Recovery disk does not work, when chice #4 is pressed it says error 109 and to contact manufacturer. I made the mistake of installing windows xp. I cannot remove it becausse it does not recognize me as the admin.
    Genius:
  • 3,587 Answers
Ohhhhhhhhh..not cool..time for a reformat, methinks.
Posted on May 03, 2008
My laptop says windows error recovery
The Windows Error Recovery message can appear for several reasons- an improper shutdown, new software, new hardware, etc. Since trying both options that you are given doesn't work, you need to troubleshoot the Windows startup error. If you have recently added new hardware, disconnecting or removing it could solve the problem for you as it might be creating some type of incompatibility.
Troubleshooting Windows Error Recovery: Last Known Good Configuration
You can attempt to boot up in Safe Mode and select Last Known Good Configuration and see if that works to resolve the Windows startup error. Turn the computer on and immediately begin to press the "F8″ key. If this does not work, you might need to press the "F2," "F10," or "F12″ key. Once you see the prompt screen, select "Last Known Good Configuration."
Troubleshooting Windows Error Recovery: Booting up from the Installation Disk
If that did not work, try booting up the laptop using the Windows installation disk - provided you still have it. If so, follow these steps:
1)   Turn the power button to your laptop on.
2)   Immediately insert the Windows installation disk that belongs to the laptop.
3)   When you see the option for "Check System," press the "ESC" key. Next, press the "F1″ key. Your laptop should now boot up.
4)   You can now use the "System Restore" feature to allow your laptop to return to a previous setting when it was functioning properly. This might mean selecting "R" for recovery.
Mar 11, 2011 | Acer Cell Phones
Tip
How to fix "Operating System Not Found" error when you start your Windows...
When you try to start a Windows XP-Based computer, you may receive an error message that the operating system is not found.
APPLIES TO
Microsoft Windows XP Home Edition
Microsoft Windows XP Professional
Symptoms
When you start a Windows XP-Based computer, you may receive one of the following error messages.
Error message 1
Operating system not found.
Error message 2
Missing Operating System
When you start your computer to the Recovery Console to recover functionality, you may receive an error message that resembles the following error message:
Setup did not find any hard drives installed on your computer.
CausesThis issue may occur if one or more of the following conditions are true:
The basic input/output system (BIOS) does not detect the hard disk.
The hard disk is damaged.
Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
Note Some third-party programs or disk corruption can damage an MBR.
An incompatible partition is marked as Active.
A partition that contains the MBR is no longer active.
Resolution To resolve this issue, use one of the following methods, depending on your situation.
Contact your hardware manufacturer
Your best bet may be to contact the manufacturer of your computer or your hard disk. The manufacturer may have a utility that you can use to perform a more detailed scan for damaged areas of the disk and help verify the correct BIOS settings. However, be aware that the damage to your hard disk may be serious. Sometimes this means that your only solution is to replace your hard disk.
If a fix or workaround is not available, you can use the "Advanced Troubleshooting" section to try to resolve this issue.
Advanced troubleshooting
This section is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact support. For information about how to contact Microsoft support, visit the following Microsoft Web site:
http://support.microsoft.com/contactus/
Method 1: Verify the BIOS settings
Verify the computer's BIOS settings to make sure that BIOS lists and recognizes the hard disk. See the computer documentation or contact the hardware manufacturer for information about how to verify the BIOS settings.
After you verify that the computer's BIOS detects the hard disk, restart the computer, and then test to determine whether the issue is resolved. If the issue is not resolved, or if the computer's BIOS cannot detect the hard disk, you may have issues with your hardware. Contact the hardware manufacturer to inquire about how to resolve this issue. You may have to replace the hard disk.
For information about how to contact hardware manufacturers, click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base:
65416 Hardware and software vendor contact information, A-K
60781 Hardware and software vendor contact information, L-P
60782
Hardware and software vendor contact information, Q-Z
Method 2: Use Recovery Console
Use the fixmbr command in the Windows XP Recovery Console to repair the MBR of the startup partition.
Warning This command can damage your partition table if a virus is present or if a hardware problem exists. If you use this command, you may create inaccessible partitions. We recommend that you run antivirus software before you use this command. We also recommend that you backup your data before you use this command. If the fixmbr command detects an invalid or non-standard partition table signature, the fixmbr command prompts you for permission before rewriting the MBR. The fixmbr command is supported only on x86-based computers.
