The Front loader washing Machine fills up with water but doesnt wash or spin. First I thought it was the belt and replaced with a new one. After changing the belt i turned it on and it spun for a while with a lot of noise and then stopped spining again. Please help I already spent 90$ on a new belt.
  • kaiyanaga Aug 21, 2010
    Washing machine is Fron loader Ariston AV61. I removed the rear cover and saw that the new replacement belt wasnt moving so i thought the belt is too tight and needs adjusting so i removed the belt. The motor still doesnt turn. So i gave it a little twist at the rotor and it rotated for a while with a sound and then stopped again in another direction i spun it by hand and it rotated for a while before stopping. I disconnected the power so i dont burn the motor.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please let me know the name of manufacturer and model number of washing machine so that I can provide you with model specific information.
Thanks
Rylee
Posted on Aug 21, 2010
  • 1 more comment
  • Rylee Smith
    Rylee Smith Aug 21, 2010
    If the pump is fine then it is the motor that should be replaced as it seems to be bad and cannot be repaired. Please do accept the solution if the issue is
    resolved or post a comment for further assistance.
    Thanks
    Rylee
    Is there no way to repair the motor as i think it could be the bearings or brushes? Or you think it would be cheaper to buy a new one.
  • Rylee Smith
    Its always better to buy a new one however, if you want you replace its bearings and brushes but replacing it completely will rule out such issues in future.
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Apr 20, 2011 | Maytag Washing Machines
Replace belt j845 samsung front loader washing machine. how do i get replacement belt on as back and both sides of machine is one piece of metal
There is no belt on a front loader washing machine. The way the drum spins is by a stator in the back of the unit.
Dec 29, 2009 | Samsung WF337AA Front Load Washer
GE washer wJR4170G1WW wont wash or spin What
changing from large to small load will not cause a problem. this could be a control panel issue. unplug machine, the try rotating load size dial back and forth a few times, plug machine back in and try
Jul 24, 2009 | Washing Machines
Washing machine wont stop filling
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
Washing machine faberic softner try fills with water when in use.
hot water valve inside unit may be faulty ck it to make sure that it is powering up and then make sure it is operating. the cold and hot valve are one unit on most washers so the unit is replaced as one. if its a front loader than there might be a one way ck valve malfunctioning or the unit keeping intoducing water into the unit even though it is at the level it should be at. top loader then the level sensor is jacked and needs replaced.
Jun 12, 2009 | Frigidaire GLTF1670A Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Final Spin Cycle Amiss
depending on the make and the model, especially if it is a top loader, try replacing the belt. when the belts get older they stretch and slip a little, just enought o cause your problem
Oct 10, 2007 | Washing Machines
Kenmore Front Loader-Doesnt Aggitate nor Spin
the speed control board needs to be replaced in the lower rirght corner of the washer
Sep 12, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
