Question about Garden
Is it possible to convert a Sovereign sgt 30 cord strimmer to a bladed brush cutter?
3 Suggested Answers
SOURCE: AM after carb service kit for my Echo SRM 2000A
Get the brand name and #'s of the carb. and go to that web site and order one. Also try napa they also have some kits. donnyb60
Posted on Mar 24, 2009
  • 109 Answers
SOURCE: 2 stroke mixture ratio for strimmer
The basic fuel/oil mix is 50 to 1
Posted on May 06, 2009
I need a recoil part for my sovereign SGT 24 any ideas please
perhaps the manufacturer can assist you in finding a new spring.or your local dealer
Sep 08, 2015 | Garden
I purchased an 8 inch heavy-duty brushcutter blade for my Ryobi 30 cc four cycle powerhead how do I attach it to the string trimmer head
You can't use the blade on most string trimmers unless you have a brush cutter style then you would unscrew the trimmer string head and attach the blade with the adapter that came with the unit.
Oct 23, 2014 | Garden
Sovereign strimmer HS-PT-2538
I had this problem once when machine was hot it was difficult to restart, I've found putting choke on slightly, about a quarter of the way, and not touching the throttle will see it starting, then put choke back off and leave it to idle for 20 - 30 seconds before using. Seems to be a characteristic of this strimmer.
Jun 11, 2013 | Garden
I have a makita backpack petrol strimmer fitted with a line head can i fit a brushcutter blade instead i donot have the full model No it is a 41cc engine it is an early model
Hi Doug,
There are adapters for just about every combination of trimmer, brush cutter blade, grass gator, etc. you can think of.
One of the most handy purchases has been a non specific arbor adapter set. Not only does it have 2or 3 each of the most common nuts in both left and right hand thread, it has inserts that keep every blade, flail and brushcutter I've tried dead center.
It even came with a diamond shaped one for a skillsaw blade that I tried with my Ryobi 4 cycle. That thing turns thorny blackberry vines to powder.
So the answer is yes.
Best regards
Aug 14, 2010 | Garden
Can i purchase a metal cutting blade for my sovereign petrol grass trimmer 6102
Universal kits are available that will allow you to attach a brush cutter blade to just about anything that usually has a line head. The kit contains a selection of bolts, adapters, packing washers etc - you simply select the parts you need to attach the blade. The blade itself is not machine specific.
May 08, 2010 | Garden
I have just bought an RBC30SET. I am trying to
To remove the strimmer and procut fitment first you need to lock the shaft by placing item 35 into the slot in the flange next to the fitment and through into the hole in the outer housing of the drive shaft, item 3. Then using the box spanner turn the fitment CLOCKWISE. Once this has started to move it can be turned by hand until it released. Place the brush cutter onto the shaft followed by the dished washer, cupped face towards the cutter and fix in place with the nut, turning it anticlockwise to tighted. DO NOT overtighted as the direction the cutter turns will tighten the nut further.
Sep 18, 2009 | Ryobi Garden
BAD STARTER
it might have a easy start that wound make it seem like its sliping.change spark plug and gap at 030.see if it helps if not rebuild carb.
good luck
Jul 20, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Garden Logo
139 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