For more information about Recovery Console, click the following article numbers to view the articles in the Microsoft Knowledge Base:
314058 Description of the Windows XP Recovery Console 307654 How to install and use the Recovery Console in Windows XP
on Jul 15, 2010 | Computers & Internet
Please help!! my dell latitude d620 fails to boot displaying: YVFXP is compressed press Ctrl+Alt+Del to restart. When i do this it jus does the same thing.
Ifyou have compressed the hard disk drive using the Compress drive to save disk space option under the Propertiesmenu for your hard disk drive and have performed a non-destructive recovery ora system recovery, the following error message may appear: NTLDR is compressed. Press CRTL-ALT-DEL to restart. This error message is resolved byfollowing these steps: 1. Insert the Windows XP CD drive onthe computer and restart the computer. 2. Press F12 when the computer firststarts, then select CD-ROM, click any key to boot into windows startup. 3. When you get to the install windowsXP screen: 4. Press Rto repair the Windows XP installation using Recovery Console. 5. Enter the appropriate number for theWINDOWS installation, for example, the WINDOWS installation could be listed as 3:C:\WINDOWS or 3: D:\WINDOWS . 6. If prompted, enter yourAdministrator password and press Enter . If there is no password, justpress Enter . 7. At the prompt, if the WINDOWSinstallation you selected in Step 4 was C:\WINDOWS, type: cdc:\ Or, if theWINDOWS installation you selected in Step 4 was D:\WINDOWS, type: cdd:\ 8. At the prompt, type: attrib-c ntldr and thenpress Enter . 9. At the prompt, type: exit 10.Press the Enter key and immediately remove all discs or diskettes from thecomputer to allow the computer to restart.
Mar 05, 2011 | Dell Latitude D620 Notebook
When switcthing on my Advent netbook it comes up with the error message Windows Boot Manager Windows Falied to Start. A recent hardware or software change might be the cause. To fix the problem: 1....
Hi sioban_bros,
Based on your situation. I suggest trying the following steps:
1. restart the computer and keep pressing F8; Use Last Known Good Configuration.
2.If the issue still occurs after that, I suggest testing if we can boot from a Windows XP disk. If so, please install Windows XP on another partition and access your important data.
3. After backing up those data, you can use Windows XP disk to format the drive and reinstall your preferred operating system.
4. However, if we cannot boot from a Windows XP disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
To access the data on the drive, you can try to install the hard drive on another computer.
Hope it helps.
Please rate this solution if found useful.
Best regards,
Reyjoshua07
Jan 17, 2011 | Advent Netbook
Down loaded msn explorer 8 pc will not start up TMGR missing
The "TMGR" is a Windows Operating System component file.
This error might occur if the TMGR file is corrupted or missing.
However, as this is a Operating System Component file, you may resolve the issue by performing the below steps.
First, you may try performing the SFC Scan.
Performing the SFC Scan will automatically fix any damaged files or any errors in the Registry.
Steps to initiate the SFC Scan:
1) Open the RUN command window.
2) In the RUN command window, type "cmd" and press Enter.
3) In the Command prompt, type cd
4) Then. type cd Windows and press Enter.
5) Then type sfc /scannow and press Enter.
6) This will start the SFC Scan process.
The Computer might also ask for the Windows Operating System Disc.
Peforming the SFC Scan should resolve the issue with the TMGR file.
If the issue still persists, initiate the Disc checking process.
For Windows XP:
support.microsoft.com/kb/315265
For Windows Vista:
http://windows.microsoft.com/en-US/windows-vista/Check-your-hard-disk-for-errors
For Windows 7:
Jul 05, 2010 | Acer Aspire One PC Notebook
How do I format my laptop using the recovery disk???
hi there, here's the step by step procedure for reformatting.
1. insert the recovery disk first to your cd rom
2. restart pc and keep on tapping the F12 key
3. once you are prompted for boot options select your cd/dvd rom drive
your computer will now boot up from your cd rom and will initialize the setup.
Apr 21, 2010 | Acer Aspire 4720 Notebook
My hard drive burnt out. The hard drive test says failed and the operating system won't boot. I placed a leftover hard drive from my Playstation 3 into the laptop and now it says no operating system found....
