Question about Dryers
Fails to turn and hums if drum rotated it starts
  • 269 Answers
The motor capacitor has failed and will need replacing it can normally be found either mounted on the motor or close to it.
The capacitor resembles a D type torch battery and could be alluminium or plastic casing.
Hopes this helps.
Posted on Aug 21, 2010
Illeagle
  • 525 Answers
SOURCE: Drum not rotating
If you clean your lint filter after each load faithfully, try removing the dryer vent hose that goes to the outside and inspect it for lint accumulation, water build up, or some other foreign material, as this will restrict air flow and cause your described symptoms. If your are unable to inspect your vent, disconnect it from the back of the dryer and start your dryer to see if it works that way.
Posted on May 29, 2008
TheMobilian
  • 8220 Answers
SOURCE: Fridgidaire Gas Dryer - Mod.#FDG
Your glides are brobably broken and missing. This will make the drum hard to turn and bind the motor. Get the front off the dryer:
7411f19.jpgStart by popping the top with a putty knife.
Get the screws out that hold the front on and take a look:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 16, 2008
mastatech
  • 478 Answers
SOURCE: START SWITCH HUMS BUT THE DRUM DOES NOT ROTATE
Try turning the drum while holding down the start button the belt could be twisted
Posted on May 10, 2009
localwonder
  • 6784 Answers
SOURCE: Dryer humms but does not turn unless I rotate drum when turned on
HI. This is a damaged sator assembly in the motor casing. the cooper windings are damaged. this motor will need to be replaced asap, if possible.
Posted on Oct 19, 2009
  • 4088 Answers
SOURCE: Dryer hums when start button is pushed and drum
The drum belt may be broken. Open the top to check this.
Posted on Feb 20, 2010
How to get to motor on hoover vhc691b?
Very rare a motor fails on a hoover drier normally its the capacitor that fails. you can hear the motor humming but the drum wont rotate to proof its the capacitor turn the machine on press start listen for the motor humming open the the door of drier turn the drum by hand fast then shut the door as fast has possible then the drum should start going around . then this proves its the capacitor fault you are doing the job of the capacitor giving the motor a start .
May 16, 2014 | Hoover HDC6 Electric Dryer
When the button is pressed to start the dryer it begins to hum as iff the drum is stuck. It does this for about 5 to 10 seconds then shuts off. If I attempt to start it again nothing happens. sound like...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Apr 17, 2011 | Whirlpool LER7646E Dryer
Dryer motor hums but does not turn when start button is pushed
Jan 24, 2011 | Maytag MDG6000 Dryer
GE dryer model DDE8200GALAD was working fine. After removing a load and trying to dry another, after inserting the load and shutting the door when you turn the timer to start it before pushing the start...
Jan 23, 2011 | GE Dryers
The dyrer will not turn on. The dryer makes a humming noise but will not turn on.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Also, check the blower on the dryer to see if a article of clothing may have gotten stuck there and preventing the motor from running.
Jan 22, 2011 | Whirlpool Dryers
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
Jan 18, 2011 | Kenmore Dryers
When I press the start button, it hums but won't turn on, I hear clicking behind the cycle setting dial?
Jan 17, 2011 | Maytag Dryers
Drum will not rotate
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 25, 2010 | Kenmore 83142 Electric Dryer
The Maytag Neptune dryer motor hums but does not start the drum turning. The belt is good.
The motor bearings or drum bearings may be seized or the motor starter circuit is bad. Can you manually rotate the drum? If so, that probably eliminates any seized bearings. Try rotating the drum while the motor hums. If that allows the motor to run, then the starter circuit is defective. Unless the motor has an external start capacitor, the motor will likely have to be replaced.
Aug 01, 2009 | Dryers
The dryer just makes a humming noise when I turn it on, but won't turn all the way on
When you say it won't turn all the way on, does that mean the drum isn't rotating?
If yes, the belt from the motor that goes around the drum might have broken and you can hear the hum of the motor spinning but no longer rotating the drum.
The other thing I can think of is that the motor itself has failed, possibly seized, and you can hear the motor trying to spin but it cannot. With the dryer unplugged and empty of clothes, try to rotate the drum. If it rotates extreamly easily, then the belt has broken. If you cannot rotate it at all by hand, then chances are the motor is seized. It should rotate with moderate effort.
Mar 08, 2008 | Dryers
Open Questions:
Dryers Logo
53 people viewed this question
Top Dryers Experts
