Question about Gateway FPD2185W 21 in. LCD Television
No picture Solid blue light at switch. can not turn off. Changed all swollen caps on both boards but still the same thing.Any Ideas ??? Thanks Mike
  • 2 more comments
  • tjones29 Jun 22, 2008
    Same Problem. when i first turn it on it is a bright blue light. then fades to a lighter blue. there is not picture and cannot turn off.
  • jim483 Jul 15, 2008
    same problem. When power cord is pluged into outlet the blue light gets real bright and then fades to a dim blue and no picture. Just black screen. This is the Gateway 21 inch FPD2185W same as the one mentioned. Hope there is help for it. Beautiful picture when it was working!! No steps taken yet. I have no idea what to do with it.
  • sagreen Jul 22, 2008
    My monitor is doing the same thing. Is there a way to fix this without having to take the monitor and have it fixed?
  • Shrubs123 Aug 02, 2008
    Same problem no matter what cable is used(DVI, VGA, S-VIDEO, COMPOSITE) Blue light on button goes bright for a second when first pluged in then goes dim and you never get a picture. Gateway support was absolutly no help as of course its out of warrenty.
    Thanks.
    Problem Solver:
  • 3 Answers
Dunno if I'm about to have the same problem. Maybe you guys know...
I went to power it up this morning and it gave me some problems:
I leave my PC on at night, but I turn the monitor off. So this morning I hit the blue button:
The monitor came on for a brief second and then off. You could see my desktop, but it quickly shut off.
I run a PC on the DVI input and another PC on the VGA. I tried switching between the two and it didn't work. The monitor would come up for a split second, and then off. The power switch would eventually go to it's normal standby yellow.
I tried unplugging the power cable for about 15 minutes - no help.
So my last ditch effort: I unplugged EVERYTHING off the monitor - all cables, power, etc...
Waited a few minutes and plugged the DVI back in first and then the power. It came back on.
Am I looking at a permanent failure in the near future? Could it be these capacitors that was previously mentioned?
I don't know if this thing is still under warranty. Probably not.
THanks,
Homer
Posted on Sep 21, 2008
There are 3 screws at the bottom of the unit. Take those out.
At the bottom get a small screwdriver and slowly start to push inbetween the plastic. there are tabs all around the side of the unit. You have to be careful and push in and it will snap open.
There isnt too much cable for the power switch, so you will have to disconnect the cable. this will allow the rest to open up.
Once you do this, 4 screws hold the LCD in place, remove these. Carefully from the bottom pivot the LCD screen. On the right hand side 4 connectors will need to be unplugged and one main cable on the left had side. Be careful not to damage the socket.
There is a metal enclosuer that has to be removed, once done open the top and remove the power board. There are about 12-14 capacitors that if you replace them. The unit should power up.
Posted on Sep 06, 2008
I have replace all the capacitors on the power supply board. The cost was around $10 from Newark-one. The unit works ok but never got any USB power, since I dont use that I am set.
Posted on Aug 22, 2008
I have this same problem with my monitor. Is there a way I could fix this myself without having to take it and have it fixed?
Posted on Jul 22, 2008
    Problem Solver:
  • 6 Answers
Http://en.wikipedia.org/wiki/Capacitor_Plague
Posted on May 22, 2008
I have a Hisense LCD T.V. model H32V77C. Power indicator is red. When I push the power button, indicator turns blue, then blinks red 3 times and returns to blue, then shuts off.
hi sounds like there's no backlight voltage, check power supply board for any swollen caps, if ok, test the voltage on the white connector from the power board to the inverter board , with a meter should be 24v dc thanks
shaun
Mar 21, 2017 | Hisense Televison & Video
I have a Philips 32PF5521D and currentky have no sounds. I have a picture but when i go to turn the sound up on the remote nothing happens. The green power light is also flashing a green light. Is there...
First look on power supply board for bad capacitors they will be vented or swollen on Top, If No bad Caps then try resoldering boards ,if this does not clear out the problem then replace the SSB board ,known as signal board .
May 31, 2011 | Philips Televison & Video
My Toshiba 52XV540U won't turn on even I tried many method described in manual. I also checked two fuses inside, they look good. Any suggestion? Thanks!
Do you have any tv repair exp? If not take it to a shop! If you do, then check for swollen caps.There are 5 fuses in that set,2 glass ones and 3 light blue solid that says 5 amp. I have a same mod. tv as you that I can't fix. It's probably the main power board as is mine. The board but most likely has to be changed. I am checking on a price and don't know yet. I have 35 yrs. exp. in repairing tvs. I can fix most of the lcds that i get. Sometimes I have a hard problem.If you don't have any tv repair exp.then you need to take it to a shop.Either they can fix the board or find another one,perhaps a used one,which will be a whole lot cheaper. The tv is still worth putting a few hundred in it, unless you can afford a new one. Maybe a bit smaller since they are coming down quite a bit. I will let you know what happens with mine!
Aug 23, 2010 | Toshiba 52XV540U 52 in. HDTV LCD TV
Turn on tv and purple pixels like snow are spread around tv.
First thing replace any swollen capacitors in the power board.
Sep 01, 2009 | Samsung LNT5265FX 52 in. LCD Television
Picture takes almost an hour to come on
Replace swollen capacitors on power board.
Aug 29, 2009 | Polaroid FLM-3201 Television
TV Sucks - Hisense TL2020
Your problem involves 4 electrolytics on the power supply board. There are (3) 1000 mfd @25 volts and (1)220 mfd @16 volts. The power supply board is situated in the middle of the set slightly off to the right. It is held in with 4 screws and has 2 small harnesses on it. The 3 1000 mfd in the set that I was repairing were all swollen at the top and when I ran them on an esr meter sure enough they were opened. The 220 actually tested ok but was a little swollen at the bottem so I changed it anyway. After replacing all caps, normal operation was restored. Thanks, Jack from Staten Island
Jul 23, 2009 | Hisense TL1700 17 in. LCD Television
All my DRC8335 vcr-video system says is hello
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Solution #1 posted on Feb 22, 2009 Asker's Rating 0%20stars_w.png
noavatar_s.gif dvickery926
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Thanks to the help on this forum, I was able to fix my DRC8335 power supply. C226 was the problem, went to Radio Shack and found the 470uf 35V replacement. It came up and worked like a charm after soldering it in. (See the picture of the cap on the board). It was just slightly swollen when viewed from the top but when i removed it, the bottom was really distorted. Thanks to micro065 and Mike Powellebbca66.jpg
Comment posted on Feb 22, 2009 Thanks to Mike Adams not Powell, sorry. Mike Adams is a FixYa Expert.
May 02, 2009 | RCA DRC8335
OPen the tv up
The bulging/swollen caps mean that they have basically gone bad and have lost their capacitance and need to be replaced and are the most likely problem to the light that you are seeing. Make sure a qualified person replaces them otherwise you will just end up spending more in the long run.
good luck and let me know how it turns out
bestdarngood
Feb 08, 2009 | Dell W4200 42 in. HD-Ready Plasma...
Blue Flickering Screen - Which Repair Kit?
yes they provide a free service manual with their kits. the symptom of the blue screen could either be the signal or the FMT as they can both cause those symptoms, My professional guess would be the signal board as the FMT will cause distortion lines across the screen with no picture.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
172 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