Try the recovery console from a windows xp recovery/install disk:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select the operating system you want to repair (you may have only one option).
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation. From here I would try "chkdsk /r" and "fixboot"
For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
For information about a specific command, type help commandname at the command prompt, and then press ENTER.
6.To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Once you've done this restart the computer and see if it boots up.
Apr 08, 2010 | HP Compaq Presario V6000T PC Notebook
Unmountable boot volume
hi,
-this can be a hardware problem or a software problem
-run diagnostics first on the computer
-turn off computer; while the computer is off, press and hold the "Fn" key then press power at the same time to initialize the test
-if you find error message like 0142 - this is a hard drive failure; contact your manufacturer for replacing your hard drive
-if no error is found, it is a corrupted Windows; you need to reinstall Windows, ensure you consult local technician to back-up files before installation.
cheers!
Oct 05, 2009 | Dell Inspiron 1525 Notebook
I am having the same difficulties as you!
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&docname=c00220758&product=12455
If you have compressed the hard disk drive using the Compress drive to save disk space option under the Properties menu for your hard disk drive and have performed a non-destructive recovery or a system recovery, the following error message may appear: NTLDR is compressed. Press CRTL-ALT-DEL to restart. This error message is resolved by following these steps:
  1. Insert the HP Recovery Tools CD or Compaq Recovery Tools CD into the CD drive on the computer and restart the computer.Wait for the HP Recovery Tools CD or Compaq Recovery Tools CD window to open.
  2. Select Run Microsoft Recovery Console , click Next , and then follow the onscreen instructions. NOTE: If you are unable to open a recovery console, follow the Alternate steps .
  3. Press R to repair the Windows XP installation using Recovery Console.
  4. Enter the appropriate number for the WINDOWS installation, for example, the WINDOWS installation could be listed as 3: C:\WINDOWS or 3: D:\WINDOWS .
  5. If prompted, enter your Administrator password and press Enter . If there is no password, just press Enter .
  6. At the prompt, if the WINDOWS installation you selected in Step 4 was C:\WINDOWS, type: cd c:\Or, if the WINDOWS installation you selected in Step 4 was D:\WINDOWS, type: cd d:\
  7. At the prompt, type: attrib -c ntldr and then press Enter .
  8. At the prompt, type: exit
  9. Press the Enter key and immediately remove all discs or diskettes from the computer to allow the computer to restart.The error message should be resolved.
Alternate steps NOTE: These alternate steps work for HP and Compaq desktop PCs with Windows XP and a recovery partition. (M0st HP and Compaq PCs with Windows XP have a recovery partition on the hard disk drive.) These steps do not work if you have replaced the hard disk drive, replaced Windows with another operating system, or repartitioned the recovery partition.You can use the following steps if you are unable to open a recovery console:
  1. Turn on the computer. When the initial logo screen appears, press the F10 key repeatedly until a message about starting recovery appears.
  2. At the Recovery screen, click Advanced Options and then press the Alt and D keys at the same time to go to a command prompt.
  3. At the command prompt, enter the following: diskpart
  4. At the command prompt, enter the following: list volume
  5. Remember the drive letter next to line for the main hard drive; HP_PAVILION or PRESARIO.
  6. To close Diskpart, enter the following: exit
  7. At the command prompt, enter the drive letter followed by a colon (:). For example, H:
  8. At the command prompt, enter the following: cd \windows\system32
  9. At the command prompt, type the following: compact ntldr /u <the drive letter>:\ntldr For example if the drive letter was H, you would type: compact ntldr /u h:\ntldr
  10. Type exit and press Enter .
  11. Click Quit .The error message should be resolved.
Sep 06, 2009 | E-Machines eMachines Desktop PC
Replacing with harddrive 40GB
Did you simply swap hard drives? "Couldn't find NTLDR" basically means the PC cannot find any version of Windows installed because the boot file is missing. This could be because you have a CD in the drive or the hard drive is missing or broken.
If you put in a new hard drive to replace your older smaller one you need to reinstall Windows on that new 40GB drive or it just won't work. If you have some PC Tech friends they should be able to move the data which is tricky or help you out.
Mar 18, 2009 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
