Question about JVC KD-G322 CD Player
Is it possible to connect four speakers ? - JVC KD-G322 CD Player
Yes you can thats why its a 4 channel output
Posted on Dec 29, 2010
I don't know how to connect the speakers to my insignia receiver.
Well, this is a two channel (stereo) receiver. If you have two speakers, look to rear of the unit and connect right speaker to the right output terminal and vice versa with left speaker. If you have four speakers, there are an option if the receiver has systems A and B of speakers set. Do the same with B system and listen to all four speakers using switch at the A+B position. Good
Jul 21, 2010 | Insignia 200W Stereo Receiver
Changing the omes of a 4 10'' bass cabinet
i guess ur talking about four nos of  4ohms 10" speakers. two speakers of four ohms connected in series gives 8 ohms, but if u use parallel connection u will get half of individual ohms i.e 2 ohms. so connect two speakers in series and another two speakers in series. parallel the two serial speakers and voila... u get a 4ohms speaker with double the wattage.
parallel connection - connect +ve to +ve and -ve to -ve.
series connection - connect -ve of one speaker to +ve of another speaker so that u have +ve input to one speaker and ground(-ve) on the second speaker.
So, two separate series speaker then parallel the two series speakers.
Mar 12, 2010 | Audio Players & Recorders
How do i connect 4ohm speakers to my 8ohm jvc receiver
You must connect two sets of speakers to do this.
You must connect them in series.
Meaning, you connect the positive of one to the positive (red) on that reciever. Then you connect the negetive of that speaker to the positive of another four ohm speaker, then run the negetive of that speaker to the negetive on the reciever. Just like if you were connecting batteries together.
Remember never to connect multiple speakers in paralell. (positive to positive and negetive to negetive) as this would make four ohm speakers into a two ohm configuration.
You can use speakers with higher ohm ratings in this setup. For instance, if you connect an eight ohm speaker in series with a four ohm this would give you 12 ohms. Which is also acceptable.
Feb 06, 2010 | JVC Audio Players & Recorders
Only 2 out of the 4 speakers of my Creative Inspire M4500 work!
If you still have the guarantee , then take it back to the buyer and replace it with a newer one and before you leave the shop try them there ! If that is not possible i'm asking you : What is your operating system and which service pack you got ? I think WinXp with service pack2 should solve the problem .
Jan 09, 2010 | Creative Labs Audio Players & Recorders
Just clicks no power. Already checked for touching wires and proper cooling. This unit has worked fin in the same location for four years. Any other ideas?
I had a similar 'drop out' problem with my Yamaha RX-V3300.
Problem- Possibly loose speaker connections.
I have banana connections which I unplugged; tightened speaker terminal connections at back of receiver and then reinserted banana speaker connectors- which remedied problem. There is possibly some kind of loose connection either caused by the banana plugs or at speaker connectors at the back of the receiver, which was remedied (i.e. possibly temporarily) by reinserting the banana plugs.
I also previously thought something was wrong with the main on/off power relay which was 'dropping out' and replaced it, but then 'drop out' problem returned a few days later. I reinserted and tightened speaker connectors, which has it working again.
Dec 22, 2009 | Yamaha RX-V630 Receiver
Having problems with the installation of the brutus 2008d amp in my truck. how many channels is it? how do i connect the subs? do i connect the rca cables from the radio to the input or output.
The rca cables from your stereo go to the "input" part of the amp. Now, if there are four speaker connections in your amp, then it's a 2 channel. If you have eight speaker connections then you have a four channel amp. Note, some amps can be briged to provide more power to the speakers. On a two way amp(2 speakers), the connections can be briged to only one speker providing more power, usually whatever the amp power rating is, say a 500watt amp will put all 500 watts to that speaker. The same goes for a four way amp(4speakers), can be bridged to two speakers(250watts per speaker). Hope this helps.
Sep 04, 2009 | Car Audio & Video
CORRECT CONNECTION TO AMP BEING A FOUR TERMINAL SPEAKER
Hello i_starling,
The Kicker L7's come in either 2ohm or 4ohm dual voice coil (DVC) versions.
Whatever amp they are connected to, you need to know both the impedance of your L7's and the impedance of your amp. The L7's dual voice coils can be wired to provide a total of four different loads:
2ohm coils in parallel = 1ohm load
2ohm coils in series = 4ohm load
4ohm coils in parallel = 2ohm load
4ohm coils in series = 8ohm load
Your best connection would be the one that results in a final impedance load that is supported by the amp.
Hope this helps.
May 01, 2009 | Car Audio & Video
Infinity car speaker
It's very possible the speakers have dual voice coils, therefore, would have two "+" and two "-" connections. With the model numbers of the speakers, I can confirm that for you.
Mar 30, 2008 | Car Audio & Video
Speakers
You have A and B output on your amp.For example you can connect two speakers on A and four on B but first check impedance of the speaker.Use four pioneers but make serial connection (+ wire of one speaker goes to +Rout,-of that speaker goes to + of another one and then its - to -Rout of the amp.Same thing for left channel.Thats for B output.For A simply connect speakers.By choosing A or B ON or OFF you'll get two or four speakers working.If A and B is ON all six will work.I hope that this will help you
Feb 29, 2008 | Audio Players & Recorders
Car stereo installation speakers
Your old unit was a common ground unit meaning all speaker grounds as well a radio ground were the same. The new unit should NOT be connected to this wire configuration. Newer units change the potential difference of the speaker power meaning that the - wire of the unit may have negative 24v on it so IT CANNOT BE REFERENCED TO EARTH OR CHASSIS GROUND.
I would recommend rewiring the speakers to the radio for best reliability and sound quality.
Dec 31, 2007 | Jl Audio 12W3 Car Subwoofer
JVC KD-G322 CD Player Logo
35 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
