Question about Latin Percussion Lp Timbale Cowbell
Can i go for cummins 5.9 to ford 6.6 - Latin Percussion Lp Timbale Cowbell
    President:
  • 1,138 Answers
Sorry but this is posted in the wrong category. It has been posted under musical instruments.
Posted on Aug 22, 2010
Hi out there, I am trying find the correct age of my Classic Gibson Les Paul and am struggling. it's serial number is 064336. Any help would be great fully appreciated. Thank you
This is actually not an easy question to answer a Gibson (as you may already know) has used multiple numbering schemes..Your guitar may be a 2000... This is from Gibson's site: "Les Paul Classic: This model features an ink stamped serial number with no "MADE IN USA" (just as we used on the original 1952-1960 Les Pauls). Most will be 5 to 6 digits in length, but the earliest examples feature 4 digit serial numbers. There should be a space after the 1st digit with the 4 and 5 digit serial numbers, and no space with the 6 digit numbers. The 1st digit indicates the year of manufacture for the 4 & 5 digit serial numbers, these were used from 1989-1999. The 1st and 2nd indicate the year of manufacture for the 6 digit serial numbers which we've been using since 2000. Examples - 9 xyx = 1989 (4 digit number beginning with "9" used only in 1989) 0 xxyx = 1990 9 xyxx = 1999 00xyxx = 2000 05xyxx = 2005" http://www.gibson.com/Support/Serial-Number-Search.aspx/ Alternatively many people have gotten the best answer by calling Gibson directly: USA: 1-800-4GIBSON HTH!
Dec 10, 2017 | Gibson Music
How to reset line 6 spider 3 15 watts
Turn the amp off. Hold down the A (or clean) button as you turn on the power and hold the button for 5-8 seconds, then release.
Jan 25, 2014 | Line 6 Spider Iii 15 Modeling Guitar...
Guitar serial number lookup us11131155
Possibly... Here's what Fender says...
US11 + 6 digits
V + 5 or 6 digits (American Vintage Series except '52 Telecaster, which uses a five-digit number stamped into the bridge plate)
2011
(for American Vintage series, check neck date for specific year)
What model Fender is it?
Jan 25, 2014 | Fender Music
On the Marshall 5 button footswitch for the TSL, there are 7 wires in the cable, 6 of which are clearly labeled by color on the circuit board in the footswitch. The brown must be combined with another wire...
Only 6 wires are used by the amp. Tie the brown wire to the metal frame to act as shielding if anything. You will probably find that the brown wire either connects to the shell of the connector or to nothing.
Apr 23, 2011 | Marshall Amplification Marshall 5-Button...
Maybe stupid question....is it possible to record 8 separate mono tracks on this thing? I cannot seem to select only track 5, 6, 7, or 8. When I try to record onto 5, for example, it is impossible to not...
I believe you have to adjust the levels DURING the bounce operation... I don't think you can do that after.
I would consider using a computer based editing program to handle more than 4 tracks...
Aug 30, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
How do you reset your line 6 spider jam?
Hold down the settings/tone button as you turn on the power and keep holding it for 5 to 8 seconds. Here is a link you might like:http://line6.com/community/docs/DOC-4629
Aug 21, 2010 | Line 6 Spider Iii 75 Guitar Combo...
El transistor de poder de mi amplificador line 6 spider ii de 30 watths se quemo, quisiera saber el modelo del transistor para poder cambiarlo
If you want to know what the part number of the power amp in your unit is, it will be either a TDA2030 or TDA2050 which ia a 5 terminal audio amp of 14Watt or 32 Watt respectively.
Aug 11, 2010 | Line 6 Spider Iii 30
Need a 6 pin cable for Roland JX-3P
Make your own cable!
Check this connector or others at the site: (this is the male, not sure which *** you need on the cable).
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=CP-1060-ND
Use 5 conductor shielded wire. Connect the cable shield to pins 4 and others to their corresponding pins.
Mar 12, 2010 | Roland JUNO-D Synthesizer
On any channel I've begun to get a intermittant
If this has a digital effects processor read on.., I had a SIMILAR problem on a Behringer GX110.
The electrolytic filter cap for the 5 volts of the DSP effects had gone bad. The 5 volts was dipping when the DSP reset and it would repeatedly reset causing a clicking at about once a second. 50 cent part fixed it. The part is a little undersized electrically so is more prone to failure in the unit I have.
That particular one had the DSP as a seperate board with its own 5 volt supply from the main transformer.
Dec 18, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Latin Percussion Lp Timbale Cowbell Logo
32 people viewed this question
Top Latin Percussion Music Experts
Michial Gueffroy
Michel Laprise Sr
rhodesworks
Are you a Latin Percussion Music Expert? Answer questions, earn points and help others
