32" JVC CRT model AV32533 While operating the picture suddenly started oscillating wildly and creating a horrible matching noise which sounded as if it was also picked up from the attached sound system. I shut everything down and when restarted the television will not come on. The power light comes on and does not respond to the power button. It glows solid for a while and then starts blinking and will only go off if the set is unplugged. Thanks for your help.
  • 12 Answers
SOURCE: popping noises and no picture or sound
try replacing the stk's on the deflection board (making sure that all of the resistors on the board are OK and that there are no solder cracks I found one of the jumpers had a bad solder joint on the one I worked on) but if that doesn't fix I have some raw research that might give you somewhere to start :
No. The CRT driver ICs are prone to shorting and cause this symptom (I just had one with those very symptoms and the green CRT driver IC was shorted). Disconnecting the CRT board does not clear the short on the board. Often then is a small burn mark on the CRT board under the affected IC (but not always). The IC should be a TDA6111Q. Be sure to note the proper position
of the IC as it should face with the letters TOWARD the heat sink!!!!
Larry, Check the CRT driver ICs on each of the CRT boards.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7769 FAX
Hi Guys, I don`t see many JVC`s and don`t have the print for this AV48WP30, went out this morning and as customer claimed on phone when you plug set in and turn on it makes a loud thump thump in both speakers 20-30 times then relay clicks, the thump stops, and blue idiot light on front goes dim/bright, dim/bright, have to unplug set to start this same scenario over again. Never develops HV or audio, Will order the service manual today, but would like to know if anyone has seen this before (should say "heard" this before)
I would disconnect each crt board and hv lead one at a time and try. Have seen several bad tubes on that model. The only other problem I have seen on that set is bad convergence amps, however that doesn't cause shutdown.
Perry Bower
Electric Medic
From Tech Repair CD:
JVC\AV48WP74\just went click*click*click when turned on Video drive IC (IC1101) on the red CRT module
shorted. It looked like bad solder on the B+ was the cause
Frequently Used Top Five Repair Parts by symptom code
Above from JVC Web site, also I have seen shorted video drive IC's on the crt boards short and cause this symptom. Try unplugging the 200 volt source to the crt boards and see it the set powers up and stays on. There is a B+ relay which supplies 130 Volts to the horizontal output circuit. Is this relay energizing? I takes about five seconds after the power is turned on for it to energize. If a short is detected on the 130 volt line the blue power lamp on the front will do what you describe and the relay will pulse on and off. (David)
Non-functional Digital Input
1. Power off the unit
2. Disconnect the digital input if it is connected
3. Remove the rear cover
4. On the digital input module, using a shorting pin (PC type) or a
jumper, short Pin 1 and Pin 2 of the
SB connector
5. Power on the unit
6. Unplug the unit and remove the shorting pin or the jumper
7. Re-attach the unit’s rear cover
8. Power on the unit, and input the digital source
Posted on Dec 06, 2007
SOURCE: JVC HD-527575 problem
We just had the same problem. The Projector lamp is burned out. You can get the lamp at Their phone # is 800-678-8585
Posted on Oct 22, 2008
SOURCE: samsung hcm4216w won't turn on light blinks then shuts down and tries to restart again
Your problem is TV is not getting enough power so you better buy a stabilizer and make the power to go thro the stabilizer to TV then it will get sufficient power supply everything will be smooth afterwards even the voltage problem.
Posted on Nov 04, 2008
SOURCE: jvc tv
when both the blue light and red light are blinking it means 1 of 3 things. 1. lamp replacement. This often works everytime for the repair. TIP!!! DO NOT USE ANY OTHER LAMPS OTHER THAN JVC AUTHENTIC LAMPS. ANY OTHERS AND YOU RISK DAMAGING YOUR TV FURTHER. 2. the fans are not working properly or need to be replaced. They need to be cleaned every so often and they will stop working from burn-out if not done so. This repair will cost you less than 100 dollars. 3. The ballasts are defective and need to be replaced. The ballasts themselves run about 150 dollars. I tell you I have fixed this TV more times than I care to count, not to mention the number of lamps I have gone through. The guy at the TV repair place now knows me by name when i come to buy lamps. :(
Posted on Dec 07, 2008
Try unplugging converance board if the tv turns on and has HV replace converance chips
Posted on Apr 25, 2009
Our 32'' JVC TV model # AV-32030 has an obscured picture.
With the remote go to the Closed Caption menu and make sure it is turned off.
Let me know if this helps
Apr 03, 2009 | JVC AV-32020 32" TV
Dark screen
the sound is locked off the TV good picture
Feb 20, 2009 | JVC AV-27320 27" TV
try resoldering vertical ic pins
Apr 19, 2008 | JVC AV-32260 32" TV
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
JVC AV-32730 36" picture problem..
From what you describe, a solder joint has probably cracked loose in a power supply or deflection circuit, which is quite common. Since you do sometimes see a good picture, all of your major components are fine. Repairing cracked solder joints is a very easy procedure and definately worth fixing on a 32 inch TV. The first 2 digits of the model number indicate the size of the TV.
Aug 04, 2007 | JVC AV-32D305 32" TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
You have a bad flyback transformer and shorted horizontal output transistor. Your set would have to be taken to a shop to have these parts replaced. Stargazer
Aug 04, 2007 | RCA 32V550T 32" TV
Stand-by LED blinks-no picture or sound
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, video if,sound if, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician
Jan 16, 2007 | Sony KV-32V40 32" TV
RCA F32650
I let it go and she corrected by herself. What do you think?
Aug 14, 2006 | RCA F32650 32" TV
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
