How can i connect my samsung home cinema HT-THX22 to my sky +
  • 151 Answers
SOURCE: how to hear sky tv's voice from home cinema system?
PUT A SET OF PHONO CABLES FROM AUDIO OUT ON SKY TO AUX INPUT ON YOUR SAMSUNG.SWITCH SYSTEM TO AUX INPUT SET SOUND 2 PROLOGIC 2,AND HEYPRESTO SURROUND SOUND I HOPE.
HOPE THIS HELPS.
CABLE GUY.
Posted on Jun 26, 2008
kevin000
  • 1847 Answers
SOURCE: I HAVE A NEW SAMSUNG
check the all the cable connection are according to the manual.
Posted on Jul 09, 2008
SOURCE: dvd multiregion unlock code
Perfectly it work on the SAMSUNG HT X40
Posted on Oct 18, 2008
  • 11800 Answers
SOURCE: I am struggling to connect
There shouldn't be any problem : both Samsungs have the HDMI and SCART connections. For a good quality connection the HDMI is the easiest to setup - just plug the cable and select the corresponding HDMI entry from the sources menu : directly with the Source button on the remote or from Menu > Input > Source List and select the correct one.
The Virgin box should be connected using the AV inputs from the side - Yellow Red and White RCA ones.
Posted on Nov 30, 2010
  • 42 Answers
SOURCE: i have just bought the
you will have to connect an audio output from the tv to the sourround reciver. you should have some audio output on the back of the tv and a corresponding input on the samsung ht c555
Posted on Dec 24, 2010
Sound fades out on my Samsung ht-thx22 system
Please check the drivers and see if this section is heating up, If so there is possibilty that there is a thermal runaway or there is dry soldering on the board. You can check for heating or simulate the heat to confirm the case, if not the use of a freeze-it spray can cool the suspected component to be confirmed.
Oct 22, 2011 | Samsung HT-X20 Home Cinema 600W Theater...
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
I have a ht-tz2222r home cinema system and when it is on stereo or metrix on certain occations the system has a very loud crackling noice through the front speakers can you advice please.
I solved this problem by moving the audio leads from my sky box that went into my cinema surround system and placed them in the audio out from my T.V. into the surround system.I presume that there must be a problem with the Sky box!
Jan 07, 2010 | Samsung Audio Players & Recorders
Hello I have a Samsung HT-HTX22 home cinema. It wont play any discs at all, it says Loading then reads no disc or disc error, can any one help. Regards Joe
ik heb een vestel tv ,en krijg geen geluid via mn 5.1 ht-thx22 speakers omdat hy niet voorkomt op de lijst van het manual dus mijn vraag is ondersteunt hij ook vestel tv ,s of moet ik een samsung tv kopen m.v.g. D.Suverein
Apr 11, 2009 | Samsung HT-Z310T Theater System
Disc Unknown keeps coming up on the screen
check the dust content on in the m,achine then check your settings to make sure its adjust accordingly
Mar 30, 2009 | Samsung HT-DM550 System
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
How to hear sky tv's voice from home cinema system?
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Apr 04, 2008 | Samsung HT-Q100 System
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Dvd multiregion unlock code
use the procedure for unlocking the Samsung HT-DM150 .
Oct 28, 2007 | Audio Players & Recorders
43 people viewed this question
 Grubhead
Grubhead
