Question about Xerox Phaser 6180N Laser Printer
Paper jam I have a 6180 xerox printer and I can not find the paper where its telling me I have a paper jam
  • jsmithmyth Oct 23, 2008
    It says there is a Jam at Exit Open Door A. The printer was taken apart but we still don't see the paper. I had a glossy piece of paper in there and it's no longer in the tray but it's no where to be seen.
  • Anonymous Mar 25, 2014
    paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
Posted on Oct 23, 2008
My Xerox phaser 6180 keeps saying there is a jam at exit. Open door A. I have taken it apart & cleaned/cleared everything I can. Any suggestions?
This could be some paper still stuck in the fuser, so check that.
The usual cause of this, is the 'paper out' sensor arm (in the fuser) being broken.
I'm fairly sure that this is NOT available from Xerox as a spare part, so the quickest, easiest solution is to replace the fuser.
Jul 21, 2015 | Xerox Office Equipment & Supplies
Clean printheads on Xerox phaser 6180
This type of print quality defect shows up if you have loaded the wrong type of paper in your machine and didn't remember to change the paper type (plain paper, card stock, labels, etc.).
This can also happen if the paper has a high moisture content, or if the humidity in the room is too much. Also make sure the room temperature is within its normal operating range (not too hot, not too cold).
The problem you describe could also be caused by using non-Xerox toner/drum units. Compatible toners don't work very well in Xerox printers.
Aside from those problems, the only other thing would be if the Fuser Assembly is near the end of its will also cause some print quality problems like you are describing.
Dec 24, 2013 | Xerox Phaser Office Equipment & Supplies
My phaser 6180 color printer, toner not adhering to paper could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
Xerox 7760 paper jam
at which position it will jam it matters tell in detail or send a sanp of it
Apr 10, 2013 | Xerox Phaser 7760/YDX Laser Printer
Xerox 6180 James at Tray 1 mpt every time!
Your lower trays are programmed incorrectly. Change the size and or the paper type back to letter and plain paper
Aug 23, 2012 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 6180 keeps saying load papertray with
Remove the paper tray and check the guides. Make sure they are lined up on the 8.5 X 11 marks. If it is lined up, try going into the menu of the printer and reset back to defaults.
Jul 21, 2011 | Xerox Phaser 6180N Laser Printer
I'm getting Jam at Reg Roll on my Phaser 6180, and I think there may be a bit of paper in the paper path, but i can't see it. The machine says Open Door A, which I've done a few times, but it isn't...
Had exactly the same problem... today actually.
Found the solution with another model's manual - I removed the paper from the top, but hadn't realised there was a jam in the paper tray. It was only when pulling it out completely that I found it as below...
Jam at Registration Roller
1. Remove Tray 2 completely.
2. Clear the jammed paper from the printer's
intake slot.
3. Re-insert Tray 2.
4. Open front door A.
5. Remove jammed paper if present.
6. Close front door A
Nov 23, 2010 | Xerox Phaser 6180N Laser Printer
I have a Xerox Phaser 6180 MFP, and it keeps saying paper jam and there is no jam, what can I do?
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Sep 03, 2010 | Xerox Phaser 6110 Laser Printer
We have a paper jam on our Xerox 6180. It jams on every page. When I pull the paper out there doesn't seem to be a jam, probably a bum sensor. Strangely it happened when we replaced a cartridge.
Please Call this number for this solution, details is given below.
Technical Support, Manuals and Documentation - 1890 925 050
Note - Access drivers, downloads, manuals, documentation and the online support knowledge base. Please have your serial number handy.
Thanks for using Fixya.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
Mar 16, 2010 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 6180N Laser Printer Logo
1,628 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
