Question about Microwave Ovens
The clock is flashing all zeros - cant set it
  • Microwave Ovens Master
  • 3,740 Answers
Press: Stop cancel
Press: Clock or Autostart (depending on model)
Set time
Press clock or autostart.
Should have the time set......
If this is too generic pleae provide a make and model and I wil see what the manual says verbatim.
Kelly
Posted on Aug 21, 2010
How can I reset clock on Lamona HJA7030 microwave. I have followed instructions in manual without success
Press the clock button for 3 seconds: the hours digit will flash. press the +/- to set hour. Press the clock button again: the minutes digits will flash. Use +/- to set. Press the clock button again. Done....
Oct 29, 2017 | In Microwave Ovens
Every time i set clock, it goes back to all zeros. Why
When You set clock push clock, then after you set time push the clock button again! But remember this, if You unplug the Microwave most of the time it will lose time and You will have to reset it! Hope this helps!
Jul 14, 2017 | Microwave Ovens
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
Clock will not set time
Most microwaves just need to have the clock button pressed 1 time. Then you enter the time. Next some want to to pick am or pm. Then press clock again to set. Sometime last step is the start button instead of clock.
Mar 02, 2015 | Kenmore Elite White 1.5 Cu. Ft. Convection...
Does not turn on all the numbers on panel are zero's and blinking, did try unplugging still nothing
Flashing zeros are a sign of a momentary power loss. Usually you also get a Pf error also. Not always....
Try this and if it does not work let me know.
Press Stop / cancel
Press clock
Set time
Press clock
Attempt normal use.
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Sharp R-209HK Microwave Oven
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Operating Instructions Mistral MMW17SS
Hi Bryan... I had the same problem as you in trying to work out this blasted clock!!! - by fluke I worked it out!!
Here are the steps:
1 - press the 'clock' button (to ensure the clock is displayed) 2 - press the 'cancel' button (the display will go to zero '0' 3 - use the keypad to enter the time (at this stage the colen between the hour and minute numbers will not be flashing. 4 - press the 'clock' button again (the colon will start flashing and the time will be set.
your frustrations are over my friend!
May 07, 2009 | Microwave Ovens
Keypad Problem?
look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
May 25, 2007 | Emerson MW8168B Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
