Question about Sony PlayStation 2 (PS2) Console
Playstation is not running many of my disk read errors on my ps2 slim 90006
  • 277 Answers
Hi, You’re going to be surprised when you find out how easy this is. Read the instructions all the way through before you attempt the repair just so you’ll be familiar with the entire process. First take off the outer cover of you PS2. If you haven’t done this before, you will have to remove all the screw covers from the bottom of the unit, both plastic and rubber, these will be the only screws you will have to remove in order to take off the outer cover. {mos_sb_discuss:18}
To remove the outer cover, lift up from the rear of the unit and pull towards the front in order to clear the controller jacks and the eject/close buttons. As you remove the outer cover you will notice a small metallic ribbon cable inside the machine leading to the eject/close and reset buttons on the front of the unit, this cable is usually taped to the top of the disc tray. This cable is not a sensitive as it appears; just remove the tape holding the ribbon cable. Once the outer cover is off you need to remove the cover to the disc tray, this will require a rather small phillips screwdriver (I’ve seen a few that use a standard slotted screw). Now that the tray cover is off, the first thing to do is to clean the laser eye. All you will need is a Q-Tip dipped in alcohol. Just swab the eye a few times and allow it to dry on its own, making sure that no lint was left behind from the Q-Tip.
After the cover is off of the disk tray and the laser has been cleaned you will need to plug the unit back in, (The unit needs to be hooked up to a TV as well to test it while you have it open. You should have a DVD, a game disk with a silver or gold back and one with a purple back in order to fine tune the system to play all three.) It will be necessary to have the unit powered up to perform the repair. Press the eject button so that the tray slides forward exposing the undercarriage. At the back of the unit you should see a small white, geared wheel about the size of a quarter. This little bastard is the cause of all your problems.
This wheel changes the angle in which the disk is held. You will notice that there is a small metal tab that holds the wheel in place. Take a felt-tip marker and mark the point on the wheel that meets the tab. That way you will always know the original position that the wheel was in. Now that the orig. position has been marked, feel free to spin the wheel for a few full rotations in order to see how it changes the angle. It will only alter the angle a few degrees before it goes back to zero, after it reaches the maximum angle it will go back to flat after each full rotation. Once you’ve toyed with it to see how it works, put the wheel back to the original position that you have marked. Then advance the wheel about 1/8 of a turn and place the disk tray cover back on top of the disk tray. (You will not need to screw the tray cover back down in order to test the machine; you will only need to hold down the cover with your fingers while trying to load/test a disk) Now place a DVD in the tray and press the eject/close button in order to close the tray and load the DVD (hold down the cover as explained above). Wait to see if the DVD loads, you may have to use the browser in order to load each disk you test. If the DVD loads, eject it and load a silver backed disk, if that loads try a purple backed disk. If all three loaded successfully, congratulations you’re finished. If not, remove the tray cover, eject the disk and advance the wheel another 1/8 turn and repeat the process. It just a matter of finding an angle that will facilitate the operation of all three types of disks. Once you’ve found the proper angle and the system is operating to its full potential, close it up and let’er rip. I also do not recommend placing the PS2 on its side once you have fixed it. Although Sony says they recommend it in the owner manual, I have since seen internal Sony documents retracting the statement and attributing many malfunctions to storing and operating the unit on its side. Keep it flat at all times.
Source
Useful Links
fixya.com/support/t147428-disc_read_error
It has pictures for disassembling your PS2
Posted on Aug 21, 2010
Wont run my game on ps2 slim what do I do?
ps2 games come in 3 colors blue which is rare, Black and clear. the slim has problems reading some. what color is the bottom of the game?
Aug 23, 2009 | Sony Champions of Norrath: Realms of...
Ps2 (slim)
Well first off, make sure the disk if in PS1 OR PS2 format. That is what the PS2 Is requesting when it says "Please insert Playstation or Playstation 2 format disk. The Slim PS2 has various problems reading disk.(Don't Know why? I own it and Know it does). The Fat version(1st version) is a much better system, in my opionion. Try blowing air to clean the disk reader. Or changing the disk reader portion out, At a small price.
Apr 03, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 slim 90006 series can't play orig dvd movies why?
its the new psp it never plays originals only originals with upgrades
Mar 17, 2009 | Sony PlayStation 2 (PS2) Console
GTA Vice City Error
I had this problem it's not from the ps2 it's from the disk. For some reason gta disks don't want to corporate with the slightest of scratches.
Mar 14, 2009 | Rockstar Games Grand Theft Auto: Vice City...
Dispaly cannot read disk
DONT FORGET TO RATE SOLUTION
1. CLEAN THE LASER. ALWAYS DO THIS FIRST. MOST TIMES THIS IS ALL YOU NEED TO GET YOUR SYSTEM BACK RUNNING A 100% AGAIN
2. IF THE LASER CLEANING DON'T WORK ON YOUR PS2 SYSTEM PERFORMANCE THEN TRY ADJUSTING THE LASER VOTAGE.
3. IF THE LASER VOTAGE DON'T WORK YOU NEED TO REPLACE THE LASER
Nov 18, 2008 | Sony PlayStation 2 Slimline Console
Playstation 2 is not reading disks
my playstation can not play nstc disks
Oct 25, 2008 | Sony PlayStation 2 (PS2) Console
Slim ps2 disk read error
I don't want to put you down or nothing but, buying the slim ps2 wasn't a great idea. If you bought the original ps2 it would've been better. The thing about the thin ps2 is the hd is small, the laser tends to become weaker faster. Go get the ps2 checked out someplace.
Jun 26, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
You will ne4ed to clean up the PS2. open it up and clean the laser lens with alcohol on a cotton swab. If it is the Slim Ps2 model you should not use Alcohol. Use A glass Cleaner like windex on the slim. Sometimes the magnet gets week and you need to add some magnetism to help improve the spindle grip on the Game disc. Cut up a refridgerator magnet and place it in the white cap thatt clamps the Game disc in the cd player.
Jan 06, 2008 | Sony PlayStation 2 (PS2) Console
I keep getting a "Disk Could Not Be Read" error.
maybe the lens of ur ps2 slim are dirty...if not you may need to replace it, coz lens get weak after a long time of stress using it...
Oct 08, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
377 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
