Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
Kenmore Elite Trio (w/ bottom freezer), Model # 596.76509500: Freezer is working, but refrigerator no longer cools. On the advice of a friend (and reading this website) thought that perhaps fan had "frozen," so I emptied fridge and freezer and unplugged it for 3 days to thoroughly "defrost." Upon plugging back in, same problem continues. Am unable to change temperature on the (up/down) keypad. The digital readout simply reads what the temperature is in the freezer and the fridge. Unit is only 2 years old. My previous fridge went over 20 years before encountering any problems!
22yooper
  • 828 Answers
SOURCE: Refrigerator warm, freezer cold
Totally Unreasonable if you don't mind me saying so. The person who told you that story was thinking of an absorption unit more than likely.
Your proble is related to the defrost system of your refrigerator. There is a timer that automatically starts the defrost. It energizes the heaters that defrost the cooling coil. After the coil reaches a preset temperature a defrost terminator turns the heater off for the remaining time on the timer cycle. You could have a bad timer (stalled) which would not start the defrost. Locate the timer and turn the clutch head screw clockwise very SLOWLY until you hear one audible click. The defrost should take place and will be indicated by water in the drain pan under the refrigerator. If after 25 minutes it does not restart in the cooling mode turn the screw once again to the second click and replace the timer.
If the refrigerator restarts after 18-22 minutes and defrost does not take place your problem is in the heater circuit. Open heater or thermostat (termination switch)
Posted on Jul 16, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
  • 62 Answers
SOURCE: Freezer is fine. Fridgerator portion does not cool .
The most likely cause is a bad evaperator fan motor. It is mounted in the freezer section. It blows the air up to the ref section. Open the freezer door and listen to see if you hear any fan noise.
Posted on Dec 06, 2008
  • 145 Answers
SOURCE: My Kenmore Elite refrigerator keeps freezing the food!
Replace your thermostat and will work like new again
Posted on Jun 07, 2009
  • 93 Answers
SOURCE: Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Posted on Sep 13, 2009
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
I have the same problem that someone else on here has, my freezer is working but my fridge is warm. What could be the problem?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 05, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Freezer still working. Refrigerator not cooling. Hot to top on inside of left hand door as you face refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 31, 2011 | Kenmore Elite Trio 7855 (25 cu. ft.)...
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
303 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
