will alternatively overfill. Now open the door and set the program to the rinse and turn it off. While pressing and holding the start button turn the power on. While the start button will flash, release the start button. Now again press the start button once and close the dishwasher door and the machine will run through the diagnostic mode for about twenty minutes. If an error is found the machine will stop and will display the error code. If no error code is displayed it will complete the diagnostics and end the programme. To exit diagnostic mode at any time you’ll need to press and hold the start button till the programme is cancelled. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 21, 2010
Smeg linear oven is displaying sho (showroom mode) and will not heat up. I have held down function knob for 5 seconds which clears SHO from display but within seconds it comes back. Any ideas
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 28, 2013 | Smeg Linear Pyrolitic Single Oven Electric
Smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Apr 10, 2008 | Smeg SE280X Stainless Steel Electric...
SMEG OVEN BRAND NEW WON'T HEAT
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
Sep 08, 2012 | Smeg Ovens
Smeg oven stopped working
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jan 27, 2012 | Smeg Ovens
DWI614: Fault: Switch On - initially displays all characters, then displays P0 shortly followed by 2 beeps! Pressing the 'P' button has no effect.
Just had this problem today. Went away after tightening edge-connector plugs on circuit board. Had previously tested out push-buttons with meter and were ok.
Jun 01, 2011 | Smeg DWI614 Built-in Dishwasher
Hi Our oven wont turn on, has power as the display panel has a little "A" luminated on the left of display screen but nothing else operates, no fan, Grill, timer. please advise
Mar 24, 2011 | Smeg SE210X/1 Stainless Steel Electric...
Smeg integrated dishwasher continually washing - won't move to drying cycle.
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg Dishwasher
replace the timer/control board
May 26, 2008 | Dishwashers
Dishwashers Logo
89 people viewed this question
Top Dishwashers Experts
